Old 03-20-2010, 11:39am   #1
AS1Gonzo
Points: 2,916, Level: 35
AS1Gonzo's Avatar
Gameroom Barn Bucks: $5
Default GM logo
I was wondering if anybody had any good ideas on removing the little square GM logo on each of the rear quaterpanels. They stand out on all the black.
Black on Black on Black C6
AS1Gonzo is offline   Reply With Quote
Old 03-20-2010, 12:06pm   #2
DropTheTop
Barn Stall Owner #777
Points: 22,113, Level: 100
DropTheTop's Avatar
Gameroom Barn Bucks: $6589249
I'd probably try saturating with goo gone, then dental floss. Then more goo gone until all the adhesive was gone. Then a good polish and wax to get rid of any remaining mess in the area.
Edit: It might not hurt to heat it up a little either, to soften the glue.
The Following User Says Thank You to DropTheTop For This Useful Post:
Old 03-20-2010, 3:48pm   #3
Garb55
Points: 17,083, Level: 90
Garb55's Avatar
Gameroom Barn Bucks: $7813
I used fishing line on my truck. Works better when it hot out. You can heat it up with a blow dryer, a heat gun may be to hot and mess up the paint. Heat it up with a blow dryer then use the fishing line or dental floss to go behind it sawing it off. Then use goo be gone or a wax cleaner to clean up were the emblems were.
The Following User Says Thank You to Garb55 For This Useful Post:
Old 03-21-2010, 12:46pm   #4
MAJ Z06
Points: 2,122, Level: 29
MAJ Z06's Avatar
Gameroom Barn Bucks: $1474
MAJ Z06 is offline   Reply With Quote
Old 03-25-2010, 6:15am   #5
Radioman
Points: 1,615, Level: 24
Radioman's Avatar
Gameroom Barn Bucks: $615
Get a 2010 GS. They don't come with chicklets...
Radioman is offline   Reply With Quote
Old 03-25-2010, 9:02am   #6
You won't mess up the paint w/ a hair dryer... a heat gun is a bit more intense and could possibly create issues.
Just heat it up good and hot w/ a hair dryer, then use your fingernail to get under the edge and pull it off. If that doesn't work use fishing line.
Roll off the remaining double sided tape w/ your finger as best you can then get the remaining off w/ goo-gone or 3M wax & adhesive remover. Basically the same process by which you take a BSM off of a C5.
Old 03-30-2010, 9:31am   #7
Peter Pan
Barn Stall Owner #58
Points: 9,221, Level: 66
Peter Pan's Avatar
Gameroom Barn Bucks: $13154
That is the way I have done it on several C6s and on my C5 when I went with a different badge
