05-02-2024, 4:20pm | #1 | ||||||
Can I solder in a refrigerator compressor myself?
I know nothing specific about this. It appears I may lose battle to replace a bad fridge. See Other Forum for that.
Not sure yet that it needs a compressor. Will try just tapping into low pressure line and adding some R134a first. I bought a gadget on Amazon for this. In case this doesn't work, I can buy a new compressor for less than $400. Can I just solder this in with a propane torch and no-lead solder? I do not have oxy-acetylene and have no plans (yet) to go to this level. What else do I need to know? Does the system need to be evacuated? Are there actually some kind of mechanical compression fittings or similar that would be preferrable? I'm counting on VB to be smarter than that other place for do-it-yourself. Those other pansies just call The Man and bend over. |
05-02-2024, 4:23pm | #2 | ||||||
Run up to home depot and get a hard start capacitor first for ten bucks. If the compressor is starting look at the thermostat or one of the coil fans.
The Following 2 Users Say Thank You to Big bob For This Useful Post: |
05-02-2024, 4:25pm | #3 | ||||||
Gameroom Barn Bucks: $2149
no problem, my ex-wives have done it several times just by watching Youtube videos
05-02-2024, 4:26pm | #4 | |||||||
The compressor is apparently running because it's cooling the top fridge half fairly well. It will not freeze ice cream anymore. Or freeze anything, for that matter. So I would not need the capacitor, yes/no? |
05-02-2024, 4:28pm | #5 | |||||||
One will be be the on compressor. The other one I have replace was behind the inside back wall of the freezer. That would be my best guess. It is not working so the coils are icing up and not defrosting and not cooling properly. |
05-02-2024, 4:30pm | #6 | |||||||
Service was out 3.5 times and failed to fix. I would think they looked at fans. On site service and KitchenAid help were yapping as my wifey overheard, and she reported Help basically said yer Fd. That sounds like a compressor or leak to me. |
05-02-2024, 4:33pm | #7 | ||||||
https://www.kitchenaidparts.com/Part...248595/2310607
I looked into Parts for Thermostat and came up with this: |
05-02-2024, 4:37pm | #8 | |||||||
You would think so and might be right. But it won't cost anything to pull the back off from the inside and see. |
05-02-2024, 4:39pm | #9 | ||||||
Buy a new ice box!
The Following User Says Thank You to DDSLT5 For This Useful Post: |
05-02-2024, 4:39pm | #10 | ||||||
You should braze instead. Propane and oxygen.
I repaired a water dispenser / ice machine by brazing, but it has not been recharged yet. Information on charging is pretty sparse. Not like home AC or car AC. |
05-02-2024, 4:40pm | #11 | |||||||
Air damper not it. |
05-02-2024, 4:40pm | #12 | ||||||
While we're at it, original problem was no ice. Service allegedly replaced the ice maker, but still no ice. To my estimation, this is actually unrelated to the freezer yes/no? I plan to take out the ice maker and re-install and see what may have been overlooked. If I can't find anything, a new ice maker is only $100-150.
05-02-2024, 4:44pm | #13 | |||||||
If it is not freezing your ice cream it is not going to freeze ice. |
05-02-2024, 4:44pm | #14 | ||||||
05-02-2024, 5:06pm | #15 | ||||||
Gameroom Barn Bucks: $2001216
Ha…. My tenant called two days ago, the fridge took a dump. I sent her out shopping, new ones ordered paid for waiting for delivery….
05-02-2024, 5:30pm | #16 | |||||||
Some of us still have our balls and try to fix things even if we can afford to buy two new ones. things that is, not balls. Also, wifey is not going to settle for anything less than $4k plus at the big box stores. |
05-02-2024, 5:42pm | #17 | |||||||
I have fixed many most are less than 20 bucks. One was over a hundred for a control board that was not needed but still have, . The last one was the fan that I have you checking. I flicked it and lubed it up. It is still working with the back still off. It is on back order and time to move to the summer house coming up. I have yet to see a compressor go bad or loss of freon. |
05-02-2024, 6:00pm | #18 | |||||||
I have huge balls! Tremendous some women have said! The refrigerator being replaced is 12 years old and never were we satisfied with its performance. In addition, the tax write off for the improvements to my rental property are welcomed. But if you’re welcome, you can have the old piece of junk thrown away. But I do agree most appliances Are quite easy to repair. I just don’t feel like taking the time screw it. |
05-02-2024, 6:05pm | #19 | |||||||
05-02-2024, 6:11pm | #20 | ||||||
First things first- clean the condenser fins. Make sure the fan that draws air past them is working.
