Old 10-30-2009, 11:57am   #1
NEVRL8T
Barn Stall Owner #25
Points: 27,763, Level: 100
Activity: 0.5%
NEVRL8T's Avatar
Default Any ideas?
I have a 1992 coupe that needs a drivers side power window motor replaced. The window is about 3/4ths of the way down. The motor is below the bottom edge of the inner door frame. Do I have to remove all of the hardware that the FSM says to remove to get to this motor. In other words. Do I have to drill out the rivets and remove the door pull and the entire metal accessory plate. It looks like aluminum and covers the entire door opening. I have no clue what I am doing. I am not even sure it's the motor. I replaced the switch to no avail but I need to be able to get to the motor to test it. Right now the window is down too far to do that. How in the world can I get the window up far enough to test the motor? Thanks for any help you can give.
NEVRL8T is offline   Reply With Quote
Old 10-30-2009, 3:41pm   #2
Firevette
Barn Raising I
Points: 7,718, Level: 61
Firevette's Avatar
Gameroom Barn Bucks: $14884
Good question. I haven't had to do one on my C4 yet. But if its anything like any other 90's GM then yes, you will have to pull the aluminum cover to access the regulator and motor in a manner that you can work with it. I'd assume there are screws around the perimiter. If you are going to pull the motor and its original, you will have to drill the rivets.
The best thing Ive found with windows is take your time, and dont force parts on and off. Every door panel is different and you dont want to break any plasic snaps or fasteners.
Good luck!
Firevette is offline   Reply With Quote
The Following User Says Thank You to Firevette For This Useful Post:
Old 10-30-2009, 6:30pm   #3
NEVRL8T
Activity: 0.5%
NEVRL8T's Avatar
Thanks for your input. I have still have a problem with that if anyone can help. The window is still down so far that even pulling all the covers off, I still wont be able to reach the motor. If anyone knows how I can access it or get the window up let me know please.
Old 10-30-2009, 7:36pm   #4
Firevette
Barn Raising I
Firevette's Avatar
huh..im trying to picture what you are talking about. Pic's?
Old 11-01-2009, 6:54pm   #5
Ocalaguy
Barn Stall Owner #19
Points: 5,213, Level: 49
Activity: 12.3%
Ocalaguy's Avatar
Gameroom Barn Bucks: $52371
See if this helps
Ocalaguy is offline   Reply With Quote
The Following User Says Thank You to Ocalaguy For This Useful Post:
Old 11-01-2009, 7:39pm   #6
YorkL8apex
Charter Member - C4 Mod
Barn Stall Owner #91
Points: 5,706, Level: 51
YorkL8apex's Avatar
Gameroom Barn Bucks: $2164
www.corvette.JustAnswer.com
Never tried it but Gary has this posted at the bottom of the page, may be worth a try?
1991 SGC ZR-1
YorkL8apex is offline   Reply With Quote
The Following User Says Thank You to YorkL8apex For This Useful Post:
Old 11-02-2009, 10:02am   #7
NEVRL8T
Activity: 0.5%
NEVRL8T's Avatar
I went full 'tard there for a minute. Disregard that post.
Originally Posted by Ocalaguy View Post
See if this helps
Thanks! I have the manual but have not really perused this project yet. I have been so busy with school and kids that I have been a little overwhelmed. One question though, what does it mean by "scribe the location" of the upper regulator bolts? And how do I lower the window regulator 3/4ths of the way down if the window motor wont work? Will the glass still come out even though the windo is almost all the way down now?
https://www.thevettebarn.com/forums/image.php?type=sigpic&userid=185&dateline=1324498141
Old 11-02-2009, 11:57am   #8
Ocalaguy
Activity: 12.3%
Ocalaguy's Avatar
Scribe..... to make a mark. Use a pencil or sharp pointed tool to make a mark where the bolt is located on the window regulator.
As far as moving the window I don't know. My guess is you have to move the window so you can get to the bolt that holds the glass to the regulator. Once you take that bolt out you can lift the glass out of the door.
Good luck.
Old 11-08-2009, 3:36pm   #9
NEVRL8T
Activity: 0.5%
NEVRL8T's Avatar
I got the window regulator and motor assembly off the car but I cannot figure out how to get the motor from the regulator. There are three large rivets holding the motor to the regulator. I can drill two of them from the back with no problem but I cannot drill from the back on the third one. If I drill from the fron they have large caps. Here is what I am talking about:
Old 11-08-2009, 3:53pm   #10
Ocalaguy
Activity: 12.3%
Ocalaguy's Avatar
I would try putting a grinding wheel on a drill and grind it off or use a center punch and drill a small pilot hole then use a larger drill bit.
