06-24-2011, 5:26pm | #1 | ||||||
Gameroom Barn Bucks: $89945
queston about Fuel Lines
last time I drove my vette it kept dying on me.
I finally got around to looking, thinking the fuel filter was clogged, I decided to start there... I'm 100% positive it's not the fuel filter. notice anything missing? (yes, I am aware the crossfire is missing). and further down the line, it does this: nice, right? I refuse to let the car and DSPO beat me, so I guess it's time to get some fuel lines question: the current fuel line is 1/4 inch... do I keep the same diameter, or can I go bigger. I also think I'm going to go with the steel-braided stuff vs. the hydraulic lines, and just replace all the way to the tank. |
06-24-2011, 6:06pm | #2 | ||||||
Barn Stall Owner #762
NCM Supporter '11
Gameroom Barn Bucks: $191989
Get some steel hard line and a tubing bender and a flaring tool and do it right. I don't like braided lines.
06-24-2011, 6:09pm | #3 | ||||||
steel lines seems to be the consensus among the "other" forums as well.
I think I have a tube bender out in the garage somewhere... no flaring tool though |
06-24-2011, 6:19pm | #4 | ||||||
Gameroom Barn Bucks: $2527405
Your fuel lines are collapsing left and right. I'd go steel braided. Every race car you can find has steel braided lines.
06-24-2011, 6:23pm | #5 | ||||||
race car? this is an 84 corvette with 205hp at the most.
06-24-2011, 6:29pm | #6 | ||||||
I was implying that they're safe and durable.
Most people use Earl's products. JEGS carries just about everything you could need. Earl's Performance Products UK - Performance Braided Hose and Fittings for Motorsport |
06-24-2011, 6:34pm | #7 | ||||||
NCM Supporter '11
Braided steel lines are great in race applications, it is far cheaper to jack the car up and replace the lines with steel lines. Now my C3 has a mechanical pump, so I do use braided steel line from the pump to the carb. On fuel injected engines I think steel is the way to go for the fuel injected engines.
You used to be able to buy the steel line at any autoparts store very cheaply. |
06-24-2011, 6:48pm | #8 | ||||||
one explanation I've heard for the fuel line being in the current condition is that since it was fuel injected, and is now carburated, the PO may have crimped them to bring down the pressure.
I am fairly certain that the stock pump is not being used, since all the wires for it are cut. Any truth to this? There are tool marks on the line. |
06-24-2011, 6:55pm | #9 | ||||||
Barn Stall Owner #38
Gameroom Barn Bucks: $2497584
I have a flaring tool. PM me if you need it.
06-24-2011, 7:03pm | #10 | ||||||
06-24-2011, 7:06pm | #11 | ||||||
Barn Stall Owner #420
Gameroom Barn Bucks: $12530349
your shit is fked up
The Following User Says Thank You to Petew1971 For This Useful Post: |
06-24-2011, 7:11pm | #12 | ||||||
06-24-2011, 7:11pm | #13 | ||||||
06-24-2011, 7:21pm | #14 | |||||||
A friend of mine has one like this. I know he wouldn't pay that much for a flaring tool so there must be a cheaper place. However, I can't find it for less than 275. Buying extra line with the cheaper tool is the cheaper way out if you aren't using it a lot. |
06-24-2011, 7:23pm | #15 | ||||||
06-24-2011, 7:23pm | #16 | ||||||
what's a good, albeit inexpensive, one?
would a plumbing line flaring tool work? |
06-24-2011, 7:26pm | #17 | ||||||
06-24-2011, 7:30pm | #18 | ||||||
$386
$15... you know what they say: practice makes perfect afterthought: I wonder if I can rent one from Autozone. Nevermind, they rent the same one the HF sells. |
06-24-2011, 7:32pm | #19 | ||||||
06-24-2011, 7:33pm | #20 | |||||||
NCM Supporter '11
The only fittings that need double flares are brake lines, fuel pressure on a carburetor engine is way, way lower pressure and a single plumbing type flare will work fine most of the time. |
