Old 03-28-2024, 7:41am   #67961
Rikki Z-06
Barn Stall Owner #747-400
Points: 78,334, Level: 100
Activity: 17.6%
Rikki Z-06's Avatar
Robert
Rod
MikeB
Y'all
Rikki Z-06 is online now   Reply With Quote
The Following User Says Thank You to Rikki Z-06 For This Useful Post:
Old 03-28-2024, 7:43am   #67962
Rodnok1
Points: 42,726, Level: 100
Activity: 51.8%
Rodnok1's Avatar
Morning MikeB, Rikki
Rodnok1 is online now   Reply With Quote
The Following 2 Users Say Thank You to Rodnok1 For This Useful Post:
Old 03-28-2024, 8:05am   #67963
RMVette
Points: 63,878, Level: 100
Activity: 35.6%
RMVette's Avatar
Gameroom Barn Bucks: $311064
Originally Posted by Rodnok1 View Post
Morning Robert and the rest of youins
Morning Jim and Bear
Originally Posted by MikeB View Post
Morning all
Morning MikeB
Originally Posted by Rikki Z-06 View Post
Robert
Morning Rikki
RMVette is offline   Reply With Quote
The Following 2 Users Say Thank You to RMVette For This Useful Post:
Old 03-28-2024, 9:37am   #67964
Rodnok1
Activity: 51.8%
Rodnok1's Avatar
Been looking at cars over by you Robert... If i find one to look at we'll have to meet up. My last 2 cars both came from your area actually.
Bear so cranked up today, the spazergy is just oozing out of him. I wonder if I could bottle it and use it.. Hmmmm.
We had a slap fight yesterday... He always wins.
The Following User Says Thank You to Rodnok1 For This Useful Post:
Old 03-28-2024, 4:53pm   #67965
Rodnok1
Activity: 51.8%
Rodnok1's Avatar
This place has been dead lately...
Can't get pumps to work properly so in the bin they will go damnit.
One had air cylinder damage and it never worked. The 2nd something is wrong as getting hydraulic oil on air side which is no Bueno. The money they get for parts is twice a new pump. I get new hoses with new pumps also.
Off to let Bear put a few more bruises on me.
Old 03-28-2024, 5:45pm   #67966
C3C7NIC
Barn Stall Owner #102
Points: 31,956, Level: 100
Activity: 16.5%
C3C7NIC's Avatar
Gameroom Barn Bucks: $23243
Morning Rikki, Nicole
Don't agree with Lars on points/condensor replacements, they are not ideal but once setup you can forget about them. HEI is really the way to go as the increased spark and readily available upgrades make a huge difference.
A high output coil and distributor(i used a Mallory setup) added hp and and higher rpm range. I added a CD box so could tune it exactly where wanted it. Plug gap was also increased. No way to get that performance out of points.
Leave the key in run position and can burn points up, always keep a set of point n condensor with tools in car if have them along with screwdrivers to change or file them so can get home. Back when amlady carried a nail file and is perfect for filing points and a pack of matches (cardboard) is good enough to set points.
God I'm old.
Will HEI affect the fitment under the hood? Want her to look close to original without being “NCRS” exact correct. Also want dependability.
Had roller cams out in instead of flat tap.
Found this carb online since mine is hodgepodge truck carb.
C3C7NIC is offline   Reply With Quote
The Following User Says Thank You to C3C7NIC For This Useful Post:
Old 03-28-2024, 5:48pm   #67967
C3C7NIC
Activity: 16.5%
C3C7NIC's Avatar
4 more slats for the pergola and done! That was 1078 screws. 🤯Click image for larger version
The Following 2 Users Say Thank You to C3C7NIC For This Useful Post:
Old 03-28-2024, 6:45pm   #67968
Anjdog2003
Due to inflation they are no longer free
Points: 56,363, Level: 100
Activity: 70.1%
Anjdog2003's Avatar
Gameroom Barn Bucks: $324490
Attachment 99151
Baller problems
Anjdog2003 is online now   Reply With Quote
The Following 2 Users Say Thank You to Anjdog2003 For This Useful Post:
Old 03-28-2024, 6:53pm   #67969
Rodnok1
Activity: 51.8%
Rodnok1's Avatar
Msd distributor may fit better and look more period than a traditional GM HEI as there is a significant physical difference. Not sure a traditional HEI fits anyways.
