Old 10-29-2010, 7:51pm   #21
wwomanC6
C6 Modulator
Barn Stall Owner #27
NCM Supporter '13,'14,'15
Points: 77,846, Level: 100
Activity: 51.5%
wwomanC6's Avatar
The noise is coming from the torque converter. Took off the access plug, no sign of fluid. Everything looks OK, nothing loose that we can tell. But that exactly were it's coming from. Johnny described it as a flutter.
Old 11-16-2010, 5:07pm   #22
wwomanC6
C6 Modulator
Activity: 51.5%
wwomanC6's Avatar
Took the Squirrel to a Vette friend who is a mechanic. Torque tube bearing is going bad and making the rattling noise. Looks like Sat we will be dropping the rear end and changing the torque tube bearings.
The Following User Says Thank You to wwomanC6 For This Useful Post:
Old 11-16-2010, 5:41pm   #23
Garb55
Points: 17,083, Level: 90
Garb55's Avatar
Gameroom Barn Bucks: $7813
Could be worse, good luck and hope all go's well..
The Following User Says Thank You to Garb55 For This Useful Post:
Old 11-16-2010, 7:48pm   #24
03SlowZ06
Points: 3,068, Level: 36
03SlowZ06's Avatar
Gameroom Barn Bucks: $100431
Thats a fun job. Did 2 in a week last spring. Dropping the rear that is.
50th Anniv. Quick Silver Z06
OBX LT's, Haltech Stinger
P1SC waiting to go on
Old 11-18-2010, 1:41pm   #25
That sucks. I guess this means you'll be cutting back on the hole shots.
Old 11-20-2010, 11:16pm   #26
wwomanC6
C6 Modulator
Activity: 51.5%
wwomanC6's Avatar
Ya'll be happy to know Squirrel is fixed and the strange new noise that was getting louder is gone!
Will try to get pics posted tomorrow. May take a little bit my photobucket account is full! Toooo many smileys and pics!
Old 11-20-2010, 11:27pm   #27
Garb55
Garb55's Avatar
Good to here all is back to normal..
Old 11-20-2010, 11:34pm   #28
03SlowZ06
03SlowZ06's Avatar
I am glad you got it fixed.
Old 11-21-2010, 6:34am   #29
Old 11-22-2010, 4:11am   #30
Originally Posted by Sneaks View Post
Possible torque tube bearing going bad? Use a stethescope to listen along the driveline near the point where you kinda sorta hear the clang bang rattle tink grind.
Just make sure the Squirrell is up on a lift or jackstands(well supported) when you put it in gear and try to listen. You're nice and slim Wendy, but not slim enough to go hanging upside down under the Squirrell with a scope in your ear.
You owe me 1 dozen oatmeal cookies for my expert diagnosis.
Glad you got it figured out, fixed, and back in shape Wendy.
Old 01-06-2011, 10:38am   #31
wwomanC6
C6 Modulator
Activity: 51.5%
wwomanC6's Avatar
Finally have time to post those pics of the bad torque bearing change.
The noisy culprit right here!
The bad bearing was corroded.
Putting her back together
Old 01-06-2011, 8:01pm   #32
thegreenman
Points: 15,494, Level: 85
thegreenman's Avatar
Did you see any signs of water getting in there to cause this?
Old 01-06-2011, 8:54pm   #33
wwomanC6
C6 Modulator
Activity: 51.5%
wwomanC6's Avatar
That's what is strange. No sign of water, condensation or corrosion - except right there a the bearings and spiles!?! Still trying to figure that one out.
Here on the bolts opposite side of bearing housing
And here
Old 01-06-2011, 10:52pm   #34
thegreenman
Strange, glad you got it fixed. Thanks for the pics, it helps me understand how it connected for a possible future upgrade.
Old 01-06-2011, 11:01pm   #35
wwomanC6
C6 Modulator
Activity: 51.5%
wwomanC6's Avatar
Cool
Your Welcome!
Old 01-07-2011, 9:05am   #36
ottomatic
Points: 4,140, Level: 43
ottomatic's Avatar
Gameroom Barn Bucks: $9
Thanks for the pics. I read the entire thread and took notes - filed away for future references. Nice job. Moderator: sticky this, please.
ottomatic is offline   Reply With Quote
Old 01-07-2011, 9:45am   #37
wwomanC6
C6 Modulator
Activity: 51.5%
wwomanC6's Avatar
Cool
Done!
Some other Notes for ya'll:
We ended up removing the entire torque tube assembly in order to get the torque shaft out. Did not want to come out. Took some forceful coercion.
Something I learned that I did not know - C6 Automatic transmissions have the service port on the bottom back side of the tranny. Were as manual's servicing ports are on the top forward portion.
