11-17-2010, 8:13pm | #1 | ||||||
Detailing Guru
Gameroom Barn Bucks: $950
The Junkman Battles Another Keyed Paint Job
Hey boys and girls, I had the opportunity to go at another keyed paint job this week. As a lot of you already know, fixing paint is a passion for me and not something I do for money. So when the owner asked me what I wanted in return, I told him nothing but some pictures and food. He decided that was not good enough and bought me this setup:
It's the Samsung HT-BD1250 Blu-ray DVD player and 5.1 HD audio with wireless speaker setup. I have to say that this beats Outback Steakhouse since I didn't have anything to go with my new 46" LED wide screen I just bought. I also needed a Blu-ray player as I hadn't bought one yet! On to the repair. This scratch was too deep in places to totally remove but in situations like this, you try and make the damage as least noticeable as possible. At first glance, you would not be able to see the fixed product. That's what you want to achieve with damage like this. Here's the damage and it was not pretty. The scratch went from the front fender to almost the rear quarter. As you can see, this puppy was deep. I was going to have to start with 2000 grit paper for this scratch. This posed two problems. One, I cannot use the PC-7424XP to repair 2000 grit wet sanding damage (it is not powerful enough and would take forever). I would need to use my Flex 3401VRG polisher in this case. Two, this is a new Toyota, which is notorious for having some of the thinnest clear coat on the planet (the same with Nissan's). In a situation like this, you have got to use a paint thickness gauge that measures both base coat AND clear coat. I didn't have one handy and was going to opt out of trying to fix this but the owner insisted that I go at it, even after I warned him of the danger. That scratch was bothering him so bad that anything would be better in his mind. So, at it I went. I started by claying the entire area as claying is the foundation of my shine. Another reason that I clayed the area is because the owner had used some Meguiar's ScratchX on the scratch in an attempt to repair the damage himself and I didn't want anything in that scratch that would affect my repair attempt. The only thing he managed to do was make the paint dull around the scratch. Once the area was clayed, I started with 2000 grit paper. When doing a repair like this where you are NOT going to be painting the car, you have got to know when to stop sanding. You do not necessarily totally remove the scratch. In most cases you won't, especially on clear coat that is as thin as it is on these cars. After the 2000 grit, I followed it with the 2500 and then 3000 grit papers. Again, you have got to take into consideration that these papers are also going to remove clear coat so if you remove too much with the 2000 grit paper, you've screwed the pooch. That's why a paint thickness gauge is so important. At a body shop where they are going to paint the car anyway, a paint thickness gauge is a waste of time and not necessary. Here's some shots of the sanding process. Once I completed wet sanding the damage, I broke out my Flex polisher, some Swirl and Haze Remover and a orange pad. After buffing all the damage away with that combination, I followed it with some Fine Machine Polish and a white pad. After that combination, these were the results that I was able to achieve. So as you can see, I earned my keep and this is probably why the owner was so happy. Now I need to go setup my new gear and hear what it sounds like! The Junkman
"Marines - Making the other guy die for his country for over 200 years." |
The Following User Says Thank You to Junkman2008 For This Useful Post: |
11-17-2010, 8:34pm | #2 | ||||||
Gameroom Barn Bucks: $7813
Incredible results as always! Great Job, wish you lived closer I need some touch ups! Enjoy your new Bluray 5.1 set up!!
11-18-2010, 8:08am | #3 | ||||||
CONGRATULATIONS JUNKMAN!!!!!!
You have just won an all expense paid trip to beautiful Haymarket, VA. Home of the Piedmont Golf and Country Club. When there is nothing else to do....you can do a complete paint detailing on a hot Arctic White vert. |
11-18-2010, 9:40am | #4 | ||||||
Most impressive. They should call you "It used to be junk before I worked my majic on it" Man.
11-18-2010, 12:13pm | #5 | |||||||
Detailing Guru
You guys are a riot!
11-20-2010, 10:16am | #6 | ||||||
Gameroom Barn Bucks: $1284
man that is unbelievable, that is a awesome job that you did on the repair.
11-21-2010, 12:02pm | #7 | ||||||
Detailing Guru
Thank you gents!
12-02-2010, 4:33am | #8 | ||||||
Nice job there AJ, as always.
Just out of curiosity, since you were gonna be wetsanding the area anyway, why didn't you fill the scratch with clearcoat first? If the scratch isn't down into the color, I've had good success by masking it off, filling the scratch until the fill is above the original clear, then wetsanding and polishing, as you did. Takes a lot more time, as I let the clear cure for 48 hours before I hit it with the paper and polish.
12-02-2010, 10:51am | #9 | ||||||
Detailing Guru
Bingo! You nailed it. The way you described would be a better route to go but no one wants to give me their car for that long. I mean, I wouldn't even worry about a scratch in some of the cars I've fixed!
01-05-2011, 11:17am | #10 | ||||||
Gameroom Barn Bucks: $755
First class job there and great results !
01-05-2011, 12:59pm | #11 | ||||||
Detailing Guru
Thanks Mojo.
01-16-2011, 11:03pm | #12 | ||||||
Barn Stall Owner #58
Gameroom Barn Bucks: $13154
That is real impressive scratch repair and looks better than new
01-16-2011, 11:42pm | #13 | ||||||
Detailing Guru
01-25-2011, 7:21pm | #14 | ||||||
Barn Stall Owner #25
Wow! That is really nice.
01-27-2011, 4:02pm | #15 | ||||||
Barn Stall Owner #31
Gameroom Barn Bucks: $73231
Nice job, JM. Got a friend that swears by your videos and instructions. And he has some spectacular cars.
01-27-2011, 9:47pm | #16 | |||||||
Detailing Guru
I'll be hitting the road this year again to show folks in person exactly how I do this stuff. I'll post my destinations here and maybe I hit an area next to you guys. |
01-28-2011, 1:32pm | #17 | |||||||
And, if you'd wanna show everyone beautiful you could make my car... |
01-29-2011, 3:00am | #18 | ||||||
Detailing Guru
