Old 11-01-2010, 7:16am   #1
lutzdog
Points: 11,003, Level: 72
lutzdog's Avatar
Gameroom Barn Bucks: $595211
Default grand sport wheels on c5
I am in the market for wheels and i have seen alot of options out there. I like the grand sport wheels but have not seen them on a c5. Does anyone have this option? I am almost sold on the c6 zo6 rims unless i can catch a glimpse of these in use to sway my decision. If so can i see a pic.
Old 11-02-2010, 7:14am   #2
allthrottleandsomebottle
Points: 23,599, Level: 100
Gameroom Barn Bucks: $1005893
I was looking also.........based on the review--------NO-----------
+79mm rear offset is a killer. Would stick out even for my tub job 97'
I have seen some pics on a std C6..........can you say tire stick out 1"+
Old 11-02-2010, 7:44am   #3
lutzdog
lutzdog's Avatar
damm. guess its c6 zo6's
Old 11-02-2010, 6:49pm   #4
paulp
Points: 8,191, Level: 63
paulp's Avatar
Gameroom Barn Bucks: $992
i believe the grand sport wheels are the same size as the c6 z06 wheels
01 z06
paulp is offline   Reply With Quote
Old 11-02-2010, 7:11pm   #5
Points: 35,055, Level: 100
The std C6 19x10" wheel is a 79mm offset, and when fit on C5s they are too tucked in, in fact most need spacers to keep them from rubbing the inner liner, and/or to look respectable.
The 19x12" wheel on C6 Z06 and GS's are actually 59mm offset, and if you understand how offset works, that lower offset pushes the centerline of the wheel's width out more, which makes a tub job irrelevant.
Because yes, a 19x12"-59mm, will be close, but poke out of the fenders very slightly on a stock C5 body.
Ideally, a 12" wide wheel for a tubbed C5 to keep a flush fender fitment would be in the 74-76mm ballpark. (More offset = more wheel moves inward).
In contrast, those with aftermarket rear fender flares who do want the wheel to stick out more, are usually looking at a 45-48mm offset ballpark for that same 12" wheel width.
So, even if there were such a thing as a GM 19x12" - 79mm offset wheel (and there isn't), it would likely fit your tubbed C5 quite well.
Old 11-03-2010, 7:14pm   #6
The GS +40/+59 offsets would look bad on a C5 IMHO.........
You are correct, I wasn't clear on the +79mm offset issue
It would be to deep for my C5 any way as a +74mm is what I run to be near flush depending on tire manf & size. I would need to run a 5mm spacer.....
I understand offset VERY well as this is what I have played with to date:
My consolidated list of personal stock
Wheel size,type, & weight in lbs ea
OEM MAG 17 x 8.5, 17.5
OEM MAG 18 x 9.5, 19.5
OEM MAG 18 x 9.5 w/ new Yoko 295/35-18 AVS sport non-runflats, 50
OEM MAG 18 x 8.5 w/ new Yoko 275/35-18 AVS sport non-runflats, 46
PWO 5 spoke Y2K repos 17 x 8.5 +58mm, 20
PWO 5 spoke Y2K repos 18 x 9.5 +65mm, 23
HRE 18 x 9.5 545 w/ clear center +58mm, 22
HRE 18 x 12 545 w/ clear center +74mm, 27
PWO 17 x 8.5 +58mm w/ oem runflat 245/45/17 (8/32 tread), 50
PWO 17 X 8.5 +58mm w/ new MT ET Street 26 x 11.50 x 17 with TPS & lots of weights, 45
OEM MAG 17 x 8.5 w/ NITTO 555 275/40/17 (1/2 tread), 45
OEM MAG 18 x 9.5 w/ stock OEM 275/40/18 runflats, 53
OEM MAG 17 x 8.5 w/ stock OEM 245/45/17 runflats, 47
OEM MAG 17 x 8.5 w/ new MT ET Street Radial 275/40/17, 47
OEM MAG 18 x 9.5 w/ new Hoosier R3S05 275/35/18 road race radial 4.5 32nds tread with std valve stems 42
CCW drag pack rear 16 x 10 classic full polished with well worn MT ET Street 26 x 11.50 x 16 (1/32 tread) with center cap, 34
CCW drag pack rear 16 x 10 classic full polished with 1/2 worn MT ET Street 26 x 11.50 x 16 (3/32” tread) with center caps, 38
