Old 03-04-2011, 10:45am   #1
Toque
Points: 4,023, Level: 42
Toque's Avatar
Gameroom Barn Bucks: $1077
Default Aftermarket Seat owners - Color matching BLACK carpet for the feet of seat brackets.
Guys:
Ever since I installed my Corbeau A4's (and Corbeau seat brackets) I have been left with an empty spot around the mounting feet. Its a big bare floor "Silver" spot around all the mounting feet where there is no carpet. I have wanted to find some carpet or something to cover it up. The factory seat brackets have a plastic cover to cover this bare carpet area.
While reading the forums I found a post where he made his own partition and put carpet on it. I asked him if the color was close to factory and he said it was very close in color. He got it at Walmart for $9.
I went to Walmart Wed night and got some of this carpet. Its a little thinner than the factory carpet but the color is surprisingly perfect. I was surprised how close a match it was.
I lifted my seats, then cut 8x square pieces of this carpet (6"x6"), then cut a hole in the middle for the bolt to go thru. I was able to slip this carpet square under the existing carpet easily.
You can now barely see where the factory carpet ends and this carpet starts.
Gives it a "finished" look that I wanted. It matches ALOT better than the expensive Lloyd mats I have... seriously !
Walmart Item # 15524364 (under $9).
Hope this helps someone...
Toque
The Following 4 Users Say Thank You to Toque For This Useful Post:
Old 03-04-2011, 11:20am   #2
Looks good! I had some black carpet that I used on a board to cover the amps behind the bulkhead. I cut a couple small pieces and did the same. The insulation you and I put in really made the hole stand out.
Old 03-04-2011, 11:31am   #3
Toque
Toque's Avatar
Thanks !
The insulation you and I put in ? What insulation is that ?
Under my carpet is bare balsa wood...
I don't need no stinking sound deadening...
Toque
Old 03-04-2011, 11:47am   #4
Bucwheat
Points: 49,877, Level: 100
Bucwheat's Avatar
Pretty cool!
Old 03-08-2011, 8:57pm   #5
Eagleeye
Points: 10,779, Level: 71
Eagleeye's Avatar
Gameroom Barn Bucks: $2288
Looking at those seats but I have 39-40 waist...5'11" and 198 lbs. What do you think ? I've been told it might be too snug ?
Old 03-08-2011, 9:28pm   #6
Originally Posted by Toque View Post
Thanks !
Toque
Big motors make a lot of heat...
Old 03-09-2011, 12:04am   #7
Toque
Toque's Avatar
I'm 38" waist.... 6ft, and 210lbs.
I sure don't want to gain any weight...
I'm snug in them ... but not overly. I just don't want to get any bigger or it might get uncomfortable.
Toque
