06-24-2011, 7:34pm | #21 | ||||||
Gameroom Barn Bucks: $89945
06-24-2011, 7:36pm | #22 | ||||||
Gameroom Barn Bucks: $2527405
It caught me off guard too. $300+...maybe if I owned a resto shop....
06-24-2011, 7:36pm | #23 | ||||||
Barn Stall Owner #762
NCM Supporter '11
Gameroom Barn Bucks: $191989
06-24-2011, 7:38pm | #24 | ||||||
06-24-2011, 7:40pm | #25 | ||||||
NCM Supporter '11
06-24-2011, 7:44pm | #26 | ||||||
06-24-2011, 7:48pm | #27 | ||||||
true.
this will be just like house plumbing copper right? I just cut the pipe with a standard clamp-style pipe cutter, then de-burr it? slide the fitting on, flare it out, and wrench it on? do I use teflon tape? Is there anyone in the south Houston area that is bored this weekend and wants to get some free booze? |
06-24-2011, 7:54pm | #28 | |||||||
06-24-2011, 7:58pm | #29 | ||||||
06-24-2011, 7:59pm | #30 | ||||||
06-24-2011, 8:05pm | #31 | ||||||
If you really do need to decrease the pressure, I'd suggest getting a larger diameter fuel line.
06-24-2011, 8:06pm | #32 | ||||||
06-24-2011, 8:11pm | #33 | ||||||
06-24-2011, 8:55pm | #34 | |||||||
the old install of a choke/heat riser is missing, the carb looks as if it's meant for a crossover tube/vacuum fed heat riser choke pull off, and the manifold mounted choke spring is missing... I can't say jack about the plumbing on the fuel except to say if the carb is not flooding or starving at WOT...leave it for now.... all the carb lines I EVER seen on a GM car have been 3/8 OD... |
06-24-2011, 9:19pm | #35 | ||||||
Barn Stall Owner #93
go with steel. no tape. make sure your flares are not split or have any burrs. go with braided from fuel pump to carb. It's actually easier to run the steel lines anyway. I ran mine inside the chassis tube on my 64 for extra protection but probably not needed. Use some clips with rubber stuff on them to attach so they don't rub on the line.
It's not a hard job. take your time on the bends. |
06-24-2011, 9:22pm | #36 | |||||||
The build number on the carb points to it coming off a dodge in the mid 80s. the reason i got to looking at the fuel system in the first place was that I took the car out on wed. and in the middle of driving fine, it started coughing and stumbling like the choke was closed again or a fuel filter was clogged. In fourth gear the engine would completly stall out while driving, if i drove in any other gear i had to keep my foot buried or it would die, but in either case it was still coughing the whole time, but the rpms never dropped either, the stumbling never caused it to die. It ended up dying enough times that the battery drained and i had to push the car home. |
06-24-2011, 9:30pm | #37 | |||||||
Install this instead: |
06-24-2011, 10:14pm | #38 | ||||||
Gameroom Barn Bucks: $930358
wadda mess
06-24-2011, 11:16pm | #39 | ||||||
oh boy...
06-25-2011, 7:22am | #40 | ||||||
I never seen any Dodge of any type with a Qjet on it.....you sure of that comment??
