View Poll Results: The math/logic/physics indicates: | |||
Yes, leaving more room will allow you to slow down more gradually and help prevent an accident | 8 | 40.00% | |
No, leaving more room ahead of me doesn't help any, none. | 1 | 5.00% | |
Pie | 11 | 55.00% | |
Voters: 20. You may not vote on this poll |
05-06-2022, 2:14pm | #1 | ||||||
Gameroom Barn Bucks: $5427
[Tailgating POLL] Perhaps VB can settle this physics debate...
My position: I am driving at 60 mph and somebody comes up on my ass 1 car length away (18 ft). If I can't pull over, I will very slowly reduce my speed to leave more room in front of me, then resume the same speed as when the tailgater came up on my ass.
By doing this, I am taking my increased reaction time (by creating more space) and giving it to the tailgater (in simple terms). To conceptualize, if you were tailgating me which one of these would be safer and give you more time to react if I had to stop suddenly (due to accident, traffic, whatever). You are still one car length off my ass. 1) I slow from 60-45 mph in 2 seconds, OR 2) I slow from 60-45 in 4 seconds. The (dare I say) obvious answer is (2), if you are on my ass 18 feet away at 60mph you will need more than 2 seconds. Your reaction time is 2 seconds, you hit me before you even hit the brake. SUMMARY: I am able to decelerate at a slower rate (60-45 in 4 seconds) because I left more room to react to stops in front of me. Relevant data Distance travelled in 2 seconds (typical reaction time) at 60 mph: 176 feet Average researched reaction time: 2 seconds |
05-06-2022, 2:16pm | #2 |
Remember your driver's Ed and the driving tests? I know here in FL the manual says to slow down enough to get the driver to pass you or to get yourself into a situation where you can move over.
05-06-2022, 2:22pm | #3 | ||||||
I can't move over and there is no where to pass. But I do agree with slowing down safely for the reasons my OP indicated.
05-06-2022, 2:27pm | #4 | ||||||
The Following 5 Users Say Thank You to ZipZap For This Useful Post: |
05-06-2022, 2:43pm | #5 | |||||||
05-06-2022, 2:43pm | #6 | ||||||
Gameroom Barn Bucks: $1014987
I would slow down to draw them in closer then hit the brakes because of the animal in the road. I do need a new car and their insurance would be paying for a really nice one.
The Following 7 Users Say Thank You to Old Ben For This Useful Post: |
05-06-2022, 2:50pm | #7 | |||||||
okay, well at least in this fresh thread you gave me your contention with the two data points. Summary: Aero is traveling at 60mph Aero is 18 feet behind the car ahead of him Aero claims he is NOT tailgating According to DOT/NTSB definitions is Aero tailgating??? 1) YES 2) NO I'll let the community answer this, as you seem unable (or unwilling) to grasp the physics from me. |
05-06-2022, 2:53pm | #8 | ||||||
The Following User Says Thank You to Old Ben For This Useful Post: |
05-06-2022, 2:55pm | #9 | ||||||
Supplemental information
https://www.dot.state.mn.us/traffice...gating/FAQ.pdf Please note per source: How do the DOTS work? The DOTS are spaced for the simplest and safest use by motorists. When traveling at the posted 55 MPH, under ideal road conditions, a driver should allow two DOTS to be visible between them and the vehicle they are following. This space reflects the recommended three-second following distance at this speed. The project hopes to show people the appropriate visual spacing required to safely follow vehicles on other roadways beyond the project area. |
05-06-2022, 2:58pm | #10 | ||||||
Barn Stall Owner #0331
Throw out a giant bag of marbles behind you and let them spin, crash and burn.
The Following 2 Users Say Thank You to Louie Detroit For This Useful Post: |
05-06-2022, 2:58pm | #11 | ||||||
Insufferable is the word of the day today.
Against my better judgement, I'm going to go through this again. When posed with the question, “What would you do if someone was tailgating you” Doug offered that he would slow and create more space between HIS CAR and the car IN FRONT OF his. I offered that move did NOTHING to get the tailgater off hi sass in in fact would make the situation worse. Yada yada, fast forward and I made the diagram showing TWO DISTANCES from the car in front of him and pointed out the obvious that the relationship between the tailgater and his car is UNCHANGED by his distance from the car in front of him. He then switched up the argument to say that it offered him opportunity to reduce his speed at a different rate. If I am maintaining my speed and he slows down, I will hit him. Pure science at work. The distance between our vehicles does not allow ample room for me to react. In my latest example, I indicated mph hour speed difference means that if he touches hi brake pedal so I KNOW he is slowing down, in my reaction time of .75 seconds, I will travel 5.4 feet BEFORE I hit my brakes. Therefore, if he is 6 feet in front of me, hits his brakes to drop 5mph and I see them and hit my brakes, I will still hit him. Reaction time, plus deceleration rate is going to put me too close to avoid him. This does not CHANGE just because the car in FRONT of him is 40 feet away vs 20 feet away. The ONLY relationship that matters is the speed and distance between Doug’s car and the tailgater. Only those two play a role in whether Doug gets rear ended. What HIS distance and the car in FRONT of him does impact, is whether it becomes a chain reaction that involves that front car. |
The Following 4 Users Say Thank You to Aerovette For This Useful Post: |
05-06-2022, 3:02pm | #12 | |||||||
I also am not arguing about whether it is or is not tailgating. The discussion revolves solely around whether INCREASING the distance between Doug and the car IN FRONT of him, alters the situation with the tailgater BEHIND him. See the diagram I posted. |
05-06-2022, 3:03pm | #13 | |||||||
yes, you proved once again that at 3 feet behind me there is NOTHING I can do to prevent you from hitting me since you are riding my ass. Traffic slow down ahead? BAM Cruise decelerates up hill? BAM Animal crosses road? BAM You got the distance SO close and SO dangerous to prove your point |
The Following User Says Thank You to UniqueDoug For This Useful Post: |
05-06-2022, 3:04pm | #14 | ||||||
05-06-2022, 3:10pm | #15 | |||||||
Ok, so we have established that 18 feet at 60mph IS tailgating. Finally appears we have reached some common ground. NOW on to reaction time, please see accompanying source material. How many feet have you traveled in 2 seconds (just below average reaction time) at 60mph? |
05-06-2022, 3:19pm | #16 | |||||||
If I have to be constantly tapping my brake and inching up on you, I'm just being a shit bag, but if you are just daydreaming, I'll get close enough that you should get a clue that you are holding up traffic. The point remains the you will NOT resolve the tailgating issue by increasing the distance between YOU and the car IN FRONT of you. |
05-06-2022, 3:24pm | #17 | ||||||
Doug for **** sake. Your argument was that you deal with tailgaters by INCREASING the distance between you and the car IN FRONT of you. Do I need to go search for your statement over there?
That is NOT true. Period. Charts, graphs, law, stopping distance does not matter. Increasing that gap does NOTHING to stop the tailgater. Why the **** is that so hard for you to comprehend. |
05-06-2022, 3:28pm | #18 | ||||||
Barn Stall Owner #∞
Gameroom Barn Bucks: $34677
Super.
The never ending argument thread. |
The Following 4 Users Say Thank You to z06psi For This Useful Post: |
05-06-2022, 3:32pm | #19 | |||||||
Here is your response...
05-06-2022, 3:32pm | #20 | |||||||
I’m leaving more distance, I gain reaction time, I give some of that to you. |
