Old 10-08-2009, 9:45am   #1
Default A/C tensioner squeek
Short version:
Replaced the tensioner pulley, idler pulley, and threw a new gatorback belt on. New pulleys are aluminum. Now, I"m getting a squeek that sounds like metal on metal. Sprayed some WD40 around the retainer bolts and washers, squeek goes away, but comes back soon as the WD40 has disapated. Driving me up the dang wall!
My thinking is that the retainer washers are rubbing against the aluminum pulleys and causing the noise. So, before I replace the entire tensioner unit, I thought I would throw it around here and get some opinions.
What say you guys?
Old 10-08-2009, 11:25am   #2
Weird... I went through all that a couple of years ago and replacing the tensioners did nothing. I got a Gatorback belt and it fixed it all. But I see you've allready done that.
Old 10-08-2009, 12:12pm   #3
DropTheTop
Barn Stall Owner #777
Points: 22,113, Level: 100
DropTheTop's Avatar
Gameroom Barn Bucks: $6589249
Mine went away also after I installed both Gatorbacks.
Old 10-08-2009, 8:12pm   #4
New AC tensioner and all is well. Talk about a beoch to get on! Not a job for the un-limber individual. Took about an hour or so, and that's with the old one already taken off.
Old 10-08-2009, 8:52pm   #5
PortDawg
Charter Member - C3 Mod
Barn Stall Owner #34
NCM Supporter '15
Points: 30,980, Level: 100
PortDawg's Avatar
Gameroom Barn Bucks: $173
Putting it on a lift helps..
Old 10-08-2009, 9:41pm   #6
I thought maybe going up from underneath would work better. Threw it up on jackstands, and no-go. Not enough room to work between the rack-n-pinion, leaf spring, and the tranny cooler lines.
Old 10-09-2009, 6:30am   #7
DropTheTop
DropTheTop's Avatar
Geez, and I thought getting the belt on was bad!
Old 10-09-2009, 7:17am   #8
That's the easy part. :rolllaughing:
Old 10-09-2009, 7:40am   #9
I hate leaf springs...
Old 10-09-2009, 8:34am   #10
DropTheTop
DropTheTop's Avatar
:not-funny: Grumble, grumble, stupid leaf springs . . .
Old 10-09-2009, 8:50am   #11
How would you know? You don't have any.
