Old 02-02-2010, 3:26pm   #1
Default 2001+ LS1 get the LS6 clutch?
Here's the info I found... but does anyone know if the LS1 and LS6 clutch were one in the same?
2001 Changes
  • return to 28# injectors for all models.
  • Second Generation Active Handling
  • Nassau Blue discontinued
  • Alternator 'clutch' pulley added on A4 cars
  • New soundproofing + foam in all cars
  • Smaller keyfob
  • electrochromic dimming rearview and driver's mirrors
  • lighter AGM battery
  • Thickness + Material in vert change
  • Chrome exhaust tips for coupe + vert
  • 85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT)
  • LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From: 0.472/0.479, 202/210 on 117)
  • All Corvettes now have the LS6 intake manifold
  • All Corvettes now have the LS6 engine block (windage passages in block), which includes a beefier oil pump.
  • LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6)
  • Hardtop/FRC discontinued - Evolved into Z06 model
  • Pup cats added to all models
  • Stronger synchros in all transmissions
  • Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS manifolds
    metal valvestem caps (late year)
  • Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in dia from 55 to 63 mm.
  • Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability
