Old 01-13-2010, 4:32pm   #81
Zippers!!
Old 01-13-2010, 4:59pm   #82
Shawn has the motor pulled down and PM'd me.
A couple things,measured your bores smallest part of the smallest bore is 4.0050
largest part of the largest bore is 4.0085-that's .0035 difference.Some bore had as much as .0025 taper and out of round-pretty much like every other SDxx engine.The pistons were 4.0005-so you had as much as .008 piston to wall clearance.
I'll send you some picks tonight but you can see where the main caps were walking around due to the stock main bolts.
It sounds bad but it demonstrates to me the Shawn will have it right when I get it back.
No wonder it didn't make any power.
Old 01-13-2010, 8:33pm   #83
All broken down:
Looks like it was burning some oil after all.
Pistons and rods out.
You can see where all of the main caps were walking with stock bolts. For some reason I thought I had ARP mains.
16-18k on this LS2 chain. Being replaced with a Cloyes adjustable setup.
Bare block ready for some serious machine work.
Old 01-13-2010, 8:44pm   #84
Shawn @ Va Speed
Points: 1,699, Level: 24
Shawn @ Va Speed's Avatar
Gameroom Barn Bucks: $535
Originally Posted by WKMCD View Post
All broken down:
good looking finger
Shawn @ Va Speed is offline   Reply With Quote
Old 01-13-2010, 8:51pm   #85
Originally Posted by Shawn @ Va Speed View Post
good looking finger
I hate to think where that finger has been.
Great pics BTW
Old 01-13-2010, 8:56pm   #86
Shawn @ Va Speed
Great pics BTW
I actually love thinking about where it's been
Old 01-13-2010, 8:58pm   #87
Old 01-14-2010, 10:46am   #88
Why would the main caps be "walking" around even with stock rod-bolts? These motors have 6-bolt mains and are quite strong vs. most other motor setups out there. Just curious... also, what in those pictures shows evidence of movement?
Nice work so far... VaSpeed guys just left you front desk guy a message for a quote on a catback swap on a 2003 vert... or just removing the OEM pipes.
Old 01-14-2010, 9:33pm   #89
Shawn @ Va Speed
While they may have 6 bolts holding the main caps,only 4 are doing anything and they are small.You figure these fasteners were designed to handle 400hp a lighter rotating asy and 6200rpm.Add 50% more power,5% more rotating weight and 10% more rpm,the fasteners are just not happy.This is the main reason the ls7 main caps are doweled.
Old 01-15-2010, 7:10am   #90
Shawn put some incredible pics and comments on machining the liners on ls1tech.com. I hope he puts them up here also.
L92 DynoJet Numbers Plus Plan "B" - LS1TECH
Old 01-15-2010, 8:41am   #91
That's a logical explanation... didn't realize the rotating assembly was heavier. What markings denote they were moving around vs. a normal machining mark?
Old 01-15-2010, 2:36pm   #92
Normal machining marks only go in one direction. If you look at the pics closely, you can see several places where there are marks that go across the grain of the machining process marks. That's an indication of "walking". The cap is moving side to side, or forward and backward.
At least that's what my "shade tree" eye is seeing.
Old 01-15-2010, 8:47pm   #93
Shawn @ Va Speed
Here are some pics of the sleeve machining and installation process.
first thing is the block setup in the cnc-here the probe is finding the crankshaft center line
now we find the camshaft centerline-this way we ensure the bores and decks are exactly 45 deg from the camshaft to crankshaft centerline
now we probe the bore locations to determine the location of the bores
now we probe the decks in 6 locations on each bank-this tells us the height and straightness of the decks
here is a report of the locations of the bores and the deck heights-the x locations in parenthesis are the blueprint locations the one beside them are actual.All y locations should be zero
here we are rough boring-this will get us to within .020 of the actual size
block after rough boring
couple shavings underneath
finish boring-we need to be within .0002 when finish boring-that's 2 ten thousanth's of an inch.Accuracy is really the key here-if not bored perfectly-you can crack the block when installing the sleeve or you can have a loose sleeve.There are not too many machines out there that can hold this accuracy-we are very fortunate to have one.
bores ready for sleeves
sleeves installed
ready for final machining
Old 01-15-2010, 9:17pm   #94
Great pics and writeup. I was getting tired of those little 4 inch bores anyways.
Old 01-16-2010, 7:07am   #95
Great looking work.
Old 01-20-2010, 9:53am   #96
This from Richard at West Coast Cylinder Heads - proheads.com. We're sending the heads back to Richard for a little more work.
Shawn. This is a really nice presentation of the precision machining required for proper sleeving and block prep. The final result is a solid foundation for a performance build. Thanks for taking the time to show the step by step process.
Kevin is doing a great job keeping pace with the changing demand for larger displacement engines and spotlighting the technological progress of building a potent street machine. His decision to stick with the L92 heads will help demonstrate the true power potential of this mass produced part. It's truly an impressive production design.
Nice work Kevin
Richard
Old 01-20-2010, 1:10pm   #97
Now, let's see what they can do about increasing the flow numbers on those L92's.
Old 01-21-2010, 7:02pm   #98
The heads are on their way to Richard at WCCH. New CNC program and 2.20 intake valve. I've been running stock L92 vales all this time with no problems but we're going to upgrade the exhaust to stainless also while we're at it.
That is all.
Old 01-21-2010, 9:35pm   #99
Tell 'em to hurry up. I wanna see those numbers man!
Old 01-22-2010, 6:25pm   #100
We didn't get these over here.
Block all blueprinted and decked to .0001 tolerance.
