03-07-2012, 10:50am | #1 | ||||||
Denture Queen
Barn Stall Owner #29
Gameroom Barn Bucks: $1022278
Bleeding!!!!
...Your brakes. I want to remove my calipers, clean them, probably repaint them, lube them and reinstall. I know that in order to do this, I will obviously have to empty the brake fluid from the system then refill after reassembling. Do the bleeding systems work? The one I'm looking at is http://www.amazon.com/Motive-Products-Bleeder-Adapters-European/dp/B0002KM5L0/ref=sr_1_1?ie=UTF8&qid=1331134901&sr=8-1. Anyone with any experience using a one-person system like this?
03-07-2012, 10:53am | #2 | ||||||
Gameroom Barn Bucks: $2173478
Honestly, I like the good old fashioned way of pumping your brakes..unfortunately it is a two person operation that way.
03-07-2012, 10:55am | #3 | ||||||
Gameroom Barn Bucks: $2527405
The Following User Says Thank You to Nemesis For This Useful Post: |
03-07-2012, 10:57am | #4 | ||||||
Barn Stall Owner #47
Gameroom Barn Bucks: $1098639
03-07-2012, 11:00am | #5 | ||||||
Denture Queen
The Following User Says Thank You to G8rDMD For This Useful Post: |
03-07-2012, 11:00am | #6 | |||||||
VB Dad of the Year
03-07-2012, 11:01am | #7 | ||||||
Gameroom Barn Bucks: $3122345
I still like having any brake work done by someone pumping up the brakes and forcing all the air out of the system.But I have used that style bleeder when doing a brake flush.Two things to do if you use that style,pinch off the rubber flex line going to the caliper so you don't drain out the m/c when you take the calipers off and two when you get all the air out of a caliper close the bleeder screw take off the suction line and reopen the screw until a few drops hit the floor.
If you are going to paint your calipers you should look into having them powdercoated lasts longer and looks less cheesy. |
03-07-2012, 11:03am | #8 | |||||||
Barn Stall Owner #122
Gameroom Barn Bucks: $1158963
03-07-2012, 11:04am | #9 | ||||||
03-07-2012, 11:07am | #10 | ||||||
Save a step. Paint your rotors instead.
03-07-2012, 11:10am | #11 | |||||||
Denture Queen
03-07-2012, 11:11am | #12 | ||||||||
Denture Queen
03-07-2012, 11:11am | #13 | ||||||
Denture Queen
03-07-2012, 11:13am | #14 | ||||||
03-07-2012, 11:17am | #15 | ||||||
The Following User Says Thank You to kylebuck For This Useful Post: |
03-07-2012, 11:19am | #16 | ||||||
Gameroom Barn Bucks: $730
I've used a Motive brake bleeder on several Vettes & works great. I highly recommend it.
The Following User Says Thank You to Hrdtop00 For This Useful Post: |
