07-21-2019, 8:29pm | #1 | ||||||
Barn Stall Owner #23
Barn Raising I
Gameroom Barn Bucks: $144580
Sand/Media blasting question.
I ran a media blasting cabinet for years, yer go. Problem is, it was operated off of an industrial compressor. We ran 90 pounds of pressure in the thing. Worked great
Now, I bought a small 40-pound capacity cabinet and I am running it off of a small 20-gallon compressor. At 100 psi, I can work for maybe a full minute before the thing kicks back on and I have to wait for the pressure to build up again. Any suggestions on what size compressor would be good, better, best? TIA |
07-21-2019, 8:32pm | #2 | ||||||
What are the specs on the cabinet you're using now?
07-21-2019, 8:35pm | #3 | ||||||
SOME Real Barner
Gameroom Barn Bucks: $2034428
If you have a decent motor and pump; just add a larger tank for more volume.
07-21-2019, 8:41pm | #4 | ||||||
Better:
07-21-2019, 10:00pm | #5 | ||||||
07-22-2019, 3:06pm | #6 | ||||||
Gameroom Barn Bucks: $1005893
5hp 80 gallon min...…….….9.5 CFM at 90 PSI for 40 lb and depends on media used
The Following User Says Thank You to allthrottleandsomebottle For This Useful Post: |
07-22-2019, 7:11pm | #7 | ||||||
I suspect the media cabinet owner's manual will have a suggested minimum CFM requirement at x pressure listed inside; or on their website. Go one size larger than minimum; the compressor will be happier for longer if it does not need to run WFO all the time just to keep up.
07-23-2019, 8:08am | #8 | ||||||
Barn Raising I
It is just a small 4.5 cubic foot cabinet
Don't sweat the petty things and don't pet the sweaty things. |
07-23-2019, 8:58am | #9 | ||||||
If you can lower the pressure at the gun, you may can get away with what you have for a short while. I think most shoot at 90PSI at the gun? A 2-stage, 80 gallon would be the minimum if you plan to do a lot of blasting. The more the compressor runs the more heat builds up in the air lines and may cause trouble with your blasting media. If it's only for a few projects maybe you can get away with it. If you are planning on doing a lot of blasting you will need to upgrade.
07-23-2019, 7:00pm | #10 | ||||||
07-23-2019, 7:30pm | #11 | ||||||
Barn Raising I
The Following User Says Thank You to Defib1961 For This Useful Post: |
