Old 12-20-2009, 9:02am   #1
edcmat-l1
Charter Member - Vendor
Points: 3,014, Level: 35
edcmat-l1's Avatar
Gameroom Barn Bucks: $1080
Default Tuning Q & A?
Anyone wanna start a tuning Q & A? Maybe make it a sticky?
Old 12-21-2009, 5:55pm   #2
I'm up for it. I could ask at least a dozen questions off the top of my head.
Old 12-21-2009, 7:12pm   #3
Points: 35,055, Level: 100
So ask.
Old 12-21-2009, 8:19pm   #4
71corv
Points: 7,200, Level: 59
71corv's Avatar
Gameroom Barn Bucks: $1383
I'll start with a question for Ed. Had my Z06 dynoed last March when you were in Portsmouth(?) I think. Tracked the car 4 or 5 times this year with no apparent problems (miss,etc). Do I need to have several pulls made to check if all the settings are still the same or if there is a problem? Thanks,
Gene
Old 12-22-2009, 10:56am   #5
edcmat-l1
edcmat-l1's Avatar
Gene
No, tune won't change. I do some things that keep them very stable. I've had guys come back 6-8 months after a tune, and put down virtually the same numbers as when they were tuned. Had a maggie GTO customer, who a year after being tuned, made within 2 HP. That was at 530 rwhp. 2 hp difference is well within % error.
Had a C6 LS2 that made exactly, almost to the hundredth of a HP, 6 months after be tuned.
Old 12-22-2009, 10:57am   #6
edcmat-l1
edcmat-l1's Avatar
Shoot........
Old 12-22-2009, 6:00pm   #7
Is a tune still necessary when adding a nitrous system using a controller such as "The Interface" by Harris? And if so, what's involved?
Old 12-22-2009, 8:42pm   #8
71corv
71corv's Avatar
Thanks for the info, Ed. As I've posted before, the car pulls like crazy coming off all the turns whether in 2nd or 3rd gear. Surprises a lot of people.
Gene
Old 12-22-2009, 10:03pm   #9
edcmat-l1
edcmat-l1's Avatar
I don't know exactly what that one does.
I would always recommend at least having a car dynoed after installing a nitrous system. Sometimes these cars are pretty lean to begin with (esp after a header install) so combine that with maybe a dirty MAF, a build up of carbon in the chambers, and it could be a bad situation. At least checking it on a dyno will let you know where you're at A/F wise.
Old 12-25-2009, 9:51am   #10
What exactly does the torque management do on the A4 cars? I know you told me mine was turned off when you tuned my car but I'd like to know what exactly it did and what benefit comes from turning it off.
Thanks
Old 12-26-2009, 7:38pm   #11
edcmat-l1
edcmat-l1's Avatar
Thanks
It uses either timing or ETC to decrease the amount of power the engine is making, right before, and during an upshift. It is supposed to help the trans live (that's what everyone says) but I tend to believe it is more for comfort. The engineers don't want customers coming in complaining about harsh shifts.
Turning it off, or decreasing it substantially, makes the trans shift quicker, more firmly, and lessens the time the clutch packs are slipping, which some trans builders say is better for the trans than the slow gradual shifts which tend to let the clutch packs and bands spend more time partially engaged and slipping.
Old 12-26-2009, 9:46pm   #12
Vet4jdc
Barn Stall Owner #78
Points: 19,383, Level: 96
Vet4jdc's Avatar
Gameroom Barn Bucks: $1004569
So Ed....if you have an A4 and simply want a little more agressive shift but don't plan on going out and drag racing with it, which would you recommend?
For the average daily driver, would you simply decrease it or turn it off completely?
What is the approximate cost to bring it by Va Speed and have this procedure done? (I live and work in Va Beach)
Old 12-27-2009, 8:34pm   #13
edcmat-l1
edcmat-l1's Avatar
It depends on several factors. First is how it responds to certain settings. Some respond better than others. Also depends on how aggressive the owner wants it.
I usually start with about 50% decrease in TM, along with shift adjustments.
As for cost, it's 400 for a dyno tune for a bolt on car.
Old 12-27-2009, 8:34pm   #14
In regards to wideband sensors... It seems to me (who knows very little) that you would need 2, 1 for each bank. Would running one on each side be overkill or ideal and why?
Old 12-27-2009, 9:09pm   #15
Eagleeye
Points: 10,779, Level: 71
Eagleeye's Avatar
Gameroom Barn Bucks: $2288
Have an '01Z with 40,ooo miles. Only non stock item is Halltech CAI. Runs smooth but han never had a "tune". Just installed new MSD wires and NGK plugs. I live between Richmond and Williamsburg Virginia...Recommended Tuner ?
Old 12-27-2009, 9:14pm   #16
Vet4jdc
Vet4jdc's Avatar
see Ed at Virginia Speed
Old 12-28-2009, 7:48am   #17
edcmat-l1
edcmat-l1's Avatar
Me, of course LOL
Old 12-30-2009, 8:55am   #18
Vet4jdc
Vet4jdc's Avatar
I would love to do it but with my current pay scale and the SO not working, I just don't have an extra $400 laying around to make my tranny shift a little nicer?
Old 12-30-2009, 7:43pm   #19
Eagleeye
Eagleeye's Avatar
Ed... PM sent
Old 12-31-2009, 9:14am   #20
edcmat-l1
edcmat-l1's Avatar
Hope you find something soon. I'm sure you have much more important things to worry about rather than tuning.
Ed... PM sent
Email sent.........
