09-30-2011, 7:21am | #1 | ||||||
Barn Raising III
Gameroom Barn Bucks: $10070941
insulation in a furnace room..
Fire hazard or no?
09-30-2011, 7:34am | #2 | ||||||
Barn Stall Owner #25
They make a fire-proof insulation. http://www.airkrete.com/
http://www.airkrete.com/trailer/Insi...ons/index.html |
09-30-2011, 7:47am | #3 | ||||||
Yep, and it works well.
09-30-2011, 8:05am | #4 | ||||||
Barn Raising III
They sell it in rolls?
09-30-2011, 8:07am | #5 | ||||||
09-30-2011, 8:15am | #6 | ||||||
Barn Raising III
09-30-2011, 8:24am | #7 | ||||||
Even you have an oil or gas fired air handler/furnace...
insulating the walls/ceiling of the "furnace room" is OK. Matter of fact, I recommend it for both sound & efficiency. If you are concerned about combustionables...drywall the walls over the insulation. |
09-30-2011, 8:33am | #8 | |||||||
Barn Raising III
09-30-2011, 6:45pm | #9 | ||||||
Barn Stall Owner #0
Gameroom Barn Bucks: $1576624
Usually, not a problem
Most modern furnaces need very little clearance. How old of a unit is it? Do you have a clothes dryer nearby? |
09-30-2011, 6:57pm | #10 | ||||||
Barn Raising III
Already insulated earlier today.
09-30-2011, 7:00pm | #11 | ||||||
Barn Stall Owner #0
OK, question still stands, here is why.
The drier running all by itself may pull enough air out of that room to backdraft the water heater and furnace. Leaving the door open may prevent that, but then you are pulling air out of the house. Keep in mind that a drier that exhausts 150 CFM of air(very conservative), will cause 3/4 of an air change in a 1500 sq ft house, with 8" ceilings, all by itself for every hour it runs. For every 1 CFM of air that is pulled out of the house, 1 CFM of outside air infiltrates into the house. The air that is pulled out of the house is conditioned air, the air that infiltrates in is unconditioned outdoor air, or worse, is coming from the attic, wall cavities, crawl space, etc.. |
09-30-2011, 7:07pm | #12 | ||||||
Barn Raising III
That room is just the downstairs furnace and water heater.
Washer/Drier is in a closet on another floor. |
09-30-2011, 8:30pm | #13 | ||||||
NCM Supporter '11
Gameroom Barn Bucks: $2529650
I would search for Holmes on Homes. That earring having Canadian hoser knows some shit.
09-30-2011, 8:35pm | #14 | ||||||
SnowJob
Gameroom Barn Bucks: $8052038
Here it's a minimum 3' clearance on new construction and you must use fire rated drywall.
Stuff the wall cavities with Roxul Safe and Sound(Fire resistant) and then drywall over top. If the sound is coming more from the ceiling, wrap any ducts with sound and fire rated insulation and spray foam all holes around registers or pipes. Also solid core wood doors work great for stopping sound especially when you add a weatherseal to the inside edge. There are also sound rated doors that are filled with insulation but in my experience don't work as well. |
