Old 08-06-2015, 5:48pm   #1
quadracerx
Points: 2,283, Level: 30
Activity: 1.2%
quadracerx's Avatar
Gameroom Barn Bucks: $700
Default Wooo...Hooo It runs!!
Hey Guys...
Guess what? It runs after replacing the fuel pump, strainer and filter... It runs and reasonably well too!!
Only thing I cant figure out is it seems to idle pretty fast? How can I turn down the Idle Speed? Or is it controlled by the computer?
It got really hot too... Found out the radiator is plugged. So Im doing that tonight!! Man the radiators are inexpensive, only 127.00 brand new!! Already have new thermostat, hoses and now new radiator and cap... Hopefully we will be good as far as overheating is concerned....
Thanks again for all the help with everything!!
You guys are awesome!!
Steve
quadracerx is offline   Reply With Quote
Old 08-08-2015, 11:17am   #2
SQUIRMIN VERMIN 84
Barn Stall Owner #49
Points: 23,508, Level: 100
Activity: 2.5%
SQUIRMIN VERMIN 84's Avatar
Gameroom Barn Bucks: $1025197
Check your manifold vacuum....... should be about 20 inches..
A vacuum leak will cause high idle...and an over-lean mixture will run hotter..
SQUIRMIN VERMIN 84 is offline   Reply With Quote
