01-15-2021, 12:52pm | #1 |
Das Boat problem: Starboard motor won't start when warm.
This just started. When both engines on Das Boat are cold they start easily once both fuel pumps on each motor get the fuel up to 45psi. Now, after they are warm, the port engine will start easily but the starboard won't.
They are 541 BB Chebbies, TPI, and have the MEF-I Tune Port fuel injection and computer system. I'm thinking that it's vapor locking due to the fuel return line. What says OT? |
01-15-2021, 12:57pm | #2 | |||||||
Gameroom Barn Bucks: $856744
01-15-2021, 1:17pm | #3 | ||||||
don't shut off the starboard engine.
The Following 4 Users Say Thank You to DAB For This Useful Post: |
01-15-2021, 1:48pm | #4 |
01-15-2021, 2:05pm | #5 | ||||||
01-15-2021, 2:39pm | #6 | ||||||
Gameroom Barn Bucks: $3335
Does it eventually start?
How long did it take to start? What was for lunch?
01-15-2021, 2:40pm | #7 | ||||||
poke a hole in the fuel lines to see if the vapor lock goes away
The Following User Says Thank You to Chemdawg99 For This Useful Post: |
01-15-2021, 2:44pm | #8 | ||||||
I ASSume one fuel pump per engine........ so to check pressure on the starbord engine.....after that, are you getting spark?? stick a timing light on one of the wires.......I ASSume an HEI dizzy and R U running injection?? if so need a scanner......if not, maybe check the voltages at your temp sensors to compare them.....air and water......
01-15-2021, 3:00pm | #9 |
01-15-2021, 3:01pm | #10 | |
**** off. I hate you and hope you get the KungFlu a few times. |
01-15-2021, 3:02pm | #11 | |
01-15-2021, 3:11pm | #12 | ||||||
Goldilocks
Gameroom Barn Bucks: $1009320
01-15-2021, 3:13pm | #13 |
01-15-2021, 3:14pm | #14 | ||||||
Barn Stall Owner #113
Gameroom Barn Bucks: $306898
01-15-2021, 3:17pm | #15 | ||||||
01-15-2021, 3:18pm | #16 |
Go back to your high horse over there in PR. Nobody really likes you here and it's been openly stated by many members.
01-15-2021, 8:12pm | #17 | ||||||
Gameroom Barn Bucks: $572
Is the rail pressure bleeding off? Is there a start injector?
The Following User Says Thank You to 67 Fuelie For This Useful Post: |
01-15-2021, 8:21pm | #18 | |||||||
01-15-2021, 8:23pm | #19 | ||||||
01-15-2021, 8:24pm | #20 | ||||||
That One Guy
Gameroom Barn Bucks: $2192
Is it flooding? Does the BBC TPI ecm have a clear-flood mode you can try to eliminate that?
