Old 10-19-2020, 10:32am   #1
Stevedore
Points: 15,220, Level: 85
Activity: 1.4%
Stevedore's Avatar
Gameroom Barn Bucks: $406058
Default Markers near street?
Does anyone know what these markers are? The dirtier one in the picture is up at the end of our driveway, near the edge of the roadway. The cleaner looking one is at the edge of the road in front of my son's house. They look identical, & are about 1/2" in diameter.
When I first noticed the one near us a while ago, I thought it might be a utility marker of some sort, but my son's house is in another town, with different utility providers.
Stevedore is offline   Reply With Quote
Old 10-19-2020, 10:35am   #2
ThePirate
Barn Stall Owner #107
Points: 4,965, Level: 48
Activity: 2.2%
ThePirate's Avatar
Gameroom Barn Bucks: $1793
Survey markers.
ThePirate is offline   Reply With Quote
The Following 3 Users Say Thank You to ThePirate For This Useful Post:
Old 10-19-2020, 10:35am   #3
RMVette
Points: 63,831, Level: 100
Activity: 34.2%
RMVette's Avatar
Gameroom Barn Bucks: $311064
Probably surveying benchmarks.
RMVette is online now   Reply With Quote
The Following User Says Thank You to RMVette For This Useful Post:
Old 10-19-2020, 10:37am   #4
mrvette
Barn Stall Owner #101
Points: 133,632, Level: 100
Activity: 10.4%
mrvette's Avatar
Best guess is sirveyors markers.....take a compass and see if any markings line up to make any cents.....
The Following User Says Thank You to mrvette For This Useful Post:
Old 10-19-2020, 10:39am   #5
Points: 223,926, Level: 100
Maybe they are surveyor's markers? That would be my best guess. If it was utility related, you'd see some marker paint, especially near the new one. Yellow for natural gas, blue for water, red for electric, orange for cable/phone, etc.
Old 10-19-2020, 10:46am   #6
Rodnok1
Points: 42,646, Level: 100
Activity: 53.6%
Rodnok1's Avatar
Definitely survey markers.
https://www.baselineequipment.com/chrisnik-mag-nails
Rodnok1 is offline   Reply With Quote
The Following User Says Thank You to Rodnok1 For This Useful Post:
Old 10-19-2020, 10:47am   #7
JetMechZ16
Points: 46,956, Level: 100
Activity: 5.4%
JetMechZ16's Avatar
Gameroom Barn Bucks: $856744
Not sure if anyone's mentioned surveyor markers.
The Following 2 Users Say Thank You to JetMechZ16 For This Useful Post:
Old 10-19-2020, 11:03am   #8
Points: 57,184, Level: 100
Activity: 58.3%
Dunno if this has been mentioned or not, but those look like survey markers to me.
The Following 2 Users Say Thank You to dvarapala For This Useful Post:
Old 10-19-2020, 11:05am   #9
Points: 159,154, Level: 100
Activity: 19.4%
meanwhile, somewhere on Oak Island...
The Following 3 Users Say Thank You to Mike Mercury For This Useful Post:
Old 10-19-2020, 11:20am   #10
DAB
Barn Stall Owner #4
Points: 172,146, Level: 100
Activity: 9.4%
DAB's Avatar
known as PK nails, used by surveyors, as they have a little dimple in the center, so you can line up a staff or a plumb bob exactly.
https://en.wiktionary.org/wiki/PK_nail
became very familiar with these years ago in Antarctica when I helped out the surveyors a bit.
