#1 | ||||||
Barn Stall Owner #11
Barn Raising I,II,III NCM Supporter '11 ![]()
Gameroom Barn Bucks: $1011172
ok this should be simple but it's kicking my rear, how the heack do i pull out the interior light bulbs, i can't seem to grip them with my fingers and I bought led replacements, tyi
#2 | ||||||
C6 Modulator Barn Stall Owner #27 Barn Raising I,II NCM Supporter '13,'14,'15 Bantayan Kids '13 ![]()
Good question? So I went out to see if i could get mine to come out. No joy. Did not want to pull on them to hard, as I would have to go get replacements. I thinking maybe a special puller tool maybe.
![]() Even went to the Online Chilton Manual. Nothing. Dam. |
#3 | ||||||
I talked to the vendor I bought them from and he said the easiest way was to loop dental floss around them. Off to dental
#4 | ||||||
Dental floss, hun! Let me know if it works.
#5 | ||||||
Dental floss totaly sux, worked with for about 30 minutes on one of the map light bulbs and nothing, tryed fishing line too, same results. Looked around and found a roll of 2" 3m masking tape, ended up wraping the bulb with that and it poped right out. Was a little cramped from spending that much time in the front of the car so i went to the back, used a set of gloves and poped those out and in, overall if i had used tape in the first place, probably could have done the whole car in under 15 minutes. Here's a few pic's..
Front Map lights ![]() Rear cargo lights ![]() ![]() Gloves and wraped up bulb ![]() hope this saves someone a little headache ![]() |
The Following User Says Thank You to navyndi2 For This Useful Post: |
#6 | ||||||
NCM Supporter '11
Gameroom Barn Bucks: $2529650
I have a small pair of needle nose vice grips with the tips wrapped in tape. Adjust the size of the pliers to the bulb size so you do not crush it.
Lemme look for a picture. |
The Following User Says Thank You to Omega Man For This Useful Post: |
#7 | ||||||
NCM Supporter '11
Check it:
[IMG] ![]() Make sure you do not crush the bulb. The pliers i have in the picture are fully closed with the jaws already adjusted. hope this helps. ![]() |
#8 | ||||||
That would have worked, but I let someone borrow mine a few days ago and they have yet to return them. Now for the covers under the dash and hood do they pop off with a micro srcrewdriver?
#9 | ||||||
NCM Supporter '11
Yes, that will work fine. Just don't force them. That is how I did it.
#10 | ||||||
chit, broke the under hood led and cause it didn't light, and i can't seem to get the under dash light covers off what's the trick?
#11 | ||||||
Barn Stall Owner #28
Gameroom Barn Bucks: $1346307
We just replaced the interior bulbs with LED's. Example,the rear-view mirror bulbs: I used a rubber hose that had a slightly smaller inside diameter than the outside diameter of the bulb. I slid the hose over the bulb and the bulb came right out.
![]() Last edited by Superstreet; 01-11-2011 at 2:30pm. Reason: Typo |
#12 | ||||||
Gameroom Barn Bucks: $510
Seems to be a lot of work to get these bulbs out. What is the purpose?
Also does anyone no how to get info on the barn building event in may? |
#13 | ||||||
![]() ![]() Also does anyone no how to get info on the barn building event in may? |
#14 | |||||||
![]() Quote:
![]() Barn Raising II event be held at NCM in Bowling Green Kentucky from the 24 to 27 of May. More info can be found here. ![]() https://www.thevettebarn.com/forums/o...i-details.html https://www.thevettebarn.com/forums/o...-br-ii-go.html |
#15 | ||||||
#16 | ||||||
NCM Supporter '12,'13,'14,'15,'17 ![]()
I didn't know these things were so hard to get out.Guess they will never fall out.
#17 | ||||||
have you tried using the little fuse puller that is in the fuse box ?
#18 | ||||||
Hello all please let me know that where can you buy interior lights for cars ? and can all cars have them ? I have a 2003 Oldsmobile alero and looking for your ideas,.
Metal Recyclers Brisbane Last edited by flemingz; 12-23-2013 at 4:33am. |
#19 | ||||||
Have you checked at O'Reilly's or AutoZone or an online part store? I'm sure they have replacement lights and bulb. If not a dealer should have them.
If your adding more interior lights, you might need to take in to consideration the additional battery draw and plan that in to the mod. |
#20 | ||||||
I just took my foot well lights out to replace them with LED lights and I didn't have that much trouble ,guess I have a good grip.
