Old 05-11-2010, 10:44am   #1
FRC Joe
Points: 4,203, Level: 43
FRC Joe's Avatar
Gameroom Barn Bucks: $882
Default car wont start, no spark
Car began stumbling under acceleration yesterday morning, and died a few times while rolling up to a stop. Got it back home and let it idle for a while. Still would break up while revving. No codes set my PCM. Unplugged MAF, no change. Turned the car off and did other things. Went to start it up a few hours later and no go. Cranks fine, has fuel pressure at the rail, but no hint of wanting to start. Pulled a plug and laid it on alt. bracket, no spark while cranking. Checked all fuses, disconnected and reconnected batt., still no spark.
So now I've got it up in the air, fenders back off and am looking at the extended harnesses to the coil packs. They look fine, no obv. burnt or melted wires, and they ohm out fine.
So I'm at a bit of a loss as to what to check next. Any suggestions are appreciated.
99 FRC - A&A T-Trim @ 10PSI
Old 05-11-2010, 10:56am   #2
Did you retain the factory coil-pack harness plug when you did the extensions? Maybe check to insure they're fully seated?
It seems that you've covered all the obvious things... I'm not sure what else could cause a no spark condition since the car is trying to crank and you have fuel etc.
Could it be security related? I.E. the vats or anti-theft system?
Old 05-11-2010, 11:03am   #3
FRC Joe
FRC Joe's Avatar
There was no blinking security light or anything in the DIC to indicate a security system problem. All of the coil plug were securely seated with the locking pins in place. I suppose I should bust out the service manuals and see if there is a multimeter test for the harnesses. But I have to say, at the moment I feel like doing nothing at all to it, ever again.
I was supposed to be leaving for Indianapolis tomorrow for a car get-together. I guess I should feel lucky that whatever failed failed here and not 600 miles away.
Old 05-11-2010, 11:04am   #4
DropTheTop
Barn Stall Owner #777
Points: 22,113, Level: 100
DropTheTop's Avatar
Gameroom Barn Bucks: $6589249
Uplug the MAF and try to start it up. If it runs, then you may need a new MAF. I found a similar problem that someone had with an LS1. Same thing, no spark, but everything else checked out. It's worth a shot, good luck.
Edit: I should read more closely, and not scan through!
The Following User Says Thank You to DropTheTop For This Useful Post:
Old 05-11-2010, 12:37pm   #5
allthrottleandsomebottle
Points: 23,599, Level: 100
Gameroom Barn Bucks: $1005893
Check all the grounds.......classic symptom........didn’t see you mention it Joe
http://forums.corvetteforum.com/c5-t...tion-long.html
The Following User Says Thank You to allthrottleandsomebottle For This Useful Post:
Old 05-11-2010, 3:24pm   #6
FRC Joe
FRC Joe's Avatar
I sure was hoping it was the MAF, and youre right it sounds like exactly that.
IMPORTANT ELECTRICAL INFORMATION (Long!) - Corvette Forum
Will def. check. The thing that is puzzling to me, is that the lack of spark is total. If it were related to the extended harnesses I would have expected one or the other coil packs to be out, not both. So a loose ground or some other problem like that seems likely.
Old 05-11-2010, 3:52pm   #7
Points: 35,030, Level: 100
The 3 common things that would affect ALL coil packs (both banks) are...
PCM fuse #16 underhood (10a).
Ground G106 (located near the starter I believe) and G107 (ring terminal on rear of left head)
Ignition relay 42 (this failing to close should produce a code though).
Fuses #22 (15a - coils bank 1) and #18 (15a - coils bank 2) also worth checking, but both would have to be out to affect both banks.
Old 05-11-2010, 7:23pm   #8
FRC Joe
FRC Joe's Avatar
W00t! It was the back of head ground! Running like a top again. Thanks a bunch for the ideas guys!
The Following User Says Thank You to FRC Joe For This Useful Post:
Old 05-11-2010, 7:29pm   #9
wwomanC6
C6 Modulator
Barn Stall Owner #27
NCM Supporter '13,'14,'15
Points: 77,846, Level: 100
Activity: 51.5%
wwomanC6's Avatar
Tom saves the Day!
The Following User Says Thank You to wwomanC6 For This Useful Post:
Old 05-11-2010, 8:05pm   #10
Glad you got it going.
AT&SB suggested it 1st, so I can't take credit for this one, other than offering more detailed clues.
This particular issue is semi-common to read about following a head swap project, but to happen out of the blue, not so much.
As you've learned, that little ground point is quite vital though - lacking it shuts down both the coils and injectors.
Old 05-11-2010, 9:42pm   #11
Glad it was easy..........I have never had it, But more than a few have I have helped.....hold the phone closer so I can see the problem .....no codes is the 1st clue! My nephew had the same deal also..............it was in town dead on the road. Finger tight got him home
Old 05-12-2010, 8:25am   #12
Awesome
