Share Thread Tools
Old 12-20-2018, 6:16pm   #1
SnikPlosskin
Barn Stall Owner #93
Points: 43,938, Level: 100
Activity: 12.9%
SnikPlosskin's Avatar
Default NCC-1701A Enterprise Refit
Well, due to an unfortunate Klingon misplaced soccer ball, the three foot long, fully lit Enterprise model I built more than ten years ago is roached. The upper hull saucer broke off and the wiring was just too short to fix. A couple weeks ago after I cut the wires to separate the disk, I could see that there was no way to repair it.
Oh well, 100+ hours down the drain.
So, I’m starting this build thread of a new 1/350 scale model. This time with far more sophisticated electronics and a new base that is waaaay more stable than the pile of crap on the original model.
There is a lot of modifying needed to make this work and I’ve started removing plastic that gets in the way of the lighting and modifying other areas to improve fit.
One of the first steps is light blocking with several coats of flat black, then a coat of flat white primer to make the insides reflect the light.
Some pics.
The Following 12 Users Say Thank You to SnikPlosskin For This Useful Post:
Old 12-20-2018, 6:18pm   #2
chinaski
Points: 30,181, Level: 100
Activity: 4.3%
chinaski's Avatar
COOL! Can't wait to see the end results!
chinaski is offline   Reply With Quote
Old 12-20-2018, 6:21pm   #3
SnikPlosskin
Activity: 12.9%
I’m not scratch building the electronics this time. I built my own circuit boards before. Screw that. Now there are full lighting kits on the market for this model that should save some time. Also, the LEDs are smaller and brighter. I’ll be using very fine magnet wire (33 gauge) to save some room. The previous model was stuffed to the brim with wiring and it stressed the seams.
This one will be far more precise and clean on the inside (that nobody will see) and will help if it ever needs repair since it will be more organized. There are about six different circuits for various navigation lights, strobes, photon torpedoes, a color shifting deflector dish, etc.
I’ll find a video and post it. Very neat if you are a huge dork like me.
The Following 9 Users Say Thank You to SnikPlosskin For This Useful Post:
Old 12-20-2018, 6:26pm   #4
chinaski
Activity: 4.3%
chinaski's Avatar
I dig it man. I binge watched a bunch of Star Trek recently, always have been a fan. Finished up the Enterprise series recently. Didn't give it much though when it came out, but I actually enjoyed it very much. The Vulcan science officer is pretty hot.
Old 12-20-2018, 6:47pm   #5
SnikPlosskin
Activity: 12.9%
Turn your audio off (why does everyone play that damn music with videos of this model?)
The electronics system has different modes. 5is is the dry dock startup sequence from the movie when they first fire up the new ship.
The hardest part is the painting of the complex five color pearl panels all over the model. The masking alone takes about 40 hours. It is sprayed over a semigloss white and looks amazing. But maddening.
The Following 3 Users Say Thank You to SnikPlosskin For This Useful Post:
Old 12-20-2018, 8:25pm   #6
CubSmurf
Points: 12,293, Level: 76
CubSmurf's Avatar
Gameroom Barn Bucks: $1475536
I have the most logical boner.
I love this.
I started one of these years ago, but just barely got into it before life got in the way.
Can't wait to see the progress!
CubSmurf is offline   Reply With Quote
The Following User Says Thank You to CubSmurf For This Useful Post:
Old 12-20-2018, 8:31pm   #7
SnikPlosskin
Activity: 12.9%
I love this.
It could take a year. We shall see. My experience with the first one should speed things up, plus I don’t have to create all the electronics although I will be adding some addditional lighting.
I need to figure out a base. The one that comes with it is crap. I was thinking of an oval shaped, black walnut base tapered like a river rock - sort of sleek oval blob. I’d then hollow out the bottom for the main controller board.
But I don’t really have any wood working tools. Not sure. Another option is basically a shallow box with a laser etched, plexi top. I’d spray the back side black then have the etching done and put a bunch of LEDs inside so the laser etching lights up.
I’ve seen some bases like that. But I ain’t paying $350 for one.
Old 12-20-2018, 8:34pm   #8
DAB
Barn Stall Owner #4
Points: 138,301, Level: 100
Activity: 42.4%
DAB's Avatar
How big a base is needed?