DAB is offline   Reply With Quote
The Following 2 Users Say Thank You to DAB For This Useful Post:
Old 10-19-2020, 11:28am   #11
JetMechZ16
Activity: 5.4%
JetMechZ16's Avatar
Driving surveyor spikes into drifting ice in Antarctica > Iron Maiden
The Following User Says Thank You to JetMechZ16 For This Useful Post:
Old 10-19-2020, 11:51am   #12
DAB
Barn Stall Owner #4
Activity: 9.4%
DAB's Avatar
actually, drove them into the dirt. spent many days helping lay out the location of two new buildings and their many concrete footings (precast concrete).
i can still hear Jeff (lead surveyor), "line, then distance!"
meaning first get the right direction figured out (line), and then worry about the correct distance from the transit.
i recall that each building had like 32 footers, and each footer was located by 2 PK nails, exactly located in the dirt, so later the footings could be placed properly by the heavy equipment operators (who I also worked with). they'd hoist them by the bucket on the front end loader via a chain attached to a lifting point in the footing. left, right, forward, back....wash, rinse repeat, shove a bit, DOWN! that's one....many more to go.....
The Following 3 Users Say Thank You to DAB For This Useful Post:
Old 10-19-2020, 12:11pm   #13
z06psi
Barn Stall Owner #∞
Points: 25,038, Level: 100
z06psi's Avatar
Gameroom Barn Bucks: $34677
Survey markers
z06psi is offline   Reply With Quote
The Following User Says Thank You to z06psi For This Useful Post:
Old 10-19-2020, 12:13pm   #14
Stevedore
Activity: 1.4%
Stevedore's Avatar
Thanks for all the replies; I learned something today. Doesn't happen that often anymore.
The Following 4 Users Say Thank You to Stevedore For This Useful Post:
Old 10-19-2020, 12:25pm   #15
DAB
Barn Stall Owner #4
Activity: 9.4%
DAB's Avatar
you will also find pieces of 1/2 rebar used as survey markers, often capped with a plastic cap with the surveyor's name (so others will know who placed it). several corners of our lot are marked with these, we have about 10 points that mark our boundary with other lots. sometimes they will also drive a wooden stake near it so it's easy to locate later, and one of ours has a T-post (metal fence post) driven near it so you know it's there.
on the survey, these will be noted as either "IPS" - iron pipe set (placed by the surveyor), or IPF - iron pipe found, obviously set in place by a previous surveyor.
Old 10-19-2020, 12:27pm   #16
Activity: 58.3%
Do they mark the location of PK guitars?
Old 10-19-2020, 12:56pm   #17
Stevedore
Activity: 1.4%
Stevedore's Avatar
We have those yellow caps at 3 corners of our (trapezoidal) property. I suspect that the 4th one is buried a bit. When we had the property flagged for utility locations prior to some digging last Spring, one of the guys was nice enough to wave his locator around the area where I think it is & said there was definitely something there. If I get ambitious someday, I'll dig down a little & see if I find a corner marker. It's the only one of the 4 corners that's in grass & gets mowed, so I wonder if a previous owner may have pounded it down below the surface.
The Following 3 Users Say Thank You to Stevedore For This Useful Post:
Old 10-19-2020, 12:58pm   #18
DAB
Barn Stall Owner #4
Activity: 9.4%
DAB's Avatar
very likely. it's still in the correct place, but now not subject to movement or damage.
our house in MD, i knew there was a marker in the yard between our house and the neighbor, finally found it one day (i wanted to lay out some edging just so, and stay on the line), sure enough, it was about 2" below the surface, but easy to find with a locating wand.
The Following User Says Thank You to DAB For This Useful Post:
Old 10-19-2020, 3:53pm   #19
Old Ben
Points: 28,045, Level: 100
Activity: 14.7%
Old Ben's Avatar
Gameroom Barn Bucks: $1014987
May have pulled it out not knowing what it was for. Have seen that happen.
Old Ben is offline   Reply With Quote
The Following User Says Thank You to Old Ben For This Useful Post:
Old 10-19-2020, 8:35pm   #20
Rikki Z-06
Barn Stall Owner #747-400
Points: 78,321, Level: 100
Activity: 19.8%
Rikki Z-06's Avatar
Cliffs.
Rikki Z-06 is offline   Reply With Quote
