Old 03-18-2010, 9:06pm   #1
thegreenman
Points: 15,494, Level: 85
thegreenman's Avatar
Default Minor Mods
I completed a few minor mods, here is some pics. Custom made LS3 Supercharged badges, GM splash guards for the front (already had the rears), changed brake pads to ceramic, painted the brake calibers and added race mesh inserts for the widebooty QTRs.
Old 03-18-2010, 9:22pm   #2
Lookin sharp The RatPack sticker is a nice touch.
Old 03-18-2010, 9:34pm   #3
thegreenman
Thanks, I needed the RatPack patch to look different from all of the other black Vettes around here.
Next mod post coming soon.
GB fever is spreading.
I need to find a better place to take some pictures.
Old 03-19-2010, 7:22am   #4
tomurphjr
Points: 11,312, Level: 73
tomurphjr's Avatar
Gameroom Barn Bucks: $2689
Nice touches Jeff! The red calipers really sets the black off.
tomurphjr is offline   Reply With Quote
Old 03-19-2010, 8:21am   #5
Calipers look great... what method did you use to paint them?
Old 03-19-2010, 8:48am   #6
AS1Gonzo
Points: 2,916, Level: 35
AS1Gonzo's Avatar
Gameroom Barn Bucks: $5
I like that LS3 supercharged badge, thats pretty sweet
Black on Black on Black C6
AS1Gonzo is offline   Reply With Quote
Old 03-19-2010, 10:25am   #7
thegreenman
I just sprayed with cleaner, wire brush on the drill with some more sprayed cleaner. Calipers were pretty clean, only had to remove brake dust. Brushed on Duplicolor P/N BCP400. The paint is brittle, I had to touchup already, maybe next year I will have them powder coated for more durability.
I had them custom made by Austin Barnett, [email protected], great guy to deal with.
Old 03-19-2010, 10:50am   #8
Wow so that's all brushed on... can yousee brush marks up close? Did you remove the caliper at all?
Did you use brake-clean? If so it is really bad for paint... best to wipe parts with acetone (after you used brake-cleaner) before painting.
Old 03-19-2010, 11:46am   #9
Vet4jdc
Barn Stall Owner #78
Points: 19,383, Level: 96
Vet4jdc's Avatar
Gameroom Barn Bucks: $1004569
Looks good Jeff! Like the splash guards!
Old 03-19-2010, 12:28pm   #10
thegreenman
I used brake cleaner to wash off the dust, wire brush then paint thinner to clean it up. I used the 1" sponge as my brush. I put some chap stick on the Corvette and the paint came off it easy with a razor blade. I put three coats on it one afternoon, let it sit overnight and put another coat on it in the morning.
I decided to go with the GM OEM splash guards.
Old 03-19-2010, 12:53pm   #11
Peter Pan
Barn Stall Owner #58
Points: 9,221, Level: 66
Peter Pan's Avatar
Gameroom Barn Bucks: $13154
Nice mods and those calipers sure do look good
Old 03-19-2010, 1:29pm   #12
wwomanC6
C6 Modulator
Barn Stall Owner #27
NCM Supporter '13,'14,'15
Points: 77,846, Level: 100
Activity: 51.5%
wwomanC6's Avatar
Did you put a clear coat on it?
Old 03-19-2010, 7:34pm   #13
Garb55
Points: 17,083, Level: 90
Garb55's Avatar
Gameroom Barn Bucks: $7813
Looks Sharp, how do you like the Michelin Tires? Are those Stock rims? I see you are running 345/30 in the rear.
Old 03-19-2010, 7:52pm   #14
thegreenman
No, they glossed up as the paint dried. Actually, it turned out better than I expected.
Thanks, I like the Michelin PS2s much better than the GY runflats. No, not stock rims, custom order Z06 reproductions for the offsets I needed (I like to look of the Z06 wheels). With the SC I needed bigger tires on the rear and installed installed a widebooty kit (all GM Z06 parts) to be able to get the 345's on, still have no problem lighten up the 345's but i need to upgrade the drive train before getting stickier tires.
Old 03-20-2010, 7:27am   #15
tomurphjr
tomurphjr's Avatar
Jeff,
I had a local guy power coat mine. They turned out great! Let me know if you decide to go that route and I'll give you his contact info.
The Following User Says Thank You to tomurphjr For This Useful Post:
Old 03-20-2010, 9:10am   #16
thegreenman
Thanks Tom, I am hoping the paint will hold up for the summer, I think it would be a good winter project for next year.
Old 03-21-2010, 12:47pm   #17
MAJ Z06
Points: 2,122, Level: 29
MAJ Z06's Avatar
Gameroom Barn Bucks: $1474
Looks damn good.
MAJ Z06 is offline   Reply With Quote
Old 03-31-2010, 7:29pm   #18
GotChrist?
Points: 1,616, Level: 24
GotChrist?'s Avatar
Gameroom Barn Bucks: $645
R_____________i_______________d_______________e
GotChrist? is offline   Reply With Quote
Old 03-31-2010, 7:36pm   #19
thegreenman
About time you showed up over here.
Old 04-01-2010, 7:36am   #20
GotChrist?
GotChrist?'s Avatar
I be slow like that. Just found out about this site after you guys posted of a local forum over on da udder forum. Dad called me Moon. He wanted to call me sun (son) but I wasn't that bright.
