12-13-2011, 2:22pm | #61 | ||||||
C4 Mod
... just to clarify, I am talking about adding somewhere around -.25 or -.5 degrees. Nothing REALLY extreme.
You should also specify that you want 0 - 1/16" toe-in on all 4 corners. |
12-13-2011, 2:31pm | #62 | |||||||
Front Camber -0.25° Caster: 5~7° Toe: 0 Rear Camber: -0.25° Toe: 1/8" per tire I know a C5 Z06 guy that runs -1.0 camber all around and he has no tire wear. That is beginning to attract me. What do you run on your C4? |
12-13-2011, 2:45pm | #63 | |||||||
C4 Mod
You don't even want to know what I run on the C4. I actually don't remember off the top of my head but it is in the -2.5 range. |
12-13-2011, 2:49pm | #64 | |||||||
Hmm, I should try a -0.75 front and -1.0. Whats the worst it could happen? I know where to buy tires. Not like our "non-google" friendly friend. |
12-13-2011, 2:52pm | #65 | ||||||
C4 Mod
You can see quite a bit of camber, both front and rear.
... and this is why. At speed, I have a tire exactly where I want it to be with as much contact as possible. |
12-13-2011, 2:55pm | #66 | ||||||
Check
12-13-2011, 2:57pm | #67 | ||||||
C4 Mod
The worst that could happen at -.75 or -1.0 (other than tire wear) would be that the car will follow the road a lot more than it does now. The 96 is a handful on those rare occasions I drive it on the road at highway speeds. It will randomly take off and go wherever it wants to go.
12-13-2011, 3:00pm | #68 | ||||||
Gameroom Barn Bucks: $1524159
Curious about this conversation between Pete and Bryan. What are the STOCK settings? Would it be worthwhile for an average corvette owner like me to tweak those settings next time I have it aligned, or what would be a common ground setting?
12-13-2011, 3:01pm | #69 | |||||||
I know caster is not a big deal for your needs. |
12-13-2011, 3:03pm | #70 | |||||||
Front Camber: 0° Caster: 5~7° Toe: 0 Rear Camber: 0° Toe: 1/8" in per tire. |
12-13-2011, 3:28pm | #71 | ||||||
C4 Mod
12-13-2011, 3:29pm | #72 | ||||||
C4 Mod
Personally, if I was getting my car aligned, even if it was only a weekend warrior daily driver, I would go with a little more negative camber and a little more toe-in than stock.
12-13-2011, 3:36pm | #73 | |||||||
I read that tow zero to negative adds on responsiveness in the front. What Am I missing? |
12-13-2011, 6:40pm | #74 | ||||||||
12-13-2011, 9:06pm | #75 | ||||||
Gameroom Barn Bucks: $2013824
I tend to like near zero front toe settings, but the C4 has such wide tires already, a little toe will help it drive straight. My C6 is all over the road as it has the Z51 alignment, which is more toe neutral and has a wee bit more neg camber.
My C4 had so much neg camber in the rear when I got it, I raised the ride height slighlty and eye-balled to a near 0 camber. maybe there is .5 deg negative...maybe. the tire wear is great though. Don't want to spend $$ because the toe settings are good and there is no edge feathering. it understeers on tight corners- so I think it is pretty much at conventional settings. |
12-14-2011, 8:16am | #76 | ||||||
C4 Mod
Not missing anything... the factory specs are really conservative with a huge +/-. You could be all over the place and still technically be in GM spec. Most alignment places are perfectly fine with that and aren't going to get you exactly where you want it. I would go with a much tighter tolerance and tell them somewhere from 0 to -1/16.
12-14-2011, 10:46am | #77 | |||||||
Front Camber: 0° Caster: 5~7° Toe: 0 Rear Camber: 0° Toe: -1/16" in per tire. |
12-14-2011, 10:57am | #78 | |||||||
C4 Mod
That would be an improvement. It would do great in a straight line and better in the corners than factory. If it were mine, I would go a little farther to -.25° or -.5° camber in the front on a 100% street car. You shouldn't see any negative tire wear because of that and it should still keep it's "friendly" street drivability. |
12-14-2011, 2:16pm | #79 | |||||||
Front Camber: -0.25° (or -0.5°) Caster: 5~7° Toe: 0 Rear Camber: 0° Toe: -1/16" in per tire. |
12-14-2011, 2:29pm | #80 | ||||||
C4 Mod
