Old 10-10-2009, 10:51pm   #1
Lowcash
Points: 4,921, Level: 47
Lowcash's Avatar
Gameroom Barn Bucks: $2827
Default Weekend car work
I swapped out my red display digital cutout controller for a blue display last weekend. When I tried to calibrate the cutouts to the new controller I found my passenger side cutout would not calibrate correctly. Thursday I put the car in the air and took the cutout off for cleaning and a basic overall check. No matter what I did I could not get it to sync up correctly. I then noticed the motor was kind of lazy and did not sound right. I decided instead of buying a whole new cutout I would just buy the replacement pieces (motor and butterfly kit). So hopefully on Wednesday the parts will arrive and I can put everything back together. ... I also turned the rear bolts down to 3 threads.
After I shot it with brake cleaner to get all the excess exhaust crap off I wiped it down and shot it with PB Blaster to loosen up the screws. Below is a picture of a disassembled QTP cutout.
Note: The 2 screws that attach the butterfly to the shaft are impossible to remove even after soaking it in PB Blaster. I ended up twisting the head off and had to drill the rest of the screw out.
If the cutouts don't re-sync after this, I'll be stopping by the local GHL distributor for some 'ideas'.
2008 C6 Z06
Old 10-10-2009, 11:23pm   #2
GHL.....know anyone who sells those?
Old 10-10-2009, 11:30pm   #3
Lowcash
Lowcash's Avatar
Thinking I may do some cleaning tomorrow. Clean those Corsas up as well as the rear axle area.
2008 C6 Z06
Old 10-11-2009, 9:51am   #4
Willfulone
Charter Member - Vendor
Points: 7,866, Level: 62
Activity: 1.2%
Willfulone's Avatar
Gameroom Barn Bucks: $807
My ears were burning
Peace
Chip
"Killing the Corvette Tax One Product at a Time"
Willfulone is offline   Reply With Quote
Old 10-11-2009, 8:04pm   #5
Shot of penicillan and next time, wear a cond....oh you said ears. My bad!
Old 10-11-2009, 8:18pm   #6
Blue Dragon
Points: 3,800, Level: 40
Activity: 1.4%
Blue Dragon's Avatar
Gameroom Barn Bucks: $615
Very sharp!!
Blue Dragon is offline   Reply With Quote
Old 10-14-2009, 11:54am   #7
Culookin
Points: 5,156, Level: 49
Culookin's Avatar
Gameroom Barn Bucks: $802
I kinda did the same thing when I changed out to the controller from the Toggle... The cutouts had shifted slightly and were making contact with the piping... Pulled them down and had to retorque the little set screws on the shaft (Mine, unlike yours, were loose )... They worked great fro about 4 months but are acting up again. I think I'm just gunna buy new motors like you. How much were they from QTP? Like 150?
Culookin is offline   Reply With Quote
Old 10-14-2009, 1:48pm   #8
DropTheTop
Barn Stall Owner #777
Points: 22,113, Level: 100
DropTheTop's Avatar
Gameroom Barn Bucks: $6589249
Parts show today?
Old 10-14-2009, 4:38pm   #9
Lowcash
Lowcash's Avatar
The motor was $50 and the butterfly kit was $25. It beats buying a complete cutout for $150+
2008 C6 Z06
Old 10-14-2009, 5:10pm   #10
I thought you were doing GHL's??????
Old 10-14-2009, 5:18pm   #11
Culookin
Culookin's Avatar
I'll give them a call tomorrow and see if I can't order a new set... there goes another $150!
Old 10-14-2009, 7:47pm   #12
Lowcash
Lowcash's Avatar
GHLs were my fall back incase I couldn't get this QTP thing resolved. It turned out the intermediate wire I was using was bad and it was calibrating the cutouts opposite each other. I plugged it into the existing intermediate wire and all is well and car back on all 4s.
https://shop.quicktimeperformance.co...duct_list&c=11
2008 C6 Z06
Old 10-14-2009, 10:32pm   #13
C5 BEARSFAN
Points: 3,459, Level: 38
Activity: 0.8%
C5 BEARSFAN's Avatar
Gameroom Barn Bucks: $155
i know one other besides me
C5 BEARSFAN is offline   Reply With Quote
