03-16-2010, 10:41pm | #1 | ||||||
The Old Guy
Gameroom Barn Bucks: $804566
Mods - Version 20.10
Well, it's starting again
First thing to do was to remove the rear quarters and bumper for some new mods. Munch and pops98 helped with this. Here's the buck I built, with help from pops98 and my friend Kevin, to hold everything together while doing the work. I've always thought the license plate trim on the TS rear looked kinda stuck on and hated the tabs sticking up on the plate. Kevin came up with an idea to fix this Removed everything and cut a 3/8" slot on the right side of the license recess. This will be used to insert the plate from inside the bumper. Started prepping everything up and figuring out exactly how I was going to this. The end result here will be that the plate surround will be molded into the bumper with no visible seam. Stay tuned, more to come...
03-16-2010, 11:02pm | #2 | ||||||
03-16-2010, 11:07pm | #3 | ||||||
Gameroom Barn Bucks: $870
Looks good.... keep up the nice work
The Following User Says Thank You to Shagster For This Useful Post: |
03-16-2010, 11:18pm | #4 | ||||||
What material did you find that can bond urethane to fiberglass and hold up over time and not pattern after a few heat cycles.
03-17-2010, 12:21am | #5 | ||||||
Detailing Guru
Gameroom Barn Bucks: $950
Hey Gary, you are not going to want to shoot any paint or clear on those parts with it held together. The reason being is that the rear fascia flexes at the seams where the quarters meet and the clear coat will slowly turn white as it begins to peel. It will first look like there is wax in the cracks but you'll figure it out later. It is best to separate those pieces and wrap the paint and clear around those edges.
Now guess how I know... Last edited by GB Vette; 03-17-2010 at 4:44am. |
03-17-2010, 4:47am | #6 | ||||||
Pretty sure when Gary is done there, there will be no seams at all.
03-17-2010, 5:23am | #7 | ||||||
Gameroom Barn Bucks: $2827
You just can't leave things alone, can you Gary?
Looking forward to the final product.
2008 C6 Z06 |
03-17-2010, 6:26am | #8 | ||||||
DAMN Pot,
You're boredom threshold must be very low. Ten minutes without tearing the car apart and you start thinking......... Nice work as usual. I'll be down in the next few weeks to pickup the 427 cruiser from VA Speed. We should get together. Kettle |
03-17-2010, 6:32am | #9 | ||||||
Detailing Guru
03-17-2010, 6:48am | #10 | ||||||
Coming along nicely coach!
03-17-2010, 6:55am | #11 | ||||||
Barn Stall Owner #78
Gameroom Barn Bucks: $1004569
Gonna be ready for Waterside?
03-17-2010, 7:45am | #12 | |||||||
The Old Guy
Stop by the barn anytime you're down here. Oh, wait a minute, you've already been down here twice and didn't come by Pot
03-17-2010, 8:22am | #13 | |||||||
03-17-2010, 8:22am | #14 | ||||||
Detailing Guru
03-17-2010, 11:05am | #15 | ||||||
03-17-2010, 11:15am | #16 | ||||||
The Old Guy
The Tiger Shark rear is urethane (PUR) and the L5 flairs are fiberglass
03-17-2010, 11:23am | #17 | |||||||
What Gary said
03-17-2010, 2:20pm | #18 | ||||||
Barn Stall Owner #58
Gameroom Barn Bucks: $13154
Wow more mods, you must never be done with your beautiful Vette and looking forward to seeing the finished product and your other planned mods
03-17-2010, 6:19pm | #19 | ||||||
Gameroom Barn Bucks: $560
OMG! Gary did you go off your meds again? Jezz, I disapear for a few months and look what happens.
03-17-2010, 8:51pm | #20 | ||||||
The Old Guy
Got a little done tonight. Here's the products I'm using for this project.
Here's the license frame prepped and fitted, ready for some adhesive. Here's the trim ring. I had to trim about 3/16" from the back of it for clearance. The four notches are for access to the license plate light screws. Munch took these pics while I was getting started with the first coat of adhesive. Here's the first coat sanded down and ready for the final coat. That's it for tonight
