Old 02-27-2010, 5:44pm   #1
Garb55
Points: 17,083, Level: 90
Garb55's Avatar
Gameroom Barn Bucks: $7813
Default Replacement Radiator
After replacing hoses I still have a leak. After further investigation it looks as if the leak is a little above the lower hose on the radiator side. Hard to tell as there is a lot of plastic and the electric fan hosing, need to remove as much as I can to get a better look. I noticed a lot of steam and coolant is in that area.
Has anyone replaced there radiator? Is this something I should take and have some one do? I'm not afraid to do just do not want to get in over my head if it is complicated or tricky.
Old 02-27-2010, 6:48pm   #2
Not a huge project. I think you can handle it. Are you replacing the radiator or having it repaired?
Old 02-27-2010, 7:39pm   #3
Garb55
Garb55's Avatar
Well I could not wait I pulled it. It was very easy. I will replace it.. Thanks for the reply Munch. Suggestions on a good place to get a new one?
Old 02-27-2010, 10:01pm   #4
Can't go wrong with a DeWitts radiator but they aren't cheap. Could check GM Parts House for factory replacement.
Old 02-27-2010, 10:06pm   #5
Garb55
Garb55's Avatar
Thanks Munch! I will check around. I need to have this one checked to be certain it is the issue before I slap down the Green bucks!! I have a good feeling this is the issue..
Old 02-28-2010, 2:50am   #6
thegreenman
Points: 15,494, Level: 85
thegreenman's Avatar
I upgraded to DeWitts, quality radiator, direct fit just as advertised.
Old 03-03-2010, 11:34am   #7
Peter Pan
Barn Stall Owner #58
Points: 9,221, Level: 66
Peter Pan's Avatar
Gameroom Barn Bucks: $13154
I have had a DeWitts in my boosted C5 going on 5 years now and it is a direct fit. They now have two versions a shorter one for the boosted crowd and the one I have. We lowered mine a tad to make it fit, you can not go wrong with this radiator if you plan on modding, otherwise it is probably more than you will need
Old 03-03-2010, 12:51pm   #8
FRC Joe
Points: 4,203, Level: 43
FRC Joe's Avatar
Gameroom Barn Bucks: $882
I bought a slightly beefed up radiator from A&A corvette. Looking at their site I dont see it listed anymore though. It uses the stock end tanks and an about half again thicker core. It was $250 or thereabouts IIRC and is a direct fit. Here's a pic showing the difference in core thickness. If interested you should call A&A, they may still have it avaialble and just not listed on their new site.
99 FRC - A&A T-Trim @ 10PSI
The Following User Says Thank You to FRC Joe For This Useful Post:
Old 03-04-2010, 6:18pm   #9
Garb55
Garb55's Avatar
Wish you would have posted that One earlier, I like it. I went back with stock. Installed and back on the road.
Old 03-04-2010, 9:39pm   #10
Garb55
Garb55's Avatar
Is that the one for an automatic? Is the brass fitting for the trans cooler?
Old 03-04-2010, 9:52pm   #11
FRC Joe
FRC Joe's Avatar
Yes, IIRC that's the only way it came. I might eventually run the PS line through it.
Old 03-07-2010, 7:54pm   #12
Garb55
Garb55's Avatar
New Radiator in and ready to roll! Thank you for the replies, wish I would have seen FRC Joe post earlier.
Old 03-07-2010, 9:00pm   #13
Glad ya got it back on the road!
Old 03-09-2010, 9:35pm   #14
Garb55
Garb55's Avatar
Me2.
