08-25-2013, 1:13pm | #1 | ||||||
Gameroom Barn Bucks: $2013824
Never ending quest for the best C4 ZR-1 exhaust system- Stainless Works-UPDATED
Been back and forth with a few different pipe combos- but the long story made short is that the 3" all the way back with the SW 3" X-Pipe makes great top end with plenty mid range torque using LS7 cats from a C6 Z06. It is faster than the stock mufflers on 2.7" pipe without cats. It's Freaking Loud, but then running stock muffs catless on longtube headers was a bit obnoxious too. There is drone, I will probably go to turbo mufflers again when I get some more money to spend. Additionally, I really like running catalysts again. Birds don't fall out of trees when you drive by, you don't get dirty looks from the beach hippy in a Prius, and it quiets things down and quells those decel backfires quite a bit. Lastly, I priced various aftermarket bullet cats with a 3" slip connect, but how can you beat factory Cats from a 505 hp car? You can tell it is running clean, the pipes aren't even blacked up yet and there is no odor at all. OEM parts FTW.
I had recently installed some LT5 headers and I found these 2" longtubes that were already setup for air injection. These aren't SW headers, but a mystery brand- maybe made by Morrison Motorsports in GA is the best guess I have so far. Anyhow, they fit perfectly and really woke up the car. I was running cat-less for a couple of months after the header install (using stock mufflers), but I got tired of my eyes watering every time I pulled up to a stop light with my windows down. Since I had some oem LS7 exhaust that was a stillborn modification on my C6 that I decided to not go through with, I put those nice 3" piped cats to use. They are pretty compact and just fit under the heat shields in the tunnel. .. Notice that we were able to retain the use of the clamping system so the pipes can be separated for service. .. Factory air injection still in place. Does this car even have headers?? Stealth- Because California. .. Also I got a good lesson in installation technique at my local muffler place. Check out the diff clearance. Perfect 1/4" spacing at rest. My old B&B sure wasn't able to achieve this, but it does have a lot to do with jacking up the center piping in place with a jack of some kind, then tightening the clamps before letting it hang. more pics: Last edited by mike100; 10-19-2013 at 5:03pm. |
08-25-2013, 7:07pm | #2 | ||||||
I considered that one long ago, and those mufflers tips are the reason I didn't buy them. I think they are hideous, but if they are working great for your Z-good for you.
A Vette tuner told me that SW is the muffler system he get the most HP at his mainline dyno. I'm passed Muscle Car Rumble. I want to get there, able to have a phone conversation, listen to my tunes, and drive. I foresee buying Turbo S mufflers for both Vettes in the future. I care less I loose 5-15 RWHP. Dynomax sells a 3" resonator with an X inside. That baby looks pretty cool to me. |
08-25-2013, 9:25pm | #3 | |||||||
I actually bought the car with a B&B x-piped system which is pretty similar. I foolishly got rid of that early on, but I should have kept it and thrown some different mufflers on it. Well, I tried a couple of combos and could never get the good top end rev so here I am in the same place 2 years later. I'm predicting 115+ mph in the quarter. I should also say that I got this thru a group buy on the ZR1 net registry so the price was really attractive ($735). Last edited by mike100; 08-25-2013 at 10:14pm. |
08-25-2013, 9:40pm | #4 | ||||||
08-25-2013, 9:50pm | #5 | ||||||
08-25-2013, 10:08pm | #6 | |||||||
Gameroom Barn Bucks: $510
New Style SW chrome rectangular Outlets.
I really like the new style SW chrome rectangular pipes. I have those on my 90'z and the older style dual circular chrome pipes on my 91' Z. |
08-25-2013, 10:10pm | #7 | ||||||
The Following 2 Users Say Thank You to mike100 For This Useful Post: |
10-19-2013, 4:59pm | #8 | ||||||
I guess I didn't feel that I had spent enough money on this thing so here's the update:
So I got some C6-Z06 mufflers with the NPP exhaust flapper valves (vacuum actuated). Note that the inside pipes are the loud, high flow straight thru section. This will be blocked during cruise conditions. Hacked them off to put them on my loud-ass SW mufflers. Working out the fit- had to rotate them a touch to fit the vacuum can. Also the diaphragm comes loose and you can reposition it so the vacuum nipple points in any direction. Got the staggered tip the same on both sides- sort of follows the fascia curve. I have not completed the vacuum circuit yet, but plan to trigger a vacuum solenoid using the vacuum secondary signal for the LT5 secondary throttle blades in the intake. It is computer controlled and works on throttle position and engine rpm- so the algorithm is already perfect as it exists stock on the ZR-1 model. I'm piggy backing that function for sure I could only manually pump up the valves to test them for now, but it is REALLY quiet! This IS the solution to the C4 drone on the typical aftermarket system. I can see why they offered this on the C6 vettes- it is the only way to make dual outlet mufflers quiet. |
The Following User Says Thank You to mike100 For This Useful Post: |
10-21-2013, 9:26pm | #9 | ||||||
I drove the car with the NPP valves hooked up to the plenum. They close at idle and very light cruise, but if you even barely crack 30% throttle or go up a hill, it gets loud quickly. never the less- it works and is very mellow!
