Old 08-26-2010, 5:32pm   #1
allthrottleandsomebottle
Points: 23,599, Level: 100
Gameroom Barn Bucks: $1005893
Default High heat powder coating Stainless Works 3" x-pipe & Kooks 2" race headers
Well, the headers/X pipe will be powder coated within a week.
All done by Art in Williamsburg right across from watercountry at:
Virginia Powder Coating, Virginia Custom Ceramic Coating
Here is the completed catback, the X-pipe is a Kooks setup for my 01'
Once installed, I will snap some pics and give feedback on the heat reduction
The Following User Says Thank You to allthrottleandsomebottle For This Useful Post:
Old 08-26-2010, 5:50pm   #2
Oh, now that is just F'n sick! I have wanted black exhaust since I got my car, Munchy want.
Old 08-26-2010, 6:28pm   #3
Garb55
Points: 17,083, Level: 90
Garb55's Avatar
Gameroom Barn Bucks: $7813
Old 08-27-2010, 8:54pm   #4
Dam that looks great!
Old 09-24-2010, 7:38am   #5
This is a ceramic PC..........you can get just about any type of stuff in powder now.
Here is the headers & X pipe
It can only help with heat reduction.
I have all my exhaust off now. Heat taping some lines and adding a few mods while I am there.....like this used oil cooler I couldn't pass up for the $$$:
Old 09-24-2010, 7:44am   #6
DropTheTop
Barn Stall Owner #777
Points: 22,113, Level: 100
DropTheTop's Avatar
Gameroom Barn Bucks: $6589249
Man, that is just awesome!
Old 09-24-2010, 6:40pm   #7
AND THEN SOME!!! I really, really, really, really, really like that a lot.
Old 10-24-2010, 10:05pm   #8
Got the PS in yesterday..........did everything the instructions said, tryed everything my 30 years of wrenching has shown me...and still had to lower the front subframe to the bottom of the studs to get this sucker in w/o disconnecting the a/c line or anything else. No biggy, disconnect the top arms, lower shock bolts and unclip the brake line bracket. Room is fine once in. DS doesn't look as bad
Old 01-12-2011, 9:19pm   #9
Got the DS in today.........had to leave loose the same as the PS and:
Remove PS pump off the alt bracket then the alt bracket from the head. lower the motor ~1" from max tilt and it fell right in with the sub frame lowered to near the end of the 4 subframe bolt ends .
Added less than 1/2 hour including pics, not bad.
Lots of room around all lines once boltd up. More pics to come once bolted all back together.
Old 04-11-2011, 7:57am   #10
Back up and running
30+degrees cooler on the oil
And I put the OEM catback off the 2000 coupe on for the stealth look and sound just for S & Gs ....................
Did not notice power loss............time for the strip after a tune tweak
Old 04-11-2011, 5:05pm   #11
30 degrees is pretty damn good! Those pipes really look great in black, I think I want to do my Ti's like that next time I have some extra cabbage.
I like this pic although it makes your license plate a lie.
Old 04-12-2011, 4:54am   #12
Hehehe...........but not my user id
Haven't run a bottle in years.........its really an oxgygen hit seems the motor is so old
Old 04-17-2011, 9:30pm   #13
And this is what it sounds like............
Old 04-28-2011, 7:57pm   #14
khblair
Barn Stall Owner #57
Points: 22,234, Level: 100
khblair's Avatar
Location: The original point & click interface was a Smith & Wesson
Gameroom Barn Bucks: $8632322
hmmm. very sweet!
khblair is offline   Reply With Quote
Old 04-29-2011, 7:30am   #15
Originally Posted by khblair View Post
hmmm. very sweet!
Hi Kim,
Nice pics in your albumn with your top down
Old 01-01-2012, 10:56pm   #16
And this is what it sounds like with 2 inch kooks headers, 3 inch kooks offroad and B&B Tri Flo Sport mufflers with by-pass mod I just put on..............it was just too dam quiet