Pertronix just eliminates the points and condensor with possibly more consistent spark timing. Does nothing for increasing spark or anything else.
When they came out many long years ago I ran them in a couple of vehicles only because an HEI wouldn't fit or didn't want to modify aything.
Your current setup is good enough to get you rolling, and costs you nothing. You can always upgrade distributor at any point just as easy as now.
Hell just a better coil can wake an engine up some.
Old 03-28-2024, 6:54pm   #67970
Rodnok1
Activity: 51.8%
Rodnok1's Avatar
4 more slats for the pergola and done! That was 1078 screws. 🤯Attachment 99152
Do I need to get you a taller ladder so he's not standing on the top of that one and falls... I've never done that...
Old 03-28-2024, 7:08pm   #67971
Rikki Z-06
Activity: 17.6%
Rikki Z-06's Avatar
Old 03-28-2024, 8:09pm   #67972
Anjdog2003
Activity: 70.1%
Anjdog2003's Avatar
Thread of the Month
Old 03-28-2024, 8:51pm   #67973
C3C7NIC
Activity: 16.5%
C3C7NIC's Avatar
I chewed his a$$ out a few times. He’s an accident waiting to happen.
We have taller ladders but he thinks this one is lighter and easier to move. Since he had to move it every 2 screws) and there were HUNDREDS, this was his selection. 🙄
The Following 3 Users Say Thank You to C3C7NIC For This Useful Post:
Old 03-29-2024, 5:15am   #67974
Old Ben
Points: 28,051, Level: 100
Activity: 14.4%
Old Ben's Avatar
Gameroom Barn Bucks: $1014987
Morning all.
Woke up this morning with a sore lower back. Did too much yesterday that I will pay for today.
Old Ben is offline   Reply With Quote
Old 03-29-2024, 5:52am   #67975
Rodnok1
Activity: 51.8%
Rodnok1's Avatar
Morning Ben and the rest of youins
Probably run get lumber for fence today.
Have a good day everyone
Old 03-29-2024, 6:09am   #67976
LisaJohn
Barn Stall Owner #1000
1000th member
NCM Supporter '13
Points: 32,560, Level: 100
Activity: 15.8%
LisaJohn's Avatar
Gameroom Barn Bucks: $2425793
Good morning.
Jim, I ran out of the Allegra last weekend. Apparently it was working because I had a nosebleed from sneezing Tuesday. Got some more Wed and it’s helping.
LisaJohn is offline   Reply With Quote
The Following 2 Users Say Thank You to LisaJohn For This Useful Post:
Old 03-29-2024, 6:25am   #67977
Rodnok1
Activity: 51.8%
Rodnok1's Avatar
Morning Lisa
Old 03-29-2024, 6:29am   #67978
Rodnok1
Activity: 51.8%
Rodnok1's Avatar
I have the same lightweight aluminum ladder I use constantly, I generally don't stand on the top unless on hard surface and have something sturdy to hang onto.
I don't bounce like I used to.
One of the benefits of that ladder is it flexes so if get out of shape it's forgiving plus it doesn't kill you after you fall when it falls on you... So I've heard
Old 03-29-2024, 6:33am   #67979
RMVette
Activity: 35.6%
RMVette's Avatar
Morning all.
The Following User Says Thank You to RMVette For This Useful Post:
Old 03-29-2024, 6:39am   #67980
MikeB
Barn Stall Owner #115
Points: 22,512, Level: 100
Activity: 8.3%
MikeB's Avatar
Gameroom Barn Bucks: $610854
Annual physical in an hour.
MikeB is online now   Reply With Quote