Got an EGR solenoid from the junkyard for $7.95 It was from an early 90's cadillac with a 4.9 I think. Same egr solenoid that comes on most of those cars before they went to the electric one. It vents to the atmosphere and has a little foam filter on the 3rd port. I think I will hook it up to the vacuum ball in the right front ahead of the tire. Need to figure out how to get switched 12v power into the engine compartment though. |
10-23-2013, 8:40pm | #10 | ||||||
Gameroom Barn Bucks: $882805
We have the Mild to Wild switch on our 07 using an 08 NPP exhaust. I love it. We can push the button and go to full open or closed. When closed the car is quiet like stock and open it sounds great with headers. Installation was a breeze.
10-23-2013, 11:25pm | #11 | |||||||
recall on C6's, there is an actual control box that interfaces with the ecm. Mine is more manually plumbed in and monitoring the secondary throttle plate vacuum signal ON EDIT: How did you adapt an '08 NPP onto your 07 C6? Did you only get the M2W box or did you get the GM controller along with the mufflers? |
10-24-2013, 6:40pm | #12 | |||||||
Wired this way the exhaust only works full time open or full time closed which isn't the way it was intended to work. GM designed the exhaust to open at 2000 rpm if I remember correctly. I also don't know if the Z06 Bi-mode works exactly the same as the NPP but I assume it does. |
10-24-2013, 7:02pm | #13 | ||||||
Barn Stall Owner #204
Gameroom Barn Bucks: $403724
I am really impressed. You guys are actually discussing a C4 technical problem! What is this forum coming to?
10-24-2013, 9:36pm | #14 | |||||||
Mine is working similarly now. |
10-24-2013, 9:37pm | #15 | ||||||
10-24-2013, 10:04pm | #16 | ||||||
So I finally received the adjustable vacuum switch. When the vacuum controlled secondary throttle is activated on the LT5, so is my loud valve. I set it to 12" of vacuum (12 in Hg).
The switch powers a junkyard EGR vacuum solenoid. This couples the vacuum to the muffler valves. It either connects the vacuum to the valve, or vents the vacuum to the atmosphere thru the little foam filter on the 3rd port. It never has a vacuum leak on the source end. Perfect $8 solution (I should have pocketed it but I was feeling honest). The vacuum source is the nearby vacuum ball used for the a/c and air injection diverter valve. The 12v was easy too- I tapped into the under hood lamps which of course aren't even connected anyhow. This is actually a second MAP sensor just to monitor the secondary throttle system. I 'T'-ed into it. Vacuum here means all 16 runners and injectors are working on the LT5 and it was a simple idea to switch the NPP valve off of this computer controlled load function. Here it is idling- the loud section of the muffler is blocked off (left pipe). Will try to get a video on Saturday. |
10-24-2013, 10:12pm | #17 | ||||||
The only idea I have is to get a second solenoid and run a dedicated line to each vacuum actuator. It would help them to open and close a little more quickly than running both muffs off of one teeny 15' vacuum line. But it does work and is sooo much more driveable on longer runs.
11-21-2013, 12:01pm | #18 | ||||||
ZR1 exhaust
Hi,
I live near you and own a 90 ZR-1 like yours. I was hoping I might be able to hear your ZR-1 before I buy a new exhaust. Thanks Larry Huff : |
11-22-2013, 9:29pm | #19 | |||||||
I don't know if you have ever bought an aftermarket cat-back for a C4 before, but it gets ugly real quickly if you are even a little sensitive to noise. I would have loved this stuff when I was 23 years old, but now I have to result to such retrofits and modifications to keep my sanity. here's a video of the system in action- even my cheap camera video picks up the audible resonance- it does work. http://s29.photobucket.com/user/mschrameck/media/MOV02832_zpsbfcf3c58.mp4.html |