CCW drag pack front 16 x 5 classic full polished with like new Firestone deluxe champion 5.00/5.25-16 (10/32 tread) with center cap, 33
OEM runflat 275/40/18 worn to wear bars, 29
Bridegstone expedia S-01 345/35/18 (9/32 tread), 37
New MT ET Street Radial 275/40/17 (6/32 tread), 30
New MT ET Street Radial #3784R P315/30R18 26X12.50R18 (6/32 tread), 28
New MT ET Street 26 x 11.50 x 17 tires (6/32 tread), 25
MT ET Street 26 x 11.50 x 16 tires worn out (1/32” tread) 15.75
MT ET Street 26 x 11.50 x 16 tires (3/32” tread) 18
OEM runflat 245/45/17 (8/32 tread), 29
BFG G-force drag radial 345/30/18 new, 30
BFG G-force drag radial 345/30/18 1/32nd, 29.5
BFG KDW2 295/35/19 new, 32
Yoko 295/35-19 AVS sport non-runflats (2/32 tread), 29
Toyo Proxes RA1 335/30ZR18, new, (8/32 tread in the middle & 6/32 outside edges), 33.2
Topline 5 spoke Y2K chrome repos 18 x 10.5 +58mm offset rims w/ new MT ET Street Radial #3784R P315/30R18 26X12.50R18 , 58
Topline 5 spoke Y2K chrome repos 18 x 10.5 +58mm offset rims w/ new 275/35/18 BFG G-force TA drag radial, 53
Bob' House of Wheels 18 x 10.5 Chrome Y2K repos widened to 18 x 12. Work was done by Weldcraft Wheels.+56mm (with the 1.5" strip inserted, they should be right at 9.375" backspace, 31
HRE 18 x 12 545 w/ 345/30/18 BFG DRS, 57
HRE 18 x 9.5 545 w/ clear center +58mm w/ new 275/35/18 BFG KDWs, 52
HRE 18 X 9.5" 545 full polished w/ Yoko 265/35-18 AVS sport non-runflats (8/32 tread), 50
HRE 18 x 12 545 w/ 345/35/18 EXPEDIA S-O1 (9/32 tread), 64
HRE 19 X 10" 545 w/ Yoko 295/35-19 AVS sport non-runflats (5/32 tread), 58
HRE 19 X 10" 545 w/ new BFG KDW2 295/35-19 (10/32 tread), 61
HRE 18 x 12 545 w/new Toyo Proxes RA1 335/30ZR18 & TPS, 58.4 lbs
My best 60' times on my 97':
New MT ET Street Radial 275/40/17 on C5 OEM 17 x 8.5 Magnesium wheels = 1.47 60'
Worn out 26 x 11.50 x 16" Mt ET Street on a 16 x 10 CCW drag pack = 1.51 60'
New 26 x 11.50 x 17" Mt ET Street on an PWO Y2K 5 spoke 17 x 8.5 = 1.53 60'
1/2 worn (3/32” tread) 26 x 11.50 x 16" Mt ET Street on a 16 x 10 CCW drag pack = 1.53 60'
1/2 worn 345/30/18 bfg dr on HRE 545 18 x 12 wheel = 1.49 60'
HRE 18 x 12 545 w/ 345/35/18 EXPEDIA S-O1 (9/32 tread) street tires = 1.75 60'
I have over 450 passes on these set-ups together and at different tracks....
My best 60' times on my 00' vert:
Topline 5 spoke Y2K chrome repos 18 x 10.5 +58mm offset rims w/ new MT ET Street Radial #3784R P315/30R18 26X12.50R18 = 1.69 60'
Topline 5 spoke Y2K chrome repos 18 x 10.5 +58mm offset rims w/ new 275/35/18 BFG G-force TA drag radial = 1.69 60'
I have over 150 passes on these set-ups together and at different tracks....
Interesting fact.........I love my MAG wheels for this reason:
* The Exports have a different offset measurement at the mounting point so as to bring the wheel and tire in-board under the fenderwell approximately 1/2 inch. These wheels can be identified by a Black Line drawn around the circumference of the wheel between the beads. This Black Line will be seen only when the Tire is removed from the Wheel
Domestic / Export Magnesium 5-Spoke RPO N73 **
Front - 17" x 8.5" - #9592638
Rear - 18" x 9.5" - #9592640
** These wheels have always had the offset to meet Export requirements
C6 non Z06/GS
Front 18 x 8.5, +56 mm offset
Rear 19 x 10, +79 mm offset
C6 Z06 & GS (SPEEDLINE is the manufacturer for the GSs)
front: 18 inch x 9.5 inch, +40 offset
rear: 19 inch x 12 inch, +59 offset
FWIW, here are a few photos I've seen from posts on the forum of OEM Z06 wheels and tires mounted on a non Z06 C6. I may slap some GS wheels on one of my C5s for some pics just to see..........
