11-16-2009, 7:55pm | #1 | ||||||
Washer fluid sending unit
Does anyone know what the sending unit in the washer fluid tank is supposed to read when open and when closed? In Ohms I'm guessing. I checked mine and there is a difference between open and closed but I still get a low fluid message so maybe it's out of range.
Oh yeah, also wondering what these things cost. Thanks.
11-16-2009, 9:15pm | #2 | ||||||
Gameroom Barn Bucks: $2288
Actually didn't know it has a sender so I can't help ! Is it a float type or do you know ? I'll be curious with you !!!
11-16-2009, 9:51pm | #3 | ||||||
It be a float type. I'll go take a pic... brb.
11-16-2009, 10:04pm | #4 | ||||||
Here she is...
This pic I will call closed which would be LOW washer fluid and I read .000 Ohms This pic I'll call open and reads 1. Ohms Anyone know if this is in spec or whatever? Also, there is a notch in the top where it goes in to the fluid tank so I know it's not upside down.
11-18-2009, 9:00pm | #5 | ||||||
This may be one for a resident GM engineer ! Not a clue here...
11-19-2009, 7:19am | #6 | ||||||
Don't know if it's in spec, but if it keeps giving a low reading, then I would say it's bad.
48.62 at gmpartshouse.com Kind of an expensive friggin lil part. Dayum!
02-20-2010, 10:07pm | #7 | ||||||
Barn Stall Owner #50
Gameroom Barn Bucks: $149318
Munch, I got a low washer message, so I bought a sensing unit in 04, but after I got it in, my original started working perfectly, so I never installed it. I checked mine with a meter, and got the same results as you. Let me know when you go to the barn , and I will bring it with me , if it fixes your problem, I am sure we can make an arrangements.
The Following User Says Thank You to pops98 For This Useful Post: |
