12-27-2020, 4:16pm | #1 | ||||||
Gameroom Barn Bucks: $1232517
I need some plumbing help
I want to put a toilet in a storage building I have and I have several questions.
first, can I vent it on the outside as other wise I would have to do it inside and up high. If I did that, how would you suggest I do it. The septic tank pipe that I will connect to is 12 feet from the outlet outlet from the storage room. I think I need to have a drop of three inches to that pipe. there is no pvc fitting that will give me a correct angle. Can I use a rubber coupling. I am sure I will have much more questions but this will get me started. |
12-27-2020, 4:21pm | #2 | ||||||
IB4S
The Following User Says Thank You to 04 commemorative For This Useful Post: |
12-27-2020, 4:22pm | #3 | ||||||
if only there were professionals that dealt with such things. you could look them up in the phone book, they would come out and talk to you, understand what you want, and then tell you if you could do it, and would offer to talk care of all the messy details and do it for you for a modest fee...... if only.... maybe we'd call them plumbers.
The Following 2 Users Say Thank You to DAB For This Useful Post: |
12-27-2020, 4:48pm | #4 | ||||||
Vent as high as can for smell mainly but it only needs to be as high as the highest fixture actually. Away from windows of course. Personally I'd run it inside and out high on building where convenient.
Nothing wrong with rubber bushing if can't find the correct pvc fitting as its not a pressure system. The overall horizontal run is what needs the correct pitch, do yourself a favor and put cleanouts in. |
The Following 3 Users Say Thank You to Rodnok1 For This Useful Post: |
12-27-2020, 5:40pm | #5 | ||||||
and get permits from town
12-27-2020, 6:46pm | #6 | ||||||
Gameroom Barn Bucks: $18284
if it helps, you could build a small platform and elevate the toilet. then use a double 90 degree arrangement to be able to roll the second fitting to your desired angle. you can use rubber boots or whatever they are. as far as venting, i would want it out as high as i could.
The Following 2 Users Say Thank You to Egnalf For This Useful Post: |
12-27-2020, 6:55pm | #7 | |||||||
Gameroom Barn Bucks: $1014987
The Following 2 Users Say Thank You to Old Ben For This Useful Post: |
12-27-2020, 7:17pm | #8 | ||||||
Barn Stall Owner #49
Gameroom Barn Bucks: $1025197
The Following 2 Users Say Thank You to SQUIRMIN VERMIN 84 For This Useful Post: |
12-27-2020, 7:30pm | #9 | |||||||
12-27-2020, 7:34pm | #10 | ||||||
12-27-2020, 9:01pm | #11 | ||||||
ok i will bite. my toilets at my house are on the second floor. they flow right into a vertical pipe. what problems are created by the steep angle
The Following User Says Thank You to Egnalf For This Useful Post: |
12-27-2020, 9:07pm | #12 | ||||||
Barn Stall Owner #666
Gameroom Barn Bucks: $1006120
At work the bathroom fan vents directly into the ceiling of the restaurant next door.
12-27-2020, 9:07pm | #13 | ||||||
Straight down is OK. If the slope gets too severe the liquids will run faster than the solids tend to possibly causing havoc.
12-27-2020, 11:08pm | #14 | ||||||
Barn Stall Owner #93
Use the bushes.
The Following 4 Users Say Thank You to SnikPlosskin For This Useful Post: |
12-28-2020, 4:25am | #15 | |||||||
12-28-2020, 4:28am | #16 | ||||||
As I was typing this it occurred to me to completely change the set up of the septic tank situation which will eliminate all 90 degree angles and have 45 degree angles. There are two different sources, one for a motor home and the other, this commode.
Thanks for the suggestions! |
