12-02-2020, 9:23am | #1 | ||||||
A.O.Smith Water heater issue
After Super Storm Sandy came through and under our home doing over $250,000.00 worth of damage I was forced to move the water heater and hot air furnace up into the attic (Insurance) so anyway it is 7 years old and has been making crackling and thumping sounds from inside the tank when you are using hot water and either turn on the cold water or flush the toilet (makes no sense to me) Wife looked it up on google and said we probably needed to flush the tank and then a local and very good Plumber confirmed it so....I shut heater off let it cool down awhile,opened two hot water faucets to get air flow into tank and drained it totally into the bathtub....then ran the cold water feed into it a few times and drained it again.
While doing all this I was surprised how little debris came out....I guess being on the barrier island the water is very soft. Anyway I refilled tank,turned on the burner and reheated the water. Still making the sounds...plumber says he does not believe it is a dangerous thing and we did everything correct. His advice was either live with noise or he can install a new water heater,then it will all be on him. So what do the fine folks here that know plumbing think ? |
12-02-2020, 9:24am | #2 | ||||||
Barn Stall Owner #∞
Gameroom Barn Bucks: $34677
icnlt
The Following User Says Thank You to z06psi For This Useful Post: |
12-02-2020, 9:33am | #3 | ||||||
SOME Real Barner
Gameroom Barn Bucks: $2034428
I drain the tank from the tank valve, not the faucets.
12-02-2020, 9:38am | #4 | ||||||
Gameroom Barn Bucks: $406058
12-02-2020, 9:40am | #5 | ||||||
Nothing dangerous about water heaters as long as over pressure valves working.
Perhaps it's a pipe making noise not the tank? He said opening faucets to allow air in, pretty sure he drained from the tank drain. |
12-02-2020, 10:01am | #6 | ||||||||
SOME Real Barner
Hey alky...he said he drained it into the tub...put the shine down and focus. Quote:
12-02-2020, 10:12am | #7 | ||||||
12-02-2020, 10:16am | #8 | ||||||
12-02-2020, 10:20am | #9 | ||||||
12-02-2020, 10:25am | #10 | ||||||
12-02-2020, 10:27am | #11 | ||||||
SOME Real Barner
12-02-2020, 10:41am | #12 | ||||||
12-02-2020, 10:52am | #13 | ||||||
The Following User Says Thank You to 04 commemorative For This Useful Post: |
12-02-2020, 11:07am | #14 | |||||||
Gameroom Barn Bucks: $3335
Drain the tank as you previously did, remove the inlet pipe at the top of the water heater and pour in 2 gallons of white vinegar then let it sit over night. The next day with all the faucets closed and the drain on the heater open turn the water back on, shit should come out the drain. While the water is off find the lowest point in the delivery system and have that open, then open every faucet in the house. This will allow all the anti water hammer cushions to drain
12-02-2020, 11:28am | #15 | ||||||
A.O. Smith built both the Corvettes I once owned.
"Many new mid-year Corvette owners aren’t aware that there were TWO plants that built ’64-’67 Corvette bodies; half were built at St. Louis, and half were built under contract by the A.O. Smith Corporation in Ionia, Michigan." |
12-02-2020, 11:39am | #16 | ||||||
Nice to know but does not help me
12-02-2020, 11:45am | #17 | ||||||
You haven't noticed any pressure loss have you.
12-02-2020, 11:50am | #18 | |||||||
SOME Real Barner
opened two hot water faucets to get air flow into tank and drained it totally into the bathtub |
12-02-2020, 11:50am | #19 | ||||||
I've never simply drained a water heater, I flush them by leaving the water supply on while opening the drain. That seems to flush any sediment out better than just gravity draining would.
12-02-2020, 11:54am | #20 | ||||||||
SOME Real Barner
Thanks Pocket protector collectors forum --------------> |
