11-28-2020, 1:13pm | #1 | ||||||
Anyone have media blaster knowledge?
I am wanting to start serious work on my Charger and I'm looking for a functional media blaster. I want to use either walnut or soda with the option for either.
I don't want to spend all my money on tools and have none left for the car. Can a decent (functional with minimal downside) solution be had for around $300.00? (Excluding the actual blast media) Is this something I could trust to Northern Tool or Harbor Freight? |
11-28-2020, 1:17pm | #2 | ||||||
MY only comment is I"m tired of listening to the blasted media......
The Following 5 Users Say Thank You to mrvette For This Useful Post: |
11-28-2020, 1:24pm | #3 | ||||||
Whatever you get, get a pressure blaster unless doing just small parts. Worth the extra cash.
They're fairly simple so HF style should be fine. |
11-28-2020, 2:36pm | #4 | ||||||
11-28-2020, 3:17pm | #5 | ||||||
Yes... Gravity fed are ok but not if going to use a decent amount. They're a siphon type actually. The pressure pot units get a better consistent amount. If go siphon type you'll need to replace the hose most likely as they suck and are thin. Plus you can put a slightly longer hose on. Plus side is siphon style are cheap. The dust sucks either way so use a respirator of some type.
11-28-2020, 3:51pm | #6 | ||||||
Blasting whole cars requires A LOT of air. Even blasting cabinets need more than "inexpensive" compressors can supply for more than a few minutes at a time. If you intend to blast fenders, doors, subframes etc, I recommend you sub that out especially if your workspace is in a residential area as the process is both noisy and dusty enough to seriously annoy the neighbors.
11-28-2020, 4:21pm | #7 | |||||||
I want to do mostly small parts. Door hinges, Engine compartment accessories and mounting points, control arms, etc. Body panels will only be spot work, not whole panels. That would be a job for pros. |
11-28-2020, 4:23pm | #8 | ||||||
Spring for a cabinet set up and a small siphon gun then. It will contain much of the mess and dust, plus you get to recycle the media.
11-28-2020, 4:42pm | #9 | ||||||
Does require a ton of air, i have a cabinet now as doing more the last few years, mainly to recover the media plus bending over sucks when get old(so I've heard). For what you want to do a siphon would be good. Soda blasting triple the mess... Check Craigslist for a used setup.
11-28-2020, 5:53pm | #10 | ||||||
Are you trying to get rid of rust, paint, grease or all of it? There are other methods vs blasting.
Markids77 is right. They use a ton of air. You really need a 2-stage compressor, with large tank or you will the compressor will be playing catch up during the entire process. |
11-28-2020, 6:24pm | #11 | |||||||
My compressor is a 4hp 25 gallon, 125psi. |
11-28-2020, 10:04pm | #12 | |||||||
11-29-2020, 1:44am | #13 | |||||||
Craftsman 919.152921 |
11-29-2020, 6:36am | #14 | ||||||
Barn Stall Owner #45
Gameroom Barn Bucks: $1021454
Saw a pic of one for sale on eBay. On the backside of the motor/pump housing, it shows 9scfm @ 40psi; 7scfm @90psi.
11-29-2020, 6:52pm | #15 | |||||||
I have restored several cars over 40 yrs. I only used a blaster once. That was enough for me. I was blasting the chassis of my '69 Chevelle SS 396. I forgot and left my wallet in my back pocket. I was wearing to long tail shirts that day. When I finished and was removing my clothes I pulled my wallet out. Every nook and cranny inside it was filled with the blasting media. If you blast stuff while it's still attached to the car vs. in a cabinet. All that dust and debris will wind up in every nook and cranny. When you come along to paint it at 60 PSI, etc...all that crap will get blown out and around into your fresh paint. |
11-30-2020, 3:14pm | #16 | |||||||
Gameroom Barn Bucks: $856744
Just an FYI I heard on one of the car shows. When blasting with soda it changes the PH of the metal and paint won't stick to it unless an additional step is taken to correct that.
The Following User Says Thank You to JetMechZ16 For This Useful Post: |
11-30-2020, 3:21pm | #17 | ||||||
11-30-2020, 3:30pm | #18 | ||||||
11-30-2020, 4:32pm | #19 | |||||||
I’ve done sand at home with siphon in driveway... small pits and a mess. I’ve had my 65 vette soda blasted when rebuilding it. Worked great, still messy. Looked like my yard was covered w snow dust till rain washed soda away. Gotta agree w Jet, check out walnut shells for a cabinet or other. Still a mess but won’t mess w parts |
12-01-2020, 8:51pm | #20 | |||||||
If you are spot blasting or aggressively stripping outer panels which will eventually get body color I recommend the first paint application to be a catalysed epoxy primer. It is fairly weatherproof and will provide a stable base for fillers, sandable primers and paint. |
