03-22-2023, 4:15pm | #1 | ||||||
Computer Geeks step inside
Need to copy an Intel 8051 microcontroller. I have a known good to copy.
Plan on using pickit 3 unless you know of something better. Any software you recommend? Used to have a guy but he moved damnit. It's for a circa 1986 system that has long been obsolete and parts are not to be found. Thanks in advance and here's the required eye candy. |
The Following 4 Users Say Thank You to Rodnok1 For This Useful Post: |
03-22-2023, 4:31pm | #2 | ||||||
Senior Lurker
Barn Stall Owner #95
Gameroom Barn Bucks: $750520
Might want to change the title to 'REALLY OLD Computer Geeks step inside'.
Before my IT time started. |
The Following User Says Thank You to cptlo306 For This Useful Post: |
03-22-2023, 5:07pm | #3 | ||||||
What.. I thought everyone had used computers without a mouse or fancy icons.
03-22-2023, 6:29pm | #4 | ||||||
Barn Stall Owner #THX1138
Gameroom Barn Bucks: $1322
There are modern derivatives, use one of them.
03-22-2023, 6:44pm | #5 | ||||||
03-22-2023, 6:48pm | #6 | ||||||
Gameroom Barn Bucks: $1002182
What was the question?
03-22-2023, 6:51pm | #7 | ||||||
I have ordered replacement chips.. They have to be copied from a good chip.
It's not a plug n play or replace with something newer senario. |
03-23-2023, 6:41am | #8 | ||||||
I go back to the 8088 days - what in the world are you doing ? Resurrecting an old system could only be justified IMO, if your 10 million dollar Bitcoin wallet key was trapped on it Not likely.
03-23-2023, 7:09am | #9 | ||||||
Breadboarded one of those in college into an elevator control/logic circuit. I think probably the word "software" wasn't created yet. There weren't programs for personal computers to buy in stores, had to write your own.
03-23-2023, 7:51am | #10 | |||||||
OP - sorry, I don't know much about them and can't be of much help, but I'd like to see the project if you're able to share. Understood if you can't. |
The Following User Says Thank You to CurtP For This Useful Post: |
03-23-2023, 8:30am | #11 | ||||||
Correct it's an ancient system still being used I have a a ton of hours in getting working again(and way too much money) and zero replacement parts can be found without buying the whole system.
I'll post up what I can when chips arrive. |
03-23-2023, 11:18am | #12 | |||||||
Obsolescence is a bitch. Best option: Port the code to run natively on a modern micro. Second best option: Rehost the code on a modern micro with an 8051 emulator. |
03-23-2023, 11:25am | #13 | ||||||
Maybe, but if its in assembly language and not Fortran or the like that would not be trivial...
03-23-2023, 12:41pm | #14 | ||||||
03-23-2023, 1:09pm | #15 | |||||||
Plus if I'm able to do it I may be able to help others out that have same setup. |
03-23-2023, 6:05pm | #16 | ||||||
03-23-2023, 6:36pm | #17 | ||||||
