Old 10-12-2019, 6:55pm   #1
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 116,308, Level: 100
Activity: 8.3%
JRD77VET's Avatar
Cool Time of Harvest show at Rough and Tumble today 10-12-19
Last show of the year today. Plenty of stuff happening and managed to get some pics and a few videos.
Since I volunteer at Rough and Tumble and explain the 1913 Cooper pumping engine, I can get a lot closer to the moving parts than the visitors. I held the camera a lot closer to moving parts than I would ever put my head.
Also got video of a 1-1/2 hp New Holland hit and miss engine. One of the selling features of this engine was a "freeze proof" water hopper. The taper would allow the ice to expand up instead of out which would break the cooling hopper.
I just missed this Rumley Oil Pull tractor being started but got the warm up and it driving off
1st pic are three hot air water pumping engines. The middle and right are running. We only run the big one when it's cool out as it throws off a ton of heat. It also takes three good sized folks to get it turned over to run.
2nd pic is the hot air engines and Roger's 1893 17 HP Otto engine
3rd is my 1900ish Olds engine
4th is the oldest running atmospheric engine in the Americas and 3rd oldest in the world. It's an Otto and Langen built in 1867/68 Behind it is a Crossley based on Otto's patent
5th 40 hp Fairbanks Morse
6th 125 hp Miller
7th Klein oil field engine
8th Fairbanks Morse vertical & 1-1/2 hp New Holland
9th Fairbanks Morse
10th 1-1/2 hp New Holland
The Following 9 Users Say Thank You to JRD77VET For This Useful Post:
Old 10-12-2019, 7:00pm   #2
JRD77VET
Activity: 8.3%
JRD77VET's Avatar
Renfrew engine that stopped in on it's way to VA to be gone over for running.
Old 10-12-2019, 7:06pm   #3
JRD77VET
Activity: 8.3%
JRD77VET's Avatar
First 3 pics are the 485 hp Cooper pumping engine. It displaces close to 45,000 cubic inches of displacement and has over 11,000 lbs of torque.
4th and 5th are the Mann diesel engine. One of the earliest diesels made and it's still running quite well.
6th and 7th are the 40 hp Reeves twin
8th is the Star engine
Last two are the williamsport engine.
The Following 8 Users Say Thank You to JRD77VET For This Useful Post:
Old 10-12-2019, 7:11pm   #4
JRD77VET
Activity: 8.3%
JRD77VET's Avatar
First three are a Myrick engine
Next is a 1930 Hart Parr tractor. This is the last year Hart Parr was in existence as Oliver took them over.
Steam tractor in the foreground is from 1886 and behind it is a Baker
Old 10-12-2019, 7:16pm   #5
JRD77VET
Activity: 8.3%
JRD77VET's Avatar
Some more steam traction engines.
Notice the youngster running the steam tractor. He's been coming out to Rough and Tumble for about 6 years. This is the first year the family has "set him loose" on the steam tractor and that kid handles that big tractor quite well. ( he took the steam engine school at R&T and knows what to do and what to watch for )
Old 10-12-2019, 7:22pm   #6
JRD77VET
Activity: 8.3%
JRD77VET's Avatar
Here's Justin putting the Edison generator in his truck to take down to VA. He's going to restore R&T's Edison generator to use with his 1903 Fairbanks Morse engine that he has on display.
next to last is a casting he'll be machining
Last pic is his Fairbank Morse
Old 10-12-2019, 7:42pm   #7
snide
NCM Supporter '13
Points: 216,817, Level: 100
Activity: 53.6%
Awesome!
The Following User Says Thank You to snide For This Useful Post:
Old 10-12-2019, 8:17pm   #8
MrPeabody
Points: 69,948, Level: 100
MrPeabody's Avatar
Gameroom Barn Bucks: $2214590
Very cool. I'd sure love to come to one of the events there. Maybe someday...
MrPeabody is offline   Reply With Quote
Old 10-12-2019, 8:35pm   #9
JRD77VET
Activity: 8.3%
JRD77VET's Avatar
Since you're on the other side of the country, I would suggest the Threshersman Reunion which will be August 12th thru the 15th 2020
https://roughandtumble.org/viewrefer...ventschedules/
Jeff
Old 10-12-2019, 8:58pm   #10
MrPeabody
MrPeabody's Avatar
Jeff
Thanks for the info. I get a little taste of this stuff right here when they have the annual Pear Festival and there is a display of about a dozen or so small running farm engines and a few tractors. The tractors also get decorated and are used in the lighted Christmas parade every year. Just enough to make me have an interest is seeing more, and of course to see some of the big stuff.
The Following User Says Thank You to MrPeabody For This Useful Post:
Old 10-17-2019, 9:34pm   #11
WOEII
Points: 33,953, Level: 100
Activity: 1.1%
WOEII's Avatar
Gameroom Barn Bucks: $1007440
Love it! That natural gas one looked awesome....massive amount of weight!
WOEII is offline   Reply With Quote
The Following User Says Thank You to WOEII For This Useful Post:
Old 10-18-2019, 7:20pm   #12
JRD77VET
Activity: 8.3%
JRD77VET's Avatar
Total weight of the Cooper engine with pump is 155,000 lbs. The flywheel weighs 22,000 lbs, is a two piece design and is 14' in diameter.
21-1/2" bore and 36" stroke. It's a four cylinder design that has TWO pistons. Since there is "fire" on both sides of the pistons, cooling is done with water pumped thru the connecting rods, thru the pistons and then dumped out of pipes on each end. The water pump is between the two cylinders and the pipes moving back and forth is seen in the video.
In the video, it's running about 60 RPM. Changing the gearbox ( leather belt to the governor) allows engine speeds of either 60, 75, 90, 105 or 120 rpm.
It was built in 1913 and was running until the late 1970s at Columbia Gas in Medina OH. We got spare parts for it from another branch of Columbia Gas from their Rockport VA pumping station. They took out three identical Cooper pumping engines in 2015. Out of the twelve cylinders on those three engines, only one cylinder didn't meet current EPA standards. A rebuild would have brought it back into compliance. ( but the Govt was throwing all kinds of money around to "upgrade" to something that will wear out in 12-15 years. )
Old 10-24-2019, 7:44pm   #13
WOEII
Activity: 1.1%
WOEII's Avatar
Love it.
