03-23-2024, 11:04am | #1 | ||||||
1965 Fuelie convertible
Flasher relay seems to function fine, rear signals and brake lights and license plate light are fine. When I pull out headlight switch halfway for parking lights, however, front parking lamps come on very dim. When headlights are on-nothin'. Turn signals up front don't come on even though flasher indicator lights on dash work. Any ideas?
03-25-2024, 12:27pm | #2 | ||||||
Soft short would be my guess. Original harness?
03-25-2024, 12:28pm | #3 | |
03-25-2024, 3:54pm | #4 | ||||||
Barn Stall Owner #17
Poor/oxidized wiring ground would be my first guess.
Scott
03-25-2024, 5:31pm | #5 | ||||||
Figured it out...
Thank you, Gentlemen. I ran a length of 14 (probably should have used 16) gauge wire from turn signal/parking lamp housing to frame bolt to ground it good. Did the same on the other side. Wires cannot be seen from outside, and I would highly recommend doing this if anyone experiences a similar problem. Appreciate all the inputs.
Take It Easy |
The Following User Says Thank You to Red Baron For This Useful Post: |
03-25-2024, 7:52pm | #6 | ||||||
03-26-2024, 7:42am | #7 | ||||||
Headlights are a big current "sink" on these cars and often older wiring/connection cause a problem in such a case. Many put relays on the headlight circuits to lessen the load on things like headlight switches, etc.. And, of course, grounds on a plastic car are a perennial problem.
