Old 06-16-2011, 3:37am   #21
zz4vetteguy
Points: 19,739, Level: 97
zz4vetteguy's Avatar
Gameroom Barn Bucks: $9916
Ok....so here are the codes I pulled off the car today...
P0131 - O2 sensor circuit low voltage (Bank 1 Sensor 1)
P0151 - O2 sensor circuit low voltave (Bank 2 Sensor 1)
P0101 - Mass or volume air flow circuit range/performance problem
P1133 - HO2S1 Insufficient switches (Bank 1 Sensor 1)
P1153 - HO2S1 Insufficient switches (Bank 2 Sendor 1)
Any thoughts?
Old 06-18-2011, 8:49pm   #22
03SlowZ06
Points: 3,068, Level: 36
03SlowZ06's Avatar
Gameroom Barn Bucks: $100431
Check all the fuses.
The Following User Says Thank You to 03SlowZ06 For This Useful Post:
Old 06-18-2011, 11:28pm   #23
zz4vetteguy
How dare you bring logical simple thinking into my world.
Old 06-18-2011, 11:52pm   #24
03SlowZ06
03SlowZ06's Avatar
Its a long shot, but worth a look. It would make more sense if the codes to be there constantly. If you want man just send me a PM and bring the car over to my place tomorrow if you have time. I will be working on swapping the Valve springs on my Z anyway. I can take a look at it.
Also the past half throttle boost makes sense if you do have an o2 issue. When the car goes into PE it uses predetermined tables not based on current readings.
Old 06-21-2011, 12:20am   #25
zz4vetteguy
Sorry, I slept right through your post...when I work midnights I don't usully get on here till I am at work and bored. I will take a look, also have some wires to look at too. Thanks
Old 07-27-2011, 2:32pm   #26
zz4vetteguy
Well, played with some wires, tapped some fuses, got my hands dirty, a little blood, and a LOT of cursing...I finally got around to buying and replacing the Mas Air Flow Sensor, and...
...well to quote Elton John and Austin Powers...
THE BITCH IS BACK", "YEAH BABY, YEAH"!!!
Old 07-27-2011, 3:18pm   #27
RetiredSFC 97
Barn Stall Owner #63
Points: 4,728, Level: 46
Activity: 2.8%
RetiredSFC 97's Avatar
Gameroom Barn Bucks: $32270
Glad to hear that!
RetiredSFC 97 is offline   Reply With Quote
The Following User Says Thank You to RetiredSFC 97 For This Useful Post:
Old 07-28-2011, 10:22am   #28
allthrottleandsomebottle
Points: 23,599, Level: 100
Gameroom Barn Bucks: $1005893
Hahaha.............good detective work sherlok
The Following User Says Thank You to allthrottleandsomebottle For This Useful Post:
Old 07-28-2011, 12:15pm   #29
zz4vetteguy
I did not do it alone, thanks to all of you who gave me tips and pointers and things to look for!!!!
