Paint and Body Materials, Techniques, and How To's |
10-07-2009, 8:12am | #1 | ||||||
The Old Guy
Gameroom Barn Bucks: $804566
C5 Gas Filler Relocation
Unfortunately I didn't take any pics while I was doing this mod. It really was a spur of the moment type thing and I have about 3 hours tied up in the whole thing so far. As far as costs go I've got less than $20 in it not counting filler, glass, primer, etc.
Here's some pics I took after the fact and I'll try and walk you through what I did. I measured the bottom of the stock gas filler surround and found it to be about 4" in diameter. So, I knew I needed something about 4" in diameter to use for my custom fill mount. I found a piece of 4" thin wall PVC sewer/drain line and decided this would work for the collar. I then used a cutting wheel on the Dremel to cut out the bottom of the stock surround. I then cut a 6" piece of the 4" PVC pipe and beveled the inside of it on one end. I cleaned up the outer edge of the stock bottom piece I had cut out and glued this to the beveled end of the 4" PVC using Plastic Weld epoxy. I've used this epoxy before and have had good luck with it. I knew I had to keep the fill tube as high as possible in the door jam to maintain a downward angle on the fill line going into the tank. I drew a 4" circle on a piece of paper with a compass and cut out the circle to use as a template. I held this template up on the door jam and determined the location for the fill tube. I marked the center of this location with an awl through the center hole left by the compass point in the paper. Using this center mark as my guide I used a 4 1/4" hole saw tilted downward at about a 15 degree angle to cut through the SMC and into the steel framework. I cut into the steel as far as I could before the hole saw bottomed out. I used a cutting wheel on the Dremel then to complete this initial cut. Here's a couple of pics of the plug the first cut produced. I continued cutting and trimming with this 4 1/4" hole until I reached a depth of 2 1/2" on the horizontal centerline. This 2 1/2" depth was to allow for the gas cap height. I then beveled the the hole in the door jam. My next step was to cut two holes in the back wall of the framework to clear the filler neck assembly. I cut these two holes with a 2" hole saw and trimmed the opening as required with snips. After all of the cutting and fitting was done I put everyting together with 3M panel bonding adhesive and let dry overnight. The next day I cut the excess 4" pipe protruding into the door jam off with a cutting wheel on the Dremel. Sanded the pipe and the area around it smooth and filled with SMC filler. Here's a shot looking upwards showing some detail on how the filler neck assembly looks in place. And another shot looking down on the filler. I've added some vinyl edge trim to this cut opening since the pic was taken to help prevent any chafing that may occur. I added a pre-formed 90 degree hose to the fill line because the stock one wanted to kink up when I tried to connect it to the neck. Also had to relocate the screw for the ground strap. Here's a straight on shot. Index the mounting holes like this to keep the vent/return line lined up properly. I do hope this helps and makes things a little easier for you |
10-07-2009, 8:24am | #2 | ||||||
Barn Stall Owner #777
Gameroom Barn Bucks: $6589249
I just love this mod! You are the man.
10-07-2009, 8:27am | #3 | ||||||
Gameroom Barn Bucks: $802
So when can we start on mine
10-07-2009, 8:31am | #4 | ||||||
10-07-2009, 8:34am | #5 | ||||||
Gameroom Barn Bucks: $2827
I do like this location a lot better than the rear light idea initially considered.
2008 C6 Z06 |
10-07-2009, 1:03pm | #6 | ||||||
Sweeeet. :Thumbsup:
10-09-2009, 6:43pm | #7 | ||||||
I love this mod. Not only is it just plain cool as all get out, it also eliminates one more thing that can go bad.(fuel door opener)
Nice job Gary!
10-09-2009, 6:53pm | #8 | ||||||
Gameroom Barn Bucks: $27
Has to be one of ther most unique mods I have seen. Do you get the smell of gas in the cab after filling ot up ?
10-09-2009, 10:28pm | #9 | ||||||
Charter Member - Vendor
Gameroom Barn Bucks: $155
how many times do they walk around the car at a full service station looking for the gas tank
This is a really cood mod Gary Great Job |
11-02-2009, 11:50am | #10 | ||||||
Gameroom Barn Bucks: $590
That's a cool looking mod!
11-04-2009, 11:18pm | #11 | ||||||
Moderator
Gameroom Barn Bucks: $1297
Amazing.
11-06-2009, 10:32pm | #12 | ||||||
Gameroom Barn Bucks: $7813
11-11-2009, 6:23pm | #13 | ||||||
Gameroom Barn Bucks: $505
11-13-2009, 7:47pm | #14 | ||||||
The Old Guy
Not at all! The filler is located between the inner and outer door weatherstrips and has not created any problems with fumes and/or smell.
11-13-2009, 7:56pm | #15 | ||||||
11-14-2009, 9:26am | #16 | ||||||
Gameroom Barn Bucks: $1001113
Very Kool ! !
At first I thought that you were going through a taillight Bluezey
11-14-2009, 9:46am | #17 | ||||||
Sweet!
11-14-2009, 10:36am | #18 | ||||||
11-14-2009, 11:21am | #19 | ||||||
Gameroom Barn Bucks: $2154
nicely done shaved door handles and relocate this cleans it up nicely! adding it to the list!
~~Shawn~~ 2018 Z06 A8 |
01-26-2010, 10:06pm | #20 | |||||||
Great I dea... I would like to know how exactly did you shave the original.... |