DAB is offline   Reply With Quote
Old 12-20-2018, 9:10pm   #9
Black94lt1
Barn Stall Owner #13
NCM Supporter '13,'14,'16,'17,'19,'20
Points: 19,486, Level: 96
Activity: 10.8%
Black94lt1's Avatar
Gameroom Barn Bucks: $425244
Do you know someone who’s good with wood? lol
Black94lt1 is offline   Reply With Quote
Old 12-20-2018, 9:10pm   #10
aerovette
Barn Stall Owner #7734
Points: 56,218, Level: 100
aerovette's Avatar
Nothing is irreparable. 3D printers can be your friend.
aerovette is offline   Reply With Quote
Old 12-20-2018, 9:19pm   #11
DAB
Barn Stall Owner #4
Activity: 42.4%
DAB's Avatar
Maybe....
Old 12-20-2018, 10:13pm   #12
SnikPlosskin
Activity: 12.9%
Not sure. The model is three feet long. I’m thinking probably 16” long by 8” wide. Let me think on that. You got a belt sander?
I thought about it but I may have burned one of the boards as I was testing the circuits. Plus I can’t figure out how to clamp it. The other issue is that the glue wasn’t holding. Lots of cracks all over the thing. I’d have to do a lot of repairs and then the intricate paint work would have been hosed.
I’m using a plastic welding liquid glue this time. And then 3M structural adhesive on high load areas. That design was never meant to be under the force of gravity. Big stress point where the dish meets the neck.
I’ll be using several types of glue this time. It ain’t never coming apart. It’s very hard to handle. Painting it stresses the joints. It’s a very difficult model.
Old 12-20-2018, 10:43pm   #13
DAB
Barn Stall Owner #4
Activity: 42.4%
DAB's Avatar
Stationary belt sander. Handheld belt sander. Oscillating spindle sander. Random orbital sander.
Tablesaw, two drill presses with mortising attachments, planer, bandsaw, router and router table, jointer, lathe (small ), about 120 clamps, various hand tools.
Got a picture of what you have in mind?
Old 12-20-2018, 10:47pm   #14
SnikPlosskin
Activity: 12.9%
So jealous. My dad was a cabinet maker and I grew up with a huge shop. Now I got nuthin. Life without a table saw is no life at all.
Let me give it some thought and do some engineering tests and make a drawing. It might need some lead in the bottom for weight. The support for the model is a single metal tube so that is easy.
Old 12-20-2018, 10:54pm   #15
aerovette
aerovette's Avatar
Maybe a base shaped like the shadow it casts.
Put a light directly over it, trace around it. BOOM, there's your template.
The Following 2 Users Say Thank You to aerovette For This Useful Post:
Old 12-20-2018, 11:06pm   #16
DAB
Barn Stall Owner #4
Activity: 42.4%
DAB's Avatar
Lead? Oh, I have lead...
Old 12-21-2018, 12:50am   #17
69camfrk
Barn Stall Owner #6969
Points: 54,879, Level: 100
Activity: 14.4%
69camfrk's Avatar
Gameroom Barn Bucks: $1071547
I love this.
Hell, I built an A-10 model for my youngest son several years ago, and I can't even add up the time I have in it to make it look right. So yeah, I know the model he's building is going to take a minute. The prep and paint is a nightmare.
69camfrk is online now   Reply With Quote
Old 12-21-2018, 11:08am   #18
SnikPlosskin
Activity: 12.9%
What if the base was shaped like the comm badge or is that too obvious?
Old 12-21-2018, 11:34am   #19
Sea Six
Barn Stall Owner #16A
Barn Stall Owner #16B
NCM Supporter '11,'13
Points: 145,847, Level: 100
Activity: 4.4%
Sea Six's Avatar
Gameroom Barn Bucks: $602908
Actually that would be pretty cool.
Sea Six is offline   Reply With Quote
The Following User Says Thank You to Sea Six For This Useful Post:
Old 12-21-2018, 12:51pm   #20
erickpl
Points: 11,962, Level: 75
Activity: 1.5%
erickpl's Avatar
Gameroom Barn Bucks: $111433
When you mentioned base, this was the first thing I thought of too.
erickpl is offline   Reply With Quote
Thread Tools
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright © 2009 - 2021 The Vette Barn
