10-09-2017, 11:22am | #1 | ||||||
2016 Election Expert
Barn Stall Owner #64
AR-15 related question for the gun enthusiasts here.
I have a really nice Colt AR-15 Sporter Match HBAR that I got for my wife back in the 80's when she was shooting iron sight competitions. This rifle is set up to be very accurate with just iron sights, but I want to put a holographic sight or some other type of sight to make it more fun to shoot outside the 100-yard range. The rifle has the upper with the carry handle, and stock heat shields with no Picatinny/Weaver mounting rails at all.
So, I know there are a variety of carry handle rails like these that allow you to mount an optic of some sort, either right on the handle or ahead of it. It would be nice to maybe have just a red dot sight, and also maybe a 2x power optical sight, or a holographic perhaps. Anyone have some experience with this that would want to share their recommendations? I can also go ahead and get new heat shields or whatever they are called with integrated rails or at least places you can put rails, but I'm not planning on putting a light or laser or night vision stuff on this rifle, at least not yet. Also I don't want it for home defense, already have that covered. |
10-09-2017, 11:36am | #2 | ||||||
Barn Stall Owner #6969
Gameroom Barn Bucks: $1071547
I like the Eotech holographic sights. They are pricey, but well built and reliable. What I would not do is pay 600 bux for one of their magnifiers though. You can get cheap ones that do the same thing and won't degrade the sight whatsoever. If you want to keep it under $200, Vortex makes a decent red dot scope.
10-09-2017, 11:48am | #3 | ||||||
Wow, almost $1000 for a 1x holographic sight?
10-09-2017, 12:58pm | #4 | ||||||
Gameroom Barn Bucks: $7601
Eotech kind of suck on carry handles and work better on a flat top AR. That being said, I sent both my Eotechs back to the factory when the massive zero drift issues surfaced and I got my money back. Lastly Eotechs are better are CQB distances.
The best optic for a carry handle is still the ACOG. There are many to choose from, and they are great at distance. |
The Following 2 Users Say Thank You to Nox For This Useful Post: |
10-09-2017, 1:06pm | #5 | ||||||
Or you could go old school and put on an original Colt 4 power scope like I did. I got this set up back in the day. Still have it. Shoots great.
The Following 4 Users Say Thank You to Nox For This Useful Post: |
10-09-2017, 1:06pm | #6 | ||||||
Nox, do you have an ACOG laying around in a box somewhere that you're not using?
10-09-2017, 1:26pm | #7 | ||||||
Nox, I'll check that Colt scope out! What do you think of the Leupold VX-R Patrol in this application?
10-09-2017, 1:44pm | #8 | |||||||
I use an RDS because almost all of my work is from 1 to 100 yards. However, when I am working beyond 100 yards, I usually go to a standard reticle. |
The Following User Says Thank You to Nox For This Useful Post: |
10-09-2017, 1:52pm | #9 | |||||||
10-09-2017, 2:01pm | #10 | |||||||
And with most RDS, you should be able to co-witness. I have 1/3 lower co-witness on all my RDS optics so I can use my irons if I need to. |
10-09-2017, 2:12pm | #11 | |||||||
10-09-2017, 2:28pm | #12 | ||||||
Just make sure it comes with the bolt carrier group also. Also, even though they sell them, any upper with less than 16 inch barrel will have to be registered as an SBR so be careful. I prefer 1:8 or 1:9 barrels, but everyone’s mileage varies. I shoot M-193 almost exclusively, so 1:9 is good to go for me.
10-09-2017, 7:22pm | #13 | ||||||
Carry handle mounted optics are a compromise because they end up so far above the bore centerline. If you are willing to build a separate upper to mount an optic might I suggest you simply swap your barrel assembly onto a stripped flat top upper? If you own a torque wrench, you can acquire a new upper receiver, and the tooling to do the swap for about $100.00 all in if you eschew the dust door and forward assist. First time should take less than an hour, and you can mount the sight of your dreams down low as it should be.
Also be aware that some Colt lowers use a different diameter push pin than the current industry standard. If you get a stripped upper or build a complete upper make certain you acquire parts that fit your gun. |
10-12-2017, 12:23pm | #14 | ||||||
Anybody have any comment on this complete upper, perhaps with the nickle-boron BCG upgrade?
10-12-2017, 4:05pm | #15 | |||||||
10-12-2017, 4:31pm | #16 | |||||||
Also I will be able to swap the red dot and magnifier to the old upper if I want at any time, and leave that totally as-is. Just got done going through the entire rifle with a fine tooth comb, it's in perfect shape and all nice, clean, lubed up. Also got an adapter pin for the large front take-down hole on the old Colt lower. Will make taking the upper totally off the lower a tiny bit more annoying, but that's OK. So I'll have two AR's now. A really nice 20" heavy barrel iron sight rifle and an M4-style flat-top with plenty of rail room for add-ons, and my first was a curved foregrip. Nox, I'm probably screwing up on some level but I really wanted to scratch that gun itch and I have plenty of handguns, and now at any point I can just buy another lower and *poof* have two AR's, one .223 only, and this Wylde. |
10-12-2017, 6:23pm | #17 | |||||||
10-12-2017, 6:44pm | #18 | |||||||
Most likely sometime this winter I'll build a compatible lower for the new parts and have a essentially a .556 carbine. |
10-12-2017, 6:59pm | #19 | ||||||
10-12-2017, 8:28pm | #20 | |||||||
