Old 09-01-2020, 3:51pm   #1
VatorMan
Barn Stall Owner #122
NCM Supporter '11,'13
Bantayan Kids '13,'14,'17
Points: 68,426, Level: 100
Activity: 5.0%
VatorMan's Avatar
Gameroom Barn Bucks: $1158963
Default Electricity. It lets you know when it wants out
15KV Load break switch. Or should I say FORMER load break switch.
VatorMan is offline   Reply With Quote
The Following 3 Users Say Thank You to VatorMan For This Useful Post:
Old 09-01-2020, 3:54pm   #2
BOTY
Points: 29,117, Level: 100
Activity: 2.1%
BOTY's Avatar
Hello.
BOTY is offline   Reply With Quote
Old 09-01-2020, 3:58pm   #3
FLEXjs
Points: 11,251, Level: 73
Activity: 3.6%
FLEXjs's Avatar
Gameroom Barn Bucks: $12967
Metal-Clad switchgear is pretty heavy-duty. But 15KV is on the low end.
What's the application?
FLEXjs is offline   Reply With Quote
Old 09-01-2020, 4:04pm   #4
z06psi
Barn Stall Owner #∞
Points: 25,038, Level: 100
z06psi's Avatar
Gameroom Barn Bucks: $34677
Wait till you have 440V at 300 amps blow up in your face with an arc flash.
I quit work for over an hour because of that. Took out the whole section of a FOB when I did that.
No voltage or amperage is on the low end.
z06psi is offline   Reply With Quote
The Following User Says Thank You to z06psi For This Useful Post:
Old 09-01-2020, 4:05pm   #5
z06psi
Barn Stall Owner #∞
z06psi's Avatar
Failure or surge?
Old 09-01-2020, 4:10pm   #6
VatorMan
Activity: 5.0%
VatorMan's Avatar
We run a network(not IT) system here. This was a feeder for our Neutron research facility cooling system.
Failure- no surge.
I have told the bean counters many times electrical equipment should be in buildings. Nema 3R be damned
The Following User Says Thank You to VatorMan For This Useful Post:
Old 09-01-2020, 4:14pm   #7
z06psi
Barn Stall Owner #∞
z06psi's Avatar
Failure- no surge.
I know in all the critical comms facilities (Nuke Command and Control type shit) the incomers, transformers, UPS, Generators, switch gear are all in environmentally controlled areas.
Nothing is outside. Protection and to extend durability.
Old 09-01-2020, 4:14pm   #8
FLEXjs
Activity: 3.6%
FLEXjs's Avatar
15KV is considered medium voltage but it's at the lower end of the scale.
My company makes medium voltage switchgear and although we do make 15KV stuff the majority is 27, 29, or 38KV
The metal clad stuff make by Eaton in the picture goes from 5 to 15KV so it's at the high end of that product line, for them, but not the high end for general switch applications typically used by electric companies.
Old 09-01-2020, 4:20pm   #9
z06psi
Barn Stall Owner #∞
z06psi's Avatar
I know ABB and Siemens makes a lot of the higher end stuff.
Either one of those?
Old 09-01-2020, 4:22pm   #10
VatorMan
Activity: 5.0%
VatorMan's Avatar
Most of our site is Eaton. Our 15KV substation is Eaton. We’ve had a couple of failures, but they handle them without too much fuss. Our building distribution is 480V and 208V. We do have 7 4160V chillers.
Old 09-01-2020, 4:22pm   #11
VatorMan
Activity: 5.0%
VatorMan's Avatar
FPE.
Old 09-01-2020, 4:24pm   #12
Giraffe (He/Him)
Goldilocks
Barn Stall Owner #905
Bantayan Kids '13,'15
Points: 110,810, Level: 100
Giraffe (He/Him)'s Avatar
Gameroom Barn Bucks: $1009320
Pffft. One of our generators puts out over 20,000 volts and goes through a step-up transformer to 345,000 volts.
That’s it. That’s all I know about the electrical side of our plant. Shit scares me. You can SEE a water leak. Electricity? Not so much.
Old 09-01-2020, 4:24pm   #13
Wathen1955
Points: 47,227, Level: 100
Activity: 11.2%
Wathen1955's Avatar
Gameroom Barn Bucks: $1524159
Wathen1955 is offline   Reply With Quote
The Following 2 Users Say Thank You to Wathen1955 For This Useful Post:
Old 09-01-2020, 4:28pm   #14
VatorMan
Activity: 5.0%
VatorMan's Avatar
I use a drone at work with IR and scope out PEPCOs 69KV feeders feeding us. That’s as close as I get to arial power. Screw that. Ever watch those crazy SOBs that climb around on energized cables from a helicopter ?
I always wonder about the first guy that ever did that.
Old 09-01-2020, 4:32pm   #15
Giraffe (He/Him)
Goldilocks
We're started using drones to inspect our transmission lines too.
Old 09-01-2020, 4:38pm   #16
FLEXjs
Activity: 3.6%
FLEXjs's Avatar
No; those two and Eaton are competitors of ours.
I went to the IEEE T&D convention in Denver in 2018. I was walking around taking pics. Mostly I had no idea what I was looking at. I just took pics of stuff that looked cool to show Mrs Flex when I got back.
Wandered into the Eaton booth and some dude saw my company name on my lanyard and started giving me a a hard time about taking pics. I said "Dude, I'm in finance I don't even know wtf I am looking at."
He was not amused. Fukkem.
The Following User Says Thank You to FLEXjs For This Useful Post:
Old 09-01-2020, 4:42pm   #17
FLEXjs
Activity: 3.6%
FLEXjs's Avatar
Yep, sales guy showed me this vid a while back. Freaky as hell.
Wild how they touch that rod to the power line to equalize the potential. I don't even get how that works.
The Following 2 Users Say Thank You to FLEXjs For This Useful Post:
Old 09-01-2020, 4:44pm   #18
z06psi
Barn Stall Owner #∞
z06psi's Avatar
High Voltage Cable Inspection - YouTube
They become part of the circuit.
Old 09-01-2020, 4:52pm   #19
Aerovette
Barn Stall Owner #7734
Points: 106,365, Level: 100
Aerovette's Avatar
I worked in a lab that had three phase power supplying a dyno. It had three 350MCM cables at each phase at the breaker. The breaker blew and copper was splattered inside like it was hot wax.
Old 09-01-2020, 5:20pm   #20
Giraffe (He/Him)
Goldilocks
This thread is shocking.
The Following User Says Thank You to Giraffe (He/Him) For This Useful Post:
