Old 02-18-2013, 6:15pm   #1
allthrottleandsomebottle
Points: 23,599, Level: 100
Gameroom Barn Bucks: $1005893
Default It finally begins............
Last month........
414 cid tear down
Chainfall came in handy for the hood removal
Had a couple hours yesterday, coils, covers @ alt gone too
knew the intake was cracked in the back......
Intake runner has been worked a lot
The intake was rubbing on the firewall and poor welding/fab of the aluminum made the crack..........
I found the crack after we could not tune the idle worth a shiattttttttttte. Tape worked fine
No gas on this car that I know of.
bad valve cover gasket = leak!
Old 02-21-2013, 1:48pm   #2
So, whatcha putting back on it? Fixing this intake or going with something else?
Old 02-21-2013, 6:47pm   #3
Depends on how much $$$ to fix the short block.
Since its tuned for it, most likely I will repair & reinstall to keep $$$ down
Old 03-04-2013, 10:26pm   #4
Got some more done.............pretty close to yankin
Old 05-19-2013, 8:49am   #5
Not much left before I yank it:
Poor PCV set up they had shows on the rockers.....
One head stud............interesting build
A little mis-alignment on the #6 exhaust push rod.....
Old 08-12-2013, 8:27am   #6
tbrent
Points: 7,109, Level: 58
tbrent's Avatar
Gameroom Barn Bucks: $135
What ever happened here? Did you just freshen up and get a new intake or did you get crazy with it or what? Whatever you did, I know I will be jealous so I don't know why I am even asking.. I just got rid of my stock manifolds and pup cats on my '01 The truth will set you free! That kinda hurt to share in a thread about a big cube motor..
tbrent is offline   Reply With Quote
Old 08-12-2013, 4:39pm   #7
Hahaha.............lots more power out there than this!
I have about 1 hour left.........to yank it
Old 08-18-2013, 7:58pm   #8
Some more done...........time to yank it next!
Old tools come in handy
I used this old "S" wrench to break free the bolt it is on...........couldn't get anything else on it with the stuff in the way. I wanted to leave the tunnel plate on to hold up the torque tub & rear once I pull the motor
If you haven't see the clutch fluid coupler apart.....
Old 08-25-2013, 6:12pm   #9
I got a great deal on this Friday on the way home from work from harbor Freight........$16.95 out the door!
The biggest thing for one person, is this tool and to have the torque tube jacked up to allow the engine to be above the front cradle allowing you to easily twist it out. Ileft the tunnel plate in to support the to tube, plenty strong for the job.
My 3 ton chain fall with chain bag(stylish eh?) was great!
This is how much the lower cradle has to be dropped to clear the oil pan/steering
Here is where the 2 x 4 & jack go on the tube:
Just about out!
OUT!!!
Clutch dust!
And my tire dolly does fine to push it around till I get it on the engine stand, thats next!
Old 08-30-2013, 4:43pm   #10
PortDawg
Charter Member - C3 Mod
Barn Stall Owner #34
NCM Supporter '15
Points: 31,441, Level: 100
PortDawg's Avatar
Gameroom Barn Bucks: $173
If you need a stand, I have one you can borrow..
Old 09-03-2013, 8:13pm   #11
Thanks for the offer bro, I got one
Old 11-03-2013, 9:24pm   #12
Update....................see if you can tell what may be the problem from the oil pan..
Old 11-13-2013, 8:01am   #13
And the problem...........
Of course the crank hitting the piston skirts didn't help......
Pistons don't look good either..........no wonder it burned oil!
Looks to me like original start up oil starvation..............no priming!
