Old 03-18-2010, 2:48pm   #1
1TZSLO
Points: 5,654, Level: 51
1TZSLO's Avatar
Gameroom Barn Bucks: $377
Default Reduced system power
Today I cranked up my 97 Coupe 6speed and all of a sudden this came
up Reduced system power going across the dash.
U1016 Loss of Communications with PCM
U1096 Loss of Communications with IPC
C1278 TCS Temporarily Inhibited By PCM
C1281 Steering Sensor Uncorrelated Malfunction
P1516 Command vs Actual Throttle Position Performance (TAC Module)
So I immediately shut the car off and waited about 20secs and cut it back on and it runs fine for the rest of the day. The only thing that was done to the car recently was I had a clutch installed.
This is the second time this has happened with in a week.
and I was hoping for some insight on what might be causing it.
Arctic White 97 C5 Coupe
NOT STOCK
Old 03-18-2010, 3:23pm   #2
GB Vette
The Old Guy
Points: 62,624, Level: 100
Activity: 6.4%
GB Vette's Avatar
Gameroom Barn Bucks: $804566
I would be looking for a loose connection, broken ground, blown fuse etc. that may have occured during the clutch changeout.
'02 FRV (Fixed Roof Vert)
NCM Lifer #1572
The Following User Says Thank You to GB Vette For This Useful Post:
Old 03-18-2010, 3:27pm   #3
Points: 35,032, Level: 100
The P1516 is what's putting it in Reduced Power Mode.
Here's what the service manual says about it:
_____________
Circuit Description
The commanded throttle position, based on accelerator pedal position and possibly other limiting factors, is compared to the Actual throttle position. The 2 values should be within a calibrated range of each other. Both the PCM and the TAC module redundantly monitor the Commanded and Actual throttle position. This DTC sets if the TAC module detects the problem.
Conditions for Setting the DTC
* DTC P1518 is not set.
* The ignition switch is in the crank or run position.
* The ignition voltage is greater than 5.23 volts.
* Not in battery saver mode.
* The TAC module detects that the commanded and actual throttle positions are not within a calibrated range of each other or the PCM and the TAC cannot determine throttle position or both TP sensors are invalid.
* All above conditions met for less than 1 second.
Action Taken When the DTC Sets
* The PCM will illuminate the Malfunction Indicator Light (MIL) when this diagnostic runs and fails.
* The Reduced Engine Power message displays on the drivers information center.
* The PCM records the operating conditions at the time the diagnostic fails. The PCM stores this information in the Freeze Frame and/or Failure Records.
* If no other TAC System DTCs are set, the TAC System will operate in Reduced Engine Power mode. If certain TAC System DTCs are set at the same time, the TAC System either defaults to a more tightly restricted mode of operation if the TAC determines that limited safe operation is possible, or the TAC commands the engine to shut down.
Conditions for Clearing the MIL/DTC
* The PCM turns the MIL OFF after three consecutive drive trips that the diagnostic runs and does not fail.
* A last test failed (Current DTC) will clear when the diagnostic runs and does not fail.
* A History DTC clears after forty consecutive warm-up cycles, if this or any other emission related diagnostic does not report any failures.
* The PCM battery voltage is interrupted.
Important
The clear DTC info function may have to be performed twice in order to clear a Throttle Actuator Control System DTC.
Clear the MIL/DTC information using a scan tool.
Diagnostic Aids
The following may cause an intermittent:
* Poor connections. Check for adequate terminal tension. Refer to Troubleshooting Procedures, Checking Terminal Contact (Body and Accessories/Wiring Systems) for proper procedure.
* Corrosion
* Mis-routed harness
* Rubbed through wire insulation
* Broken wire inside the insulation
* Inspect the TAC module connectors for signs of water intrusion. When this occurs, multiple DTCs should be set and no circuit or component problems can be located.
* For an intermittent condition refer to Symptoms .
* If a repair is completed and the DTC was cleared using a scan tool on the same ignition cycle, the default action will not clear until an ignition cycle has occurred.
* When the TAC module detects a problem within the TAC System, more than one TAC System related DTC may set. This is due to the many redundant tests run continuously on this system. Locating and repairing one individual problem may correct more than one DTC. Keep this in mind when reviewing captured DTC info.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
5.
If the TP Indicated Angle does not follow the movement of the throttle blade, and no TP Sensor DTCs are set, there is a mechanical problem with the throttle shaft or the TP Sensor. Replace the throttle body assembly. Re-install the air inlet duct after you complete the repairs.
21.
When a problem is detected within the TAC System, more than one TAC System related DTC may set. This is due to the many redundant tests run continuously on this system. It is possible that locating and repairing one individual problem may correct more than one DTC. Keep this in mind when reviewing captured DTC info.
The C1278 is a sympathy code that usually accompanies any code that put the car in REP mode. When the P1516 set, the C1278 came with it.
The C1281 is a steering position sensor code, but since your 97 doesn't have Active Handling, I wouldn't worry too much about it.
And don't worry about the U codes either. They are almost always there.
The Following 2 Users Say Thank You to Y2Kvert4me For This Useful Post:
Old 03-18-2010, 3:32pm   #4
1TZSLO
1TZSLO's Avatar
I researched some on CF and most say its a lose ground. But finding which one might not be fun. And thanks Y2k guess imma have to pull out my manual and start checking.
NOT STOCK
Old 03-18-2010, 3:59pm   #5
Check the wiring harness for the driver's side bank fuel injectors. There's a bracket for the evap system at the rear of the head that can chafe through the harness causing all kinds of funky issues.
Happened on my Z06... once in a while I'd get a random code.... clear it and nothing would happen. One day I started the car and it **** the bed... well the harness had finally rubbed through bad enough that it was in constant contact and shorting out.
Old 03-18-2010, 4:23pm   #6
1TZSLO
1TZSLO's Avatar
Just went and checked the fuses, seemed all to be fine.
NOT STOCK
Old 03-18-2010, 4:24pm   #7
1TZSLO
1TZSLO's Avatar
Good call, brb gonna check. Its good to have my car parked 10 feet from my shops back door haha.
NOT STOCK
Old 03-18-2010, 4:31pm   #8
1TZSLO
1TZSLO's Avatar
Checked didnt see any chaffed wires. but found the cap to the rail above the inj, off.
The end of the rail that faces towards the front of the car. Found the screw on cap and put it on.
NOT STOCK
