Old 10-27-2010, 9:41pm   #1
wwomanC6
C6 Modulator
Barn Stall Owner #27
NCM Supporter '13,'14,'15
Points: 77,846, Level: 100
Activity: 51.5%
wwomanC6's Avatar
Default Strange New Noise
CheySha and I heard a strange new noise coming out from under my Vette tonight. Sounds like a vibration noise coming from the rear end area. We only hear it when its in gear. Goes away When put in park. I crawled under there to pin point were its coming from. Sounds like the front of the transmittion/torque shaft connection area. To me it sounded like the front trans housing area. Any ideas what the issue might be?
I have an automatic.
Old 10-27-2010, 9:50pm   #2
03SlowZ06
Points: 3,068, Level: 36
03SlowZ06's Avatar
Gameroom Barn Bucks: $100431
Your general area might be kinda this general area description does not help alot. LOL.
Does it sound like metal on metal or just something loose sitting on the tranny bounceing round?
I would feel around to see if any of the harnesses have come off the cheesy little clips and is bouncing around. Also I can see the maybe the brake lines rattling might be the cause. Lastly gently put pressure on the exhaust tips when it makes the noise to see it maybe one of the hangers is squeeking.
50th Anniv. Quick Silver Z06
OBX LT's, Haltech Stinger
P1SC waiting to go on
Old 10-27-2010, 10:01pm   #3
CheySha
Points: 2,414, Level: 31
CheySha's Avatar
Gameroom Barn Bucks: $1208
Wellllll it sort of sounded like a tink clang rattle bang and it sounded like it was somewhere in the left of the middle right close to the back but towards the front.
CheySha is offline   Reply With Quote
Old 10-27-2010, 10:05pm   #4
wwomanC6
C6 Modulator
Activity: 51.5%
wwomanC6's Avatar
Felt around the exhaust pipes for loose clamps & clips. Will check the brake lines and hangers tomorrow and let ya know.
To me it didn't sound like metal on metal but more like something metal rattling or and exhaust leak rattle.
Old 10-27-2010, 10:05pm   #5
Defib1961
Barn Stall Owner #23
Barn Raising I
Points: 60,695, Level: 100
Defib1961's Avatar
Gameroom Barn Bucks: $144580
EXACTLY where mine was.
Don't sweat the petty things and don't pet the sweaty things.
Defib1961 is offline   Reply With Quote
Old 10-27-2010, 10:07pm   #6
wwomanC6
C6 Modulator
Activity: 51.5%
wwomanC6's Avatar
Your funny!!!
Old 10-27-2010, 10:19pm   #7
thegreenman
Points: 15,494, Level: 85
thegreenman's Avatar
Do you have NPP? I think they make a clang bang rattle tink noise instead of the tink clang rattle bang sound. If you have NPP the butterfly's could be rattling.
Old 10-27-2010, 10:20pm   #8
03SlowZ06
03SlowZ06's Avatar
Sounds like a very good place to start. I can also picture one of the H pipe hangers with the spring ( I think your c6 uses the same) hangers rattling.
Old 10-27-2010, 10:27pm   #9
wwomanC6
C6 Modulator
Activity: 51.5%
wwomanC6's Avatar
Have stock exhaust, and I saw those springs you were referring to but did not check them.
Old 10-27-2010, 10:47pm   #10
thegreenman
I am thinking exhaust somewhere, just barley touching something, you want at least 1/4 clearance from the exhaust. My header was hitting my subframe and was only noisy when in gear also, I found it by seeing rub mark on the header.
Old 10-27-2010, 10:52pm   #11
CheySha
CheySha's Avatar
Sorry Wendy I was distracted by the WS game LOL... I don't know how to really describe it but maybe we can make an audio clip of it and post it along with a pic of the where it's coming from?
Old 10-27-2010, 10:56pm   #12
wwomanC6
C6 Modulator
Activity: 51.5%
wwomanC6's Avatar
I figured as much!
We can do that tomorrow evening if I cant find the problem looking at the things mentioned!
Old 10-27-2010, 11:28pm   #13
CheySha
CheySha's Avatar
I think it's more of a grinding noise... Like when a clutch gets too hot... That's almost what it sounds like to me...
Old 10-28-2010, 6:14am   #14
Possible torque tube bearing going bad? Use a stethescope to listen along the driveline near the point where you kinda sorta hear the clang bang rattle tink grind.
Just make sure the Squirrell is up on a lift or jackstands(well supported) when you put it in gear and try to listen. You're nice and slim Wendy, but not slim enough to go hanging upside down under the Squirrell with a scope in your ear.
Old 10-28-2010, 6:27am   #15
DropTheTop
Barn Stall Owner #777
Points: 22,113, Level: 100
DropTheTop's Avatar
Gameroom Barn Bucks: $6589249
I loves me a good smart ass!!
Old 10-28-2010, 11:58am   #16
lutzdog
Points: 11,003, Level: 72
lutzdog's Avatar
Gameroom Barn Bucks: $595211
a woman that will crawl under her vette and troubleshoot. the only thing hotter than that is if she was wearing a lacy g-string while holding a beer while doing it..
Old 10-28-2010, 5:54pm   #17
Points: 35,032, Level: 100
Try door # 3, tell us if the noise is there or not in neutral. (there is a difference)
A4 cars have different engine idle speeds depending on if "in gear", or "park/neutral". Based on your description, my inclination is that it's probably not something rotating, but is making noise by resonating at the lower idle RPM frequency which happens only when in gear.
You can test this easily, with the car on the ground, by placing the car in Drive, holding your foot on the brake, and giving it just a LITTLE throttle to bring the RPMs up off normal idle some (at/near/not over 1000 RPM). Does the noise remain or disappear? Or does it get worse?
And if you find there is a difference between park and neutral, it would quickly point to the tq converter, even though the resultant noise would likely be heard downstream.
Old 10-28-2010, 7:51pm   #18
wwomanC6
C6 Modulator
Activity: 51.5%
wwomanC6's Avatar
No noise in park or neutral, All others yes.
"but is making noise by resonating at the lower idle RPM frequency which happens only when in gear." - YES
DISAPPEARS
Recorded a video & trying to get it on you tube.
Old 10-28-2010, 9:24pm   #19
Your replies point to an exhaust vibration issue. (good news for you - probably nothing serious).
The C5 commonly suffered from the same thing, although mine never had this trouble (though I would never hear it on my car even if it was), am not sure of the real fix.
Hopefully you can reply to this reply, as I've done nothing on the other end to change things...
Old 10-29-2010, 4:14am   #20
wwomanC6
C6 Modulator
Activity: 51.5%
wwomanC6's Avatar
Talked to Johnny (Posse Peep). Him and a Josh(Resurrection Auto/Vette Mech) said the same thing along the same lines with your diagnoses. We are gonna put it on the lift this afternoon to try and find the problem.
The Following User Says Thank You to wwomanC6 For This Useful Post:
