Old 12-02-2009, 11:02pm   #1
Default Wheel spacers and lowering question
Wondering how thick a wheel spacer you could put on before you needed to get longer studs. I plead ignorance on any factors such as wheel thickness.
Also, when you are lowering the car do you need to take in to account the inside arc of the wheel well?
Old 12-03-2009, 7:39am   #2
Normally, you want at least 1-1 1/4" of stud coming through the wheel. There are exceptions, but it's a good rule of thumb. Not the inch measurements you been giving the wife, you want real world increments.
If you're running stock wheel sizes, you can lower all the way on stock bolts with no issues of rubbing. Running wider wheels? Can't help ya there, but someone else will chime in.
Old 12-03-2009, 2:02pm   #3
Willfulone
Charter Member - Vendor
Points: 7,866, Level: 62
Activity: 1.2%
Willfulone's Avatar
Gameroom Barn Bucks: $807
1/4 inch...then you can upgrade to some APR studs or similar...
Corvette Wheel Spacers
Peace
Chip
"Killing the Corvette Tax One Product at a Time"
Willfulone is offline   Reply With Quote
The Following User Says Thank You to Willfulone For This Useful Post:
Old 12-03-2009, 4:46pm   #4
Thanks, I will have to check how much thread I have now. I am running 19 x 11 on the back with 295/35/19 rubber and last time I pulled the wheels I had a very thin strip of plastic stuck to the wheel from it rubbing. I'd like to lower the car just a tad but as it sits now it's not gonna happen. Glad you cleared that up about the "real world measurements" at first I was thinking I'd need like 6 inches of thread!
Peace
Chip
Thanks Chip, those are the ones that got me thinking about this. I may be placing an order after the holiday.
Old 12-03-2009, 4:54pm   #5
Points: 35,009, Level: 100
With an 11" wheel, I'm not sure spacing them out much would help you, unless they are not optimally offset to begin with.
5/16" is about the max before needing longer studs.
And Chip, the hardware company that makes longer studs is ARP, not APR. (unless APR is some sort of copycat company).
Old 12-03-2009, 5:34pm   #6
I just want to get the tire off the wheel well so an 1/8 would do it but I was thinking a 1/4 just from looking at the wheel in relation to the fender. With a 1/4 I am thinking I could even lower it a bit and still be OK. But like I said, my main concern is getting the tire to not rub.
Old 12-03-2009, 8:50pm   #7
Eagleeye
Points: 10,779, Level: 71
Eagleeye's Avatar
Gameroom Barn Bucks: $2288
On dragstrip cars the tech guides required 3 1/2 full turns on lug nut was minimal with 5 turns optimal at 100 ft. lbs. torque if that makes sense ...
Old 12-23-2009, 2:14pm   #8
So if you use a wheel spacer such as a 1/4" what about the hub centric nature of the wheel???
Old 02-02-2010, 7:32pm   #9
I just ordered some 1/4" spacers from Chip, should be here soon! Keep your fingers crossed!
Old 02-02-2010, 7:50pm   #10
Garb55
Points: 17,083, Level: 90
Garb55's Avatar
Gameroom Barn Bucks: $7813
What is the Objective your trying to Achieve with the Spacers, Lower the car and have the wheel stick out farther but not rub?
My BAD, I need another Beer!
