12-23-2011, 3:35pm | #141 | ||||||
12-23-2011, 3:39pm | #142 | ||||||
12-23-2011, 4:14pm | #143 | ||||||
Gameroom Barn Bucks: $4969152
Yeah,I noticed that...wonder what is? Hope it was oil soluable.I hope he didn't use that on the rings too. I thought he said the project was finished and running but I have been wrong before..
12-23-2011, 4:22pm | #144 | ||||||
He did say it was running, and has another thread that sounds like he may have smoked the trans. His luck resembles mine.
12-23-2011, 4:30pm | #145 | ||||||
12-23-2011, 5:11pm | #146 | ||||||
Gameroom Barn Bucks: $3699
Where is Jakesons' thread? I'm feeling left out.
BTW: I love that avatar Pete K. |
12-23-2011, 5:12pm | #147 | ||||||
The Following User Says Thank You to nutz4c4 For This Useful Post: |
12-23-2011, 5:37pm | #148 | ||||||
That white stuff he is using looks like the assembly lube .
No. 105 Motor Assembly Grease Calcium Type Grease For all engine and transmission assembly Prevents rust LUBRIPLATE No. 105 is a white, waterproof, NLGI No. 0, grease type lubricant possessing exceptional anti-seize properties and recommended extensively for coating all moving parts for motor assembly and rebuilding. The suggested procedure is to apply LUBRIPLATE No. 105 as a light coating by means of a brush or swab or by spraying to all moving parts of the engine. This will include such applications as valve stems, pistons, rings, timing gears, main and rod bearings, and, in fact, every moving part of the internal combustion or diesel engine. This is to take place prior to assembly. This procedure will eliminate corrosion and seizure after the initial start. |
The Following User Says Thank You to Ch@0s For This Useful Post: |
12-23-2011, 5:41pm | #149 | |||||||
12-23-2011, 5:42pm | #150 | ||||||
12-23-2011, 5:53pm | #151 | ||||||
It sure looked like he used enuff.....
12-23-2011, 6:29pm | #152 | ||||||
Gameroom Barn Bucks: $460853
Pete, the old Marines loved Lubriplate. Did you ever use it?
The Following User Says Thank You to Vette Jockey For This Useful Post: |
12-23-2011, 6:33pm | #153 | |||||||
I use a light finger smear of oil on the rings, and if it will sit, I will mist a light coat of WD-40 on the exposed steel or iron. That is what I was taught in the 80's, and I never deviated. |
12-23-2011, 7:11pm | #154 | ||||||
Gameroom Barn Bucks: $3895593
12-23-2011, 7:16pm | #155 | ||||||
12-23-2011, 7:33pm | #156 | ||||||
12-23-2011, 7:44pm | #157 | ||||||
I think they started using it about the same time they enacted the ( Don't ask, Don't tell) policy...At least thats what I heard.. ....WW
12-23-2011, 7:45pm | #158 | ||||||
12-23-2011, 8:11pm | #159 | ||||||
You guys are bad.
12-23-2011, 8:19pm | #160 | ||||||