Here's a pic just to give you an idea of the GS wheels on a C5 look..........there was a set for a good price and I was looking.......but they will not fit right and look poor on a C5 IMHO
PM me if ya need anything else Lut
The Following 2 Users Say Thank You to allthrottleandsomebottle For This Useful Post:
Old 11-03-2010, 7:57pm   #7
lutzdog
lutzdog's Avatar
That helps. Thx alot. BTW those rims look hawt on the c5
Old 11-03-2010, 10:01pm   #8
They look hot on the C5 because its a photoshop job, and the wheels were incorrectly "sized", as they appear more like how 19/20s fit a lowered C5.
The rest of the pics were of a C6 which is a narrower (body) than the C5 is (gee, maybe also why they changed C6 offset to be tucked in more?). So, the widebody 19x12s will definitely stick out of base C6 fender more than they will mounted on a C5. Not a valid comparison.
I'll let Steve further guide you with specific fitment and offset questions, since he knows it all, but be sure to keep in mind which day of the week you ask him...
The wheel that sticks out on Tues may very well need a spacer on Wed.
Old 11-04-2010, 6:31am   #9
bak
Nice attack........says the kettle........that’s exactly why I deal with PMing and rarely post.
Never claimed to be a know it all, but I am confident and confirmed correct in many of my “hands on”C5 areas
Sorry to clutter your thread Lutz with BS........... A real moderator would know better to PM his inferiority issues vice an irrelevant call out of a Personal attack/hostility in an open thread and take the thread off track
Old 11-04-2010, 10:41am   #10
DropTheTop
Barn Stall Owner #777
Points: 22,113, Level: 100
DropTheTop's Avatar
Gameroom Barn Bucks: $6589249
Old 11-04-2010, 12:32pm   #11
FYI there are pics floating around on CF of a black C5 with silver painted GS wheels. There's also a yellow Z06 sporting black OEM Z06 "spyder" wheels. They stick out about 1/2" in the rear and a smidge up front. You might be able to get away with it if you run a bunch of negative camber.
Old 11-04-2010, 7:04pm   #12
Garb55
Points: 17,083, Level: 90
Garb55's Avatar
Gameroom Barn Bucks: $7813
I'm running 08 Z06 oem chrome speedlines on my C5. I also think the Spyders would look Sweet! Still working on getting it lowered!
https://www.thevettebarn.com/forums/c...html#post30664
The other place!
C6 Z06 wheels fit? - Corvette Forum
Old 11-04-2010, 7:28pm   #13
Yep, and had you done that, there would be yet another misinformed person out there.
Kinda defeats the purpose of a public discussion forum, does it not?
Old 11-05-2010, 5:32am   #14
lutzdog
lutzdog's Avatar
Old 02-05-2014, 3:20pm   #15
CorvetteTrev
Points: 331, Level: 6
Activity: 1.1%
CorvetteTrev's Avatar
Gameroom Barn Bucks: $535
biggrin
I love my 04Z with 12" OEM GS WHEELS ON IT, IT RIPS, AND I GET A LOT OF COMPLIMENTS. I RACE IT. IT'S ALL GOOD. LOVE THE STANCE WITH THE WHEELS, OUT!
CorvetteTrev is offline   Reply With Quote
Old 02-05-2014, 3:22pm   #16
CorvetteTrev
Activity: 1.1%
I have such better pictures but the files are too big to upload from my cell phone camera
Old 10-15-2015, 6:05pm   #17
jigga32.cd
Points: 68, Level: 1
Activity: 0.5%
jigga32.cd's Avatar
Gameroom Barn Bucks: $515
Can you send me some pics of urs Iam looking to get some blk wheels. Wht size are on ur car 17/18 or 19/20 my num is 804-922-6878
jigga32.cd is offline   Reply With Quote
Old 10-15-2015, 6:07pm   #18
jigga32.cd
Activity: 0.5%
jigga32.cd's Avatar
Nice is tht a vette wheel
