03-12-2019, 2:41pm | #1 | ||||||
Barn Stall Owner #23
Barn Raising I
Gameroom Barn Bucks: $144580
Geometry help.
I never was good at geometry. Someone would ask me to find an angle, all I could do was point at a crooked line and say, "There it is."
So here is the question: Side "A" is 6 inches long, Hypotnuese is 29.5 inches long, Side B is 29 inches long. What the hell is my angle? TIA! |
03-12-2019, 2:47pm | #2 | ||||||
Gameroom Barn Bucks: $2214590
I was very good at geometry. But that was 50 years ago.
03-12-2019, 2:54pm | #3 | ||||||
Barn Stall Owner #74
03-12-2019, 3:14pm | #4 | |||||||
sine of small angle = 6/29.5 = 0.23389 so angle = 11.74 degrees. |
03-12-2019, 3:18pm | #5 | ||||||
2016 Election Expert
Barn Stall Owner #64
sin(a) = 6/29.5
a = 11.73 degrees The other angle is 90-11.73 = 78.27 degrees |
03-12-2019, 3:24pm | #6 | ||||||
To work it out just using the two sides (not the hypotenuse) then it would be:
tan(a) = y/x = 6/29 a = arctan(6/29) = 11.69 degrees I'm thinking this is really your angle since there's no way your hypotenuse is 29.5 with the other two sides being 29 and 6 respectively. There's a measurement error there. I mean, it's probably very close to 29.5, but if the other two sides are precisely 29 and 6 respectively, the hypotenuse is actually: sqrt(6^2 + 29^2) = 29.61 inches. |
03-12-2019, 3:27pm | #7 | ||||||
if you don't have a calculator handy, you can also solve this on the slide rule, using the C and D scales to find 6/29.5 = 0.203, and then flipping it over to read the angle off the S scale = 11.74 degrees.
03-12-2019, 3:32pm | #8 | ||||||
And children, always remember, all you need to totally know everything about a right triangle is, other than it's a right triangle, is two more pieces of information. The length of any two sides, or a side length and an angle. That's it!
03-12-2019, 4:32pm | #9 | ||||||
Barn Stall Owner #6969
Gameroom Barn Bucks: $1071547
Hope this helps...
03-12-2019, 6:35pm | #10 | ||||||
03-12-2019, 7:22pm | #11 | |||||||
Right Scalene Triangle Side a = 6 Side b = 28.88339 Side c = 29.5 Angle ∠A = 11.735° = 11°44'7" = 0.20482 rad Angle ∠B = 78.265° = 78°15'53" = 1.36598 rad Angle ∠C = 90° = 1.5708 rad = π/2 With side "a" at 6" long and side "b" at 29" long, angle "A" is 11.689° Right Scalene Triangle Side a = 6 Side b = 29 Side c = 29.61419 Angle ∠A = 11.689° = 11°41'22" = 0.20402 rad Angle ∠B = 78.311° = 78°18'38" = 1.36678 rad Angle ∠C = 90° = 1.5708 rad = π/2 ~~~~~~~~~~~~~~~~~~~~ I used this on line calculator to copy the info for pasting https://www.calculator.net/triangle-calculator.html I also used my machinist calculator and came up with the same values. https://www.ebay.com/itm/Calculated-...frcectupt=true Now if I was making this part for you, you would have gotten a phone call or an email asking which values to use. |
03-12-2019, 7:43pm | #12 | ||||||
42.
03-12-2019, 8:31pm | #13 | |||||||
03-12-2019, 8:35pm | #14 | ||||||
03-12-2019, 8:45pm | #15 | ||||||
03-12-2019, 8:57pm | #16 | ||||||
I've got a friend that was on a slide rule kick a few years ago. Buying them at flea markets and antique stores. He was hell bent on ignoring modern technology.
When he finally got a smart phone, he downloaded a rotary dial app for it. |
03-12-2019, 9:01pm | #17 | ||||||
Barn Stall Owner #115
Gameroom Barn Bucks: $610854
03-12-2019, 9:01pm | #18 | ||||||
Tell him if he had a real rotary phone, he could dial just by clicking the button on the cradle that hangs it up
03-13-2019, 1:35am | #19 | ||||||
I have an old ATT stepper relay laying around here...that means I am without question the most biggest nerd here in this group.....
Hell, I even have a Klystron Oscillator tube on the window sill..... |
03-13-2019, 5:17am | #20 | ||||||
Gameroom Barn Bucks: $1232517
I often make use of hypotenuse while squaring construction. I don't know what the hell it is but I use it somehow.
