Old 05-30-2011, 1:05pm   #1
zz4vetteguy
Points: 19,739, Level: 97
zz4vetteguy's Avatar
Gameroom Barn Bucks: $9916
Default Does it need coffee????
So, my 01 vert seems to be a little tired over the past two weeks. It seems to have lost some (well a lot) of it's umpf. It does not have the throw you back power that it used to have. No, it is not me just used to the car, the other morning leaving work after a rainy night, I mashed the go fast pedal and on a wet road it would not break loose the tires.
Besides a lack of power it still seems to run OK, and it has not thrown any codes. The only thing I have noticed is that my gas mileage has gotten a little worse.
Anyone have any thought, suggestions, or ideas?
Old 05-30-2011, 7:29pm   #2
Shrek
Points: 14,057, Level: 81
Shrek's Avatar
Gameroom Barn Bucks: $2387
I've heard of clogged cats acting like that. Check the exhaust flow at the tips during idle, then have someone rev it.
Shrek is offline   Reply With Quote
The Following User Says Thank You to Shrek For This Useful Post:
Old 05-31-2011, 12:44am   #3
zz4vetteguy
Hmmm, that is a good idea, the headers from the marathon install do run a little warmer, and I know when I installed the ZZ4 crate motor in my C4 that the exess heat screwed up the cats....but hopefully that is not the case since these are the cats that came with the headers. I will try that tomorrow.
Thanks Jeff ....or was it your wife's idea.
Old 05-31-2011, 6:19am   #4
allthrottleandsomebottle
Points: 23,599, Level: 100
Gameroom Barn Bucks: $1005893
Bring it to my mini barn...........we can trouble shoot easy
The Following User Says Thank You to allthrottleandsomebottle For This Useful Post:
Old 05-31-2011, 7:40am   #5
03SlowZ06
Points: 3,068, Level: 36
03SlowZ06's Avatar
Gameroom Barn Bucks: $100431
I would suggest a basic tune up. Plugs, wires, filter, and some seafoam.
The Following User Says Thank You to 03SlowZ06 For This Useful Post:
Old 05-31-2011, 1:31pm   #6
RetiredSFC 97
Barn Stall Owner #63
Points: 4,728, Level: 46
Activity: 2.8%
RetiredSFC 97's Avatar
Gameroom Barn Bucks: $32270
Someone on the other place just had this issue and it was clogged cats.
RetiredSFC 97 is offline   Reply With Quote
The Following User Says Thank You to RetiredSFC 97 For This Useful Post:
Old 05-31-2011, 9:02pm   #7
zz4vetteguy
New plugs & wires less then a year ago, and I seafoam every January, and July.
Old 05-31-2011, 9:03pm   #8
zz4vetteguy
We will have to set up time to do that...my weekends are slammed the next two weeks...ugh
Old 05-31-2011, 9:09pm   #9
zz4vetteguy
On the drive into work tonight I tried to put it through the paces once I was on the interstate and at a normal throttle it runs ok, but at WOT it gets a little wonky. From a standing start at a stoplight, my 0 - 60 was almost 10 seconds.
I got a Check Engine light tonight, and pulled the codes with my code scanner...
P0101 "Mass or Volume Air Flow Range/Performance Problem"
P0102 "Mass or Volume Air Flow Circuit Low Imput"
sooo...I am thinking maybe my MAF Sensor...yes, no?
I just cleaned out my filter and cleaned out the Varamam imput ducts so I know they are not clogged.
I reset the codes to see if they pop up again on my drive home tomorrow.
Old 05-31-2011, 9:11pm   #10
zz4vetteguy
I had my father put his hand over the exhaust when I got home, and he said there was flow at idle and a noticable change at a moderatly light rev.
Old 05-31-2011, 9:11pm   #11
zz4vetteguy
I would hate to think I would have to bore out the cats on this one too.
Old 06-05-2011, 10:43pm   #12
zz4vetteguy
Steve, need to find time to get up with you...just so I can make sure it is the MAF
Old 06-06-2011, 6:08am   #13
PM me and we can see about a day
Old 06-06-2011, 6:39am   #14
Also some things to check......vacumn leak, wire chaff through, etc:
GearChatter.com :: View topic - DTC P0101
Old 06-07-2011, 4:53am   #15
zz4vetteguy
PM is on the way...maybe we can make a tech day out of it....I am sure I am not the only one who will ever have this problem.
Old 06-07-2011, 4:54am   #16
zz4vetteguy
it is 5 till 0600 and my shift is almost over, I am WAY to tired to comprehend that right now...LOL
Old 06-07-2011, 6:18am   #17
PM sent................RIF...........READING IS FUNDEMENTAL to trouble shooting.....suck it up buttercup!!!!!!
I have done plenty of those shifts.............your suppose to be wide awake, drink more crown at 2-3am
Old 06-08-2011, 12:56am   #18
zz4vetteguy
Steve I tell ya, I have drank more coffee in the month I have been doing overnights then I have in the past two years.
Old 06-13-2011, 3:46am   #19
zz4vetteguy
I got a new code yesterday when I was driving home and I hit clear instead of save...ugh.
It was doing something different on the way home from work yesterday. I could press on the accellorator a little, halfway, or 3/4 and the car would maintain a steady speed, then after a few seconds, something would kick in, and it was like someone gave the car a shot of NOS. Even at 70mph, it would throw me back in the seat.
Old 06-13-2011, 12:32pm   #20
RetiredSFC 97
Activity: 2.8%
Could the throttle position sensor cause this?
