Old 11-01-2014, 12:00pm   #1
Fasglas
Barn Stall Owner #457
Points: 43,479, Level: 100
Activity: 77.6%
Fasglas's Avatar
Default USN - Was NOBODY shot watching?
Who's in charge here? Heads ARE gonna roll.
Fasglas is offline   Reply With Quote
The Following User Says Thank You to Fasglas For This Useful Post:
Old 11-01-2014, 12:18pm   #2
Thunder22
Points: 18,869, Level: 94
Thunder22's Avatar
Gameroom Barn Bucks: $216475
13 years ago?
Thunder22 is offline   Reply With Quote
Old 11-01-2014, 12:20pm   #3
mrvette
Barn Stall Owner #101
Points: 146,877, Level: 100
Activity: 2.3%
mrvette's Avatar
OOOPS!!!!!!
mrvette is online now   Reply With Quote
Old 11-01-2014, 12:31pm   #4
Aerovette
Barn Stall Owner #7734
Points: 124,581, Level: 100
Activity: 13.4%
Aerovette's Avatar
I am ignorant about such things, but with all that tonnage of chain and anchor, how do you even know when the anchor hit bottom?
Also, what was the cause of losing the chain? Too much speed? Water too deep? No way to stop it?
Aerovette is online now   Reply With Quote
Old 11-01-2014, 12:33pm   #5
Fasglas
Activity: 77.6%
Fasglas's Avatar
Originally Posted by Thunder22 View Post
13 years ago?
Does that matter? Seriously?
Old 11-01-2014, 12:43pm   #6
Fasglas
Activity: 77.6%
Fasglas's Avatar
FIRST is to ascertain how deep your intended anchorage is.
Each shot of chain is joined together with a detachable link.
One fathom equals 6 feet. There are 15 fathoms (90 feet) in a shot of anchor chain.
This method is used through the entire marking procedure alternating red, white and blue
for detachable links as appropriate
The Following 2 Users Say Thank You to Fasglas For This Useful Post:
Old 11-01-2014, 12:54pm   #7
DukeAllen
Points: 42,433, Level: 100
Activity: 99.5%
DukeAllen's Avatar
I know .gov moves slow, but surely even they've replaced the anchor after that many years.
DukeAllen is offline   Reply With Quote
Old 11-01-2014, 12:55pm   #8
73sbVert
Moderator
Barn Stall Owner #20
Barn Stall Owner #33
Points: 32,476, Level: 100
Activity: 2.2%
73sbVert's Avatar
Gameroom Barn Bucks: $988270
The anchor must have hit bottom with the 3rd shot out. Did you hear them talking about 1 o'clock, heavy strain? That meant that the ship was pulling away from the anchorage pretty hard (in current) based on the amount of "droop" in the chain, and it was tending at 1 o'clock from the bow. Considering they used the port side anchor, then the chain must have crossed the ballast bulb (or sonar dome depending on class of ship this was on, I couldn't tell).
Unlike small boats, the anchor isn't used to hold the ship in position, it is only used to pull the anchor chain out and down. THAT is what holds the ship, all that chain laying on the bottom. If I recall correctly, the amount of chain required (at minimum) is 3 times the depth. If you are in 10 fathoms of water (60 ft), then you need 30 fathoms of chain, etc.
There must have been something wrong with the brake systems. The wildcat has both electrical AND mechanical brakes. Those 2 guys in the background cranking on that wheel were on the brake. It should NOT have taken so many turns on that to release/hold the brake. I have a feeling that the electric brake was overwhelmed by the speed of the chain and the mechanical brake failed totally because the guys on it kept cranking and it wasn't operating correctly. Should have only taken a few turns on it one way and the other (off/on).
My 2 cents...
73sbVert is offline   Reply With Quote
Old 11-01-2014, 12:58pm   #9
Aerovette
Activity: 13.4%
Aerovette's Avatar
I understand how they can measure with markers. On a pleasure boat, you drop the anchor and you feel the rope slack and you know you are on bottom, Tons of chain with no sensation of slack is far different.
I would guess they know the depth in advance and release the appropriate amount of chain, but that is a guess on my part.
Old 11-01-2014, 1:00pm   #10
Aerovette
Activity: 13.4%
Aerovette's Avatar
Originally Posted by 73sbVert View Post
The anchor must have hit bottom with the 3rd fathom out. Did you hear them talking about 1 o'clock, heavy strain? That meant that the ship was pulling away from the anchorage pretty hard (in current) based on the amount of "droop" in the chain, and it was tending at 1 o'clock from the bow. Considering they used the port side anchor, then the chain must have crossed the ballast bulb (or sonar dome depending on class of ship this was on, I couldn't tell).
Unlike small boats, the anchor isn't used to hold the ship in position, it is only used to pull the anchor chain out and down. THAT is what holds the ship, all that chain laying on the bottom. If I recall correctly, the amount of chain required (at minimum) is 3 times the depth. If you are in 3 fathoms of water (18 ft), then you need 9 fathoms of chain.
My 2 cents...
It did actually stop for a while.
Old 11-01-2014, 7:28pm   #11
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 124,970, Level: 100
Activity: 2.6%
JRD77VET's Avatar
My 2 cents...
Correct
Hopefully no one was hurt during that fiasco. That is some serious tonnage and momentum there
JRD77VET is online now   Reply With Quote
